Aftermarket Gauge Test article
2 replies to this topic
#1 _76S.L.R_
_76S.L.R_
Posted 12 January 2013 - 11:30 AM
Whilst researching what brand Water Temp Gauge to opt for ,to throw away my Current innacurate one I came across these Auto Speed Gauge Tests ,I was going to opt for a VDO Gauge but after reading these im not so sure now!
Part 1
http://autospeed.com...08/article.html
Part 2
http://autospeed.com...17/article.html
Can any of you guys recomend a good and KNOW ACCURATE Water Temp Gauge( Electrical)
Edited by 76S.L.R, 12 January 2013 - 11:31 AM.
#2 _hutch_
_hutch_
Posted 12 January 2013 - 12:06 PM
Well i would still stick to VDO (have used lots of them in marine and road applications), i dont think that it really matters to much being 16 % out at 40-60 degrees,so long as its accurate in the top end of the range is when ya need to knoiw that the engine is gettin hot
Phillip
#3 _torbirdie_
_torbirdie_
Posted 16 January 2013 - 06:58 AM
There is a reason that the manufacturer usually doesn't put values on the temp guage display. It can all be correct from new, but the semiconductor material in the sensor is not for ever and hence the readings can vary a little and then create needless warranty claims that the sensor isn't working, motor is overheating etc.
As you have found out the same things affect aftermarket gauges too!
As I outlined here: http://www.gmh-toran...try723742,(post #187) if you have a way of measuring the temp of your motor accurately you can take note of what the Ir says and mentally associate that temp with a position on the gauge, and/ or put some markers at 10c intervals.......just iike you'd do when comparing a speedo with GPS readings for particular speeds
If its only about not seeing the numbers on your aftermarket gauge being wrong, why not just ditch it all together and just rely on the standard dash gauge with the method suggested, it will be just as consistent as an aftermarket unit.
Edited by torbirdie, 16 January 2013 - 07:02 AM.
