whiteline being owned by pedders i find this hard to believe....whiteline bushes are urethane, and theyre black in colour, these have proven to be a greatly improved bush
complete bush kit
#26
_Quagmire_
Posted 13 January 2013 - 02:16 AM
#27
Posted 13 January 2013 - 01:07 PM
Nathan works in the suspension game... so I'd hope he knows what he's talking about
The whiteline products I have seen before do seem alot better than the red stuff
I sell abit of Superpro at work... only been there 2 mths so no idea about failure rates and warranties
#28
Posted 29 September 2021 - 08:54 PM
Hi all, would you use the rare spares rubbers?
#29
Posted 11 November 2023 - 06:41 AM
My recent purchase of LJ complete front bush kit from Restocountry has an issue that i am in email with them about, awaiting response on way forward to a resolution.
As attached images, the LCA pivot bushes my wheel aligner alerted me to yesterday afternoon,
The Left side bush outer has slipped forward on the rubber.
The bushes have travelled less than 20Klm...
His suggestion is to fit Superpro, or Pedders bushes in there.
Watch this space.
Jaso
Posted 11 November 2023 - 08:27 AM
Holy sh*t Batman! If those are Mackay Autorubber bushes then I would be bitterly disappointed.
I had a Holden branded bush do similar to that on the RH LCA but it was the bush rubber separated from the inner tube.
Admittedly the bush was probably 25 years old.
Edited by S pack, 11 November 2023 - 08:31 AM.
#31
Posted 11 November 2023 - 09:31 AM
I cannot confirm at this point in time that what is supplied in the kit is actually Mackay brand.
Waiting on an email response.
#32
Posted 11 November 2023 - 01:33 PM
Both sides are beyond buggered. The rubber looks like it might be too soft as there is a lot of deformation? Perhaps that may account for the separation too, they should be bonded to the outer shell but if there's that much movement something's going to give
#33
Posted 11 November 2023 - 02:51 PM
Hi
Looks like the bonding bush to shell failed. Was the weight on the arm's when you tightened up the bolts? If it was my guess is the bush is faulty, If not and it was down at the bottom of it's travel when tightened the bush would flex to far and possably fail exactly as it has
#34
Posted 11 November 2023 - 03:49 PM
Posted 11 November 2023 - 05:56 PM
Hi
I have made this mistake before. Reinstalled the front crossmember in the LX and tightened everything up before it was on the wheels. Tore all the control arm bushes…
#36
Posted 11 November 2023 - 07:52 PM
Hi
Yes most certainly....the full vehicle weight was on the arms before tightening the bolts...
Posted 12 November 2023 - 07:40 AM
I guess some of this stuff could be manufactured then sit on shelves for 2 days or 2 years. Might take years for the batch to dribble through suppliers?
Edited by RallyRed, 12 November 2023 - 07:42 AM.
#38
Posted 13 November 2023 - 06:24 PM
I have requested a refund from Resto Country (RC) and have engaged my wheel aligner to fit Superpro ones in there instead.
I have not asked RC who supplies the bushes they provide in the kits... Im a bit over the matter TBH.
Posted 13 November 2023 - 06:50 PM
#40
Posted 13 November 2023 - 10:12 PM
Do superpro fail like nolathane?
Not that I have found from my own personal experience.
Edited by S pack, 13 November 2023 - 10:13 PM.
#41
Posted 15 November 2023 - 06:04 PM
Well, a reply.
The refund has amounted to $65.18. That is to cover the X2 LCA inner pivot bushes and I also asked for money back on the X4 control rod bushes too.
My wheel aligner Protrac, are fitting LCA bushes which i was advised can be supplied in 3 different % compounds - 70% (softest), 80% (medium), 90% (firmest) of which i have requested the medium.
Control rod bushes are being changed to Superpro too (on advice), unsure of the % compound though, was advised there was only 1 choice - So OK just put em in.
https://m.facebook.c...mibextid=Nif5oz
#42
Posted 20 November 2023 - 04:14 PM
I was talking to a restorer in Perth today, and he told me to stay away from Mackay bushes made after about 2015 because they were falling apart. He didn't have anything nice to say about the rares ones either. So is there a good rubber bush for LH available anywhere?
Edited by Shiney005, 20 November 2023 - 04:14 PM.
#43
Posted 27 November 2023 - 05:38 PM
Jaso :(
Posted 28 November 2023 - 01:22 PM
So there are no good rubber ones around? I might have to re-use my old ones at this rate.
#45
Posted 28 November 2023 - 10:13 PM
Somewhere in my shed I think I have a set of OE Holden ones... somewhere
#46
Posted 28 November 2023 - 11:07 PM
Get onto it Neil. Front end needs to go back in the car in a couple of weeks. Andrew has a set as well, but......well you know.....blood from a stone!!
Also tagged with one or more of these keywords: bush, steering, front, rear, end, suspension
Holden Tech →
Suspension & Steering →
Suspension BushesStarted by dacastle , 12 Jun 2022 ![]() |
Holden Tech →
Rear Spring Upper RetainersStarted by dacastle , 13 Apr 2022 ![]() |
Holden Tech →
General Questions and Help →
trailing arm bushesStarted by Squid , 23 Sep 2020 ![]() |
Members Area →
Non Torana Projects & Plans →
Suspension Guru's Help with Anti Squat for Street RodStarted by mick_in_oz , 19 Feb 2020 ![]() |
Holden Tech →
sway bar for rear lh lx with nine inchStarted by _torriemick_ , 16 Jan 2019 ![]() |
