Sill Mufflers
95 replies to this topic
#76 N/A-PWR
  • 9,639 posts
Posted 12 June 2014 - 10:17 AM
thank's Danny and DJ,
was reading further, and if you drive interstate,
your Vehicle has to be legal for that state too, regardless of the Visiting Time.
and as for the last sealed opening, the boot could be welded if need be.  :deal:
lucky for Me,
South Australia is Legal to have Side Pipes Now.
#77 N/A-PWR
  • 9,639 posts
Posted 12 June 2014 - 12:46 PM
I suppose we need to have these types of side pipes here too:-
http://www.gmh-toran...e-pipe-muffler/
http://www.rollaclub...es/page__st__30
http://questexhaust....otoid=104256445
#78 warrenm
warrenm
  • 2,118 posts
  • Car:1972 LJ Torana
Posted 13 June 2014 - 12:18 AM
When they refer to an opening it generally means an opening into the cabin, like a window or door, so there should be no need to weld the boot shut
#79 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 14 June 2014 - 08:54 AM
Sorry to hijack the thread...
I have been curious for a while, what performance advantages can be seen from side pipes?
I believe Brocks Toranas all ran side pipes from 73, hence I would imagine their are some advantages..
I was out watching the NC race cars last weekend and saw a few of the XU1s running side pipes also. Obviously not the VETTE style with heat shields, but just the side flow sticking its nose beneath the drivers door.
Edited by jkirky, 14 June 2014 - 08:54 AM.
#80 Shiney005
  • 9,614 posts
  • Car:Toyota Mirai
Posted 14 June 2014 - 09:26 AM
The full length exhaust restricts how much horsepower the motor can produce. Too much backpressure maybe.
The speedway guys used to run a straight bit of pipe back from the extractors with a chalk line drawn on it. They would do a few laps and where the chalk hadn't burnt off was where they cut it off.
#81 N/A-PWR
  • 9,639 posts
Posted 14 June 2014 - 01:06 PM
and less weight
and would be good if we don't need to weld the boot shut.
#82 _Lazarus_
_Lazarus_
Posted 14 June 2014 - 02:15 PM
I really don't think that is your main problem here.
It is whether they will allow the hot pipes to run down the sills or not, shielded or otherwise.
#83 _Lazarus_
_Lazarus_
Posted 14 June 2014 - 02:31 PM
Bit of info here -
Maybe legal on vans / utes ?
http://www.buga.com....d=2&topic=173.0
#84 76lxhatch
  • 7,208 posts
Posted 14 June 2014 - 02:55 PM
Difficult to fit a decent sized exhaust around the diff without tight bends, going out the side eliminates that problem. Plus it looks cool B-)
#85 _Bomber Watson_
Posted 14 June 2014 - 03:07 PM
Getting the pipe over the diff is generally the most restrictive area. Eliminating this is good.
I did ask that question, due to the boot having several openings into the boot it was deemed part of the cabin, so welding the holes in the rear bulkhead and parcel shelf may suffice.
Cheeer.
#86 N/A-PWR
  • 9,639 posts
Posted 30 June 2014 - 04:24 PM
Measured up the side pipes on the 11th of June, 02:46 PM, for the RAT ( 1830mm ), and 70" will be perfect:-
http://www.speedwaym...Inch,36756.html
#87 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 13 November 2016 - 02:03 AM
How much these setting you back Dave
shes gonna sound awesome with that huge
cam you will b running. 😊
Edited by madtoranajzedded, 13 November 2016 - 02:14 AM.
#88 N/A-PWR
  • 9,639 posts
Posted 13 November 2016 - 05:51 AM
Sure will Maz,
 from the link above, would cost $400 aud,
 which will need to wait for a special.
Low back pressure,
 2 1/4" id and performance sound :)
Edited by N/A-PWR, 13 November 2016 - 05:51 AM.
#89 V-SLR5000-P
V-SLR5000-P
  • 1,321 posts
  • Car:L34 x 2
Posted 13 November 2016 - 07:34 AM
To run a louvered boot lid on my Chev the engineer required a firewall to separate the boot from the back seat.
I have run an exhaust pipe exiting either side of this car for twenty years, never had an issue with the law.
#90 N/A-PWR
  • 9,639 posts
Posted 13 November 2016 - 10:54 AM
That's a Pro Street Gun Tim,
 nice louvers. :)
do you have a picture of the firewall by any chance?
Like button for you  :spoton:
#91 V-SLR5000-P
V-SLR5000-P
  • 1,321 posts
  • Car:L34 x 2
Posted 14 November 2016 - 05:13 AM
Nothing without the engine in the way. It has an HK Holden column and brake booster, no heater.
#92 _Lazarus_
_Lazarus_
Posted 14 November 2016 - 10:49 AM
I think he meant the rear bulkhead.
#93 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 14 November 2016 - 01:01 PM
I reckon all whats needed is to seal them
round holes with plate sikaflexed and screwed
down should be suffient and a couple other
small areas.being a 4 door once those holes
are done it would be hard for any fumes to
get in.
#94 N/A-PWR
  • 9,639 posts
Posted 14 November 2016 - 05:06 PM
Thinking there is a motor in the boot Laz.
Correct Maz,
I remember the fuel tank breather tube always breaking,
and the benzine ( yum ) fumes would be present in the cab.
#95 N/A-PWR
  • 9,639 posts
Posted 14 November 2016 - 05:22 PM
been thinking about how to connect the extractors to the side pipes,
 and now have come up with the idea of removing the LC/LJ sump hump,
 run a dry sump system, and run the rear 3 port primaries down and under through that space to the drivers side side pipe.
so a custom job option job there
#96 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 14 November 2016 - 06:42 PM
Good thinking or run the tune length dual
pacemaker headers .just like how a single
side pipe goes after the headers you have
2 90 deg angles but you will just have one ea
side muffler then your pipes ?.
The muffler on lhs will be tight?
Edited by madtoranajzedded, 14 November 2016 - 06:48 PM.
