LJ Sedan
388 replies to this topic
#176 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 13 June 2015 - 09:00 PM
I tried the phosphoric rust converter on the old shifter housing and it didn't really look to do anything so I've just sanded the coffee pot a little more and hopefully it will be ok.  I used an epoxy metal substitute to fill the holes and it looks to have worked out alright.
Attached File  20150610_164138.jpg   275.96K   9 downloads
Got a coat of matt black onto the column tube and bracket and an aluminium etch primer onto the coffee pot.  Will have to get some spray putty onto it next to get rid of the all the sanding marks then think about a final coat colour.  Probably just a satin black I think for the column covers and steering wheel.
Attached File  20150612_135224.jpg   544.49K   10 downloads
#177 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 15 June 2015 - 10:56 PM
Attached File  20150615_215913.jpg   92.77K   7 downloads
In Rod we Trust!
My chunk of delrin rod turned up tonight.  Hopefully I can turn it into a steering column lower bush tomorrow.
#178 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 16 June 2015 - 09:47 PM
The Delrin rod is definitely a winner.
Didn't take much effort at all to turn up a lower bush though it did make a pretty big mess in the shed.
Attached File  20150616_145131.jpg   100.12K   8 downloadsAttached File  20150616_145333.jpg   96.37K   7 downloads
I've cut a small recess on the bottom side for an oil seal to keep the dirt and water out.  Waiting for the seal to turn up in the mail.
The bush is held in place with the screws top and bottom that originally held the auto shifter gate.  Looks like it works well so far.
Attached File  20150616_145758.jpg   94.16K   9 downloads
Quick question that google couldn't really answer.  Does this type of acetal bushing need to be lubricated or is it best to run dry?
#179 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 25 June 2015 - 10:09 PM
Nothing too exciting.  Shaft seal arrived today so I fitted it up to the bottom of the steering column lower bearing.
Attached File  20150624_150723.jpg   130.4K   7 downloads
Still haven't found any solid info on whether to lube the delrin bearing but I threw some Lithium grease at it anyway.  The seal should keep it dirt and water free.
#180 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 26 June 2015 - 09:58 AM
Nice work Steve.
Cheers Graham.
#181 _Nath_
_Nath_
Posted 08 May 2016 - 07:46 PM
Hey Steve,
Hope the build is going well.
I was hoping to speak to you re your clutch cable set up.
Do you have a number I could call you on?
#182 Heath
  • 18,385 posts
Posted 10 May 2016 - 08:07 AM
In the LH/LX/UC models we can easily installed a sealed bearing on the column which is nice.
Any idea how well the Delrin bush will work in comparison?
Nice work.
#183 orangeLJ
Posted 10 May 2016 - 10:08 AM
I whacked a fine smear of vaso in there to be safe. Not that I've done a heap of kms, but it's still really nice to steer.
#184 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 17 May 2016 - 04:37 PM
Good to hear the delrin bearing is working well orangeLJ.
Haven't had any real progress on the LJ for about a year now, still working on the house and carport so I can get it undercover and start on the body.
Hey Steve,
Shoot me a PM Nath and I'll tell you all about the clutch.
#185 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 04 May 2017 - 03:38 PM
Well about a year has passed, the Torana is waiting patiently and I'm still watching other builds move along.  No progress on the car unfortunately but there has finally been some movement on the carport project.
Hopefully not too much longer before the LJ has a home.
Attached File  concrete.jpg   572.77K   6 downloads
#186 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 08 February 2018 - 08:02 PM
Almost a year later and the bloke doing the structural steel for the carport went bankrupt so still no home for the Torana.  There's a chance the steel might come through so all is not lost just yet.
Still waiting patiently...
Attached File  20171231_142412 - Copy.jpg   268.47K   5 downloads
#187 gtrboyy
gtrboyy
  • 3,209 posts
Posted 08 February 2018 - 08:34 PM
That sucks still not able to have the torrie sheltered.
Just noticed had something done similar on lc steering column years ago but without that bearing just turned down superpro bush in it's place.
#188 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 17 January 2022 - 07:19 PM
Hmmm, long time no progress.
Long story short, the f-wit doing the steel for my carport took 7 grand off me, bankrupted his company and pissed off to Queensland without delivering any steel.  That was a pretty big hit to my motivation for both the house/carport works and the Torana build.  It was a good while ago so I'm over it and there's finally a little bit of shelter starting to form for the car.
I've moved away from the full rebuild plans as I just want to be driving it now so I've got a whole heap of suspension, steering and brake parts ready to be fitted for a full refresh on those and a couple of sill repair panels and lower guards that'll need sorting out for rego.  Looks like I've finally got an engineer on board for the EFI and gearbox mods too so hopefully it'll be on the road soonish.
