Changing my mind like a little girl at the moment and decided to once again go ahead with the modifications to the original accelerator pedal. Fitting the Commodore one would probably have been nice and neat but it just needed too much work to get it done properly, when a correctly mounted version was already available.
Anyhow, the Commodore pedal was much easier to modify than the LX pedal I had earlier. A little bending at the top, some more terrible welding to get it connected to the LJ pedal and it looks to be completed.
1dscn1667.jpg 147.9K
16 downloads
1dscn1670.jpg 147.75K
17 downloads
The best part about this mod is that I can continue to use the original accelerator linkage system until it comes time to swap over the engines. This keeps it mobile for the carport construction.
Once the cable system is operational I'll clean up the welds and remove those parts of the pedal used for the linkages.
