Cheers fellas!
Had a bit of success on the steering rack parts searching! Put in a whole lot of time googling cars that had similar racks and found that a lot of the British Motor Corp cars like the Mini, Moke and MGB all used a very similar unit that looked a little different on the outside but had pretty much identical insides. So I scored a set of the spring washers, the elusive top shaft seal, some pinion cover shims and a couple of gaskets from a Mini joint in Sydney called Mini Kingdom Online. They even had the parts to my door next day which is pretty unusual these days. Out of stock on the yoke cover shims unfortunately so hopefully I've got enough from the pull down to sort it out with the new washers.
20220208_121103.jpg 335.68K
5 downloads
Also spent the afternoon swearing a lot putting the crossmember back in. It was really only the engine mounts that were a problem, the bolt holes didn't even go close to lining up with the crossmember holes until I attacked them with the round file... Anyhow, after having only planned to drop the crossmember a few millimetres to get the new rubbers between it and the chassis it ended up being out a lot longer than I'd hoped. It does look better for it though.
20220209_174854.jpg 399.35K
5 downloads
Edited by stevemc32, 09 February 2022 - 05:27 PM.