Attached File  20220116_175938.jpg   320.89K   5 downloads
#189 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 18 January 2022 - 08:07 PM
Kicked off the front-end refresh with caliper removal.  There's certainly 50 years worth of crud in there and someone had replaced the anti-squeal shims with a generous coating of silicone on the back of each brake pad!
Three out of the four caliper pistons came out without any trouble but the last one is stuck in there good.  Save that one for tomorrow.
Attached File  20220118_152659 - Copy.jpg   408.36K   7 downloads
Attached File  20220118_152653.jpg   494.99K   7 downloads
Attached File  20220118_181657.jpg   436.86K   7 downloads
#190 Heath
  • 18,385 posts
Posted 20 January 2022 - 08:20 AM
Nice to see some progress on this project. Welcome back.
The car looks pretty good. I wouldn't blame you for getting it out and enjoying it with the paint that's already on it.
How it performs is more important anyway.
#191 rodomo
  • 18,037 posts
Posted 21 January 2022 - 10:30 AM
I feel your pain with the calipers. I went through this as well. Have a look here, post 502 http://www.gmh-toran...-thread/page-21
#192 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 22 January 2022 - 07:03 PM
Cheers Heath, it was good to catch up on your build and see the awesome result.  Fantastic!
Thanks for the link Rob, I did actually see that post when I went searching for ways to unstick the bastard.  A few days of penetrene and lots of swearing and I finally got it out.  Lots of progress on your build as well, I'm impressed!
I've painted up the calipers and just waiting on some new pistons so I can put them back together.  Done a bit more dismantling of the front end today, got the lower control arms, springs and stuff like that out.  Reading the Max Ellery manual on the removal of the upper control arms it says remove the two bolt attaching the upper control arm to the tower and remove the shims.  Got that part done no worries but the next line is - remove the upper control arm from the vehicle!  I'm stuffed it I can figure out how that is supposed to happen without dropping the crossmember, am I missing something???
Attached File  20220122_153731.jpg   436.63K   6 downloads
Not sure if this lower control arm bush is 50 years old but it sure looks it!
Attached File  20220122_154418.jpg   328.03K   5 downloads
#193 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 23 January 2022 - 05:44 AM
You have to drop the cross member down.
#194 RallyRed
  • 8,147 posts
Posted 23 January 2022 - 08:01 AM
As above..
#195 RallyRed
  • 8,147 posts
Posted 23 January 2022 - 08:05 AM
The crossmember part referened in the above..
#196 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 23 January 2022 - 09:32 PM
Thanks for the info gents!
I was hoping to only lower the crossmember just enough to slip the insulator bushes in then bolt it straight back up again.  Think I'll block up the engine and just drop it completely out now I know it needs to be clear of the chassis for the upper arms to come out and go back in.  Good chance to get it cleaned up I guess.
Step 5 in the picture above says use a block of wood under the oil pan and jack up the engine.  Is the bottom of the sump strong enough to hold it for a week or so while I work on the crossmember or should I look to block it up under the sump bolts?
#197 warrenm
warrenm
  • 2,117 posts
Posted 24 January 2022 - 05:35 AM
The sump is strong enough with a block of wood under it.
#198 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 24 January 2022 - 08:30 AM
Cheers, thanks Warren!
#199 Heath
  • 18,385 posts
Posted 24 January 2022 - 02:45 PM
Yep, just spread the load across the sump and you'll be sweet.
If you try and hold the motor up with all the pressure on one little point, then you'll bend the sump, which will nearly always happen directly where the pick-up is, haha. So don't do that.
#200 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 24 January 2022 - 06:06 PM
Cheers Heath, I avoided the pickup area as I needed the room to drop the crossmember out.  Looks to have all gone ok and I was surprised the crossmember was no where near as heavy as I was expecting.
Definitely gone further than I'd hoped to at this stage but it's out now so I'll give it a wire wheel, rust convert and cheap arse rattle can spray job before putting it back together.  I reckon it'll actually look pretty good for a few months!
Calipers are coming along too, caliper pistons and a new master cylinder should be arriving soon so the next job is to make up a whole new bunch of brake lines to replace the rusted out crap.
Should I use rubber grease on the caliper piston seals or just brake fluid for initial lube when putting them back together?
Attached File  20220124_110626.jpg   329.93K   5 downloads
Attached File  20220124_121600.jpg   262.74K   5 downloads
Attached File  20220124_171953.jpg   436.9K   5 downloads
