It would still be less than $50 I'd reckon.
http://www.ebay.com....=item4d058ba32c
http://www.ebay.com....=item4abfd9e1f2
Edited by rodomo, 06 January 2013 - 11:57 AM.
Posted 06 January 2013 - 11:54 AM
Posted 06 January 2013 - 12:03 PM
I've got my thermo fan relay triggered from the 'ON' position of the ignition circuit. That way the power to the fan relay is cut during cranking.
Edited by torbirdie, 06 January 2013 - 12:08 PM.
Posted 06 January 2013 - 12:06 PM
These will do the same job, you might need to use one of these to trigger a bigger relay though? I'm not sure of the amps.
Edited by torbirdie, 06 January 2013 - 12:07 PM.
Posted 06 January 2013 - 12:07 PM
Posted 06 January 2013 - 12:26 PM
Well for now at least I just want to get the fans going in the right direction, do I just swap those 2 red wires going to the relays for the 2 earths that are bolted to chassis???? or I need to cut and swap over wires at the fan end?
Edited by torbirdie, 06 January 2013 - 12:37 PM.
Posted 06 January 2013 - 01:02 PM
ehh, Im not sure how that can work, there has to be power to the ignition circuit when cranking or it wont start.
Edited by S pack, 06 January 2013 - 01:02 PM.
Posted 06 January 2013 - 02:30 PM
Posted 06 January 2013 - 03:58 PM
I got all the tape etc off of the wires at the fan end where they are soldered onto the loom running to the relays, I can not seem to be able to De- Solder the wires with my soldering iron, they are really thick wires and chock full of solder!
Posted 06 January 2013 - 04:13 PM
Posted 06 January 2013 - 05:30 PM
Posted 06 January 2013 - 05:34 PM
Posted 06 January 2013 - 05:38 PM
Thats what im afraid of ,I have no idea why its doing that??? I only reversed the Thermo Fan Wires and they are not connected to the Gauge in any way?? Ive been unable to test the thermo fan direction now cause the gauge is now gone spaz!...Be careful with the temp needle going hard up to the full or highest marking. You might burn out the gauge.
Posted 06 January 2013 - 06:05 PM
Posted 06 January 2013 - 06:16 PM
Right, I got the temp guage fixed BUT even though I swapped the wires around on 1 fan to test ,it still seems to be blowing hot air out to the front of the radiator!!????.
If im standing at the front of the car .....then the fans are rotating towards my left side
Posted 06 January 2013 - 06:41 PM
So looking from the front of the car the fan is rotating anti clockwise?
Edited by 76S.L.R, 06 January 2013 - 06:42 PM.
Posted 06 January 2013 - 07:20 PM
Posted 06 January 2013 - 07:50 PM
Edited by torbirdie, 06 January 2013 - 07:54 PM.
Posted 06 January 2013 - 08:23 PM
Edited by torbirdie, 06 January 2013 - 08:25 PM.
Posted 06 January 2013 - 08:52 PM
Posted 06 January 2013 - 08:59 PM
Posted 06 January 2013 - 09:19 PM
Posted 06 January 2013 - 09:21 PM
Edited by 76S.L.R, 06 January 2013 - 09:23 PM.
Posted 06 January 2013 - 09:48 PM
But ive reversed the wires and it still blows towards the front of the car!!, bugger me I;ll have to try get the wires apart again now and paper test the other direction.
Ive stupidly put a lot of solder on them and theres not much wire left to play with if I cut them back again, they put the original splice not that far from one of the fans..
Posted 06 January 2013 - 09:56 PM
Are we correct in assuming that you have your fans fitted between the rad and engine and that the side of the fan pictured in my last post is facing the front of the car?
Posted 06 January 2013 - 10:03 PM
Yes the fans are mounted on the back of the radiator
