LJ Sedan
388 replies to this topic
#201 Peter UC
Peter UC
  • 771 posts
Posted 25 January 2022 - 11:23 AM
Just use brake fluid
#202 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 25 January 2022 - 06:47 PM
Cheers Peter, the caliper pistons showed up today so I got them fully assembled.  Went with brake fluid on the piston seals and a little bit of rubber grease under the dust boots.
Finished cleaning up the crossmember and did a quick repair in the usual spot, then hit it with a couple of coats of primer.
Next job is figuring out how to get those upper control arm bushes out, a bit of research is needed!
Attached File  20220125_125845.jpg   396.86K   9 downloads
Attached File  20220125_151823.jpg   433.63K   6 downloads
Attached File  20220125_185816.jpg   613.77K   4 downloads
#203 gtrboyy
gtrboyy
  • 3,241 posts
Posted 25 January 2022 - 08:50 PM
Does this really need engineers report for efi engine or just engine numbers?
I've found on lot of older cars as long as car is roadworthy & looks legal even the stricter blueslip inspectors pass the cars...maybe they're too young to know what factory spec is but as long as it shows up on RMS cars pass much easier than 90-00's era if had late model engine in old car bs
#204 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 25 January 2022 - 09:18 PM
I think my fuel tank mods and the replacement transmission crossmember are the only things that really need certification as the EFI still retains the 1973 emission controls which is just the PCV.  I don't expect it will be any real issue.
#205 Rockoz
Rockoz
  • 4,065 posts
  • Name:Rob
Posted 26 January 2022 - 08:56 AM
How we did upper bushes back in the day without a press.
Place control arm in a sturdy vice.
Put a nut back on one side of the link.
Get a very large hammer and start belting the link.
The raised portion on the link will push the opposite bush out.
Then put the nut on the other end and bash it back the other way.
Did hundreds of them.
These days I would use a press, but the basics are the same.
Rob
#206 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 26 January 2022 - 06:06 PM
Thanks Rob, I'm a little more hesitant to start bashing things with a big hammer these days since the parts are becoming harder to find.  Some dude on youtube posted a video of removing the upper control arm bushes from his LX while it was still in the car and I was able to follow that method fairly easily.
I got all the ball joints removed.  My little one man powered press made light work of the bottom ball joints.  I looked at the lower control arm bushes and decided a few days of penetrene might be a good bit of preparation before trying to push them out.
Attached File  20220126_112218.jpg   525.28K   3 downloads
Attached File  20220126_123615.jpg   449.98K   3 downloads
Started stripping down the rack as well to fit new rack ends and tie rod ends.  I'm struggling to work out how the rack ends come off as they don't seem to have a pin like the old workshop manual shows but instead looks like the lock nut is bashed into the pin hole to secure it?  I'll try to pry out the lock nut parts before attempting to remove it.
Attached File  20220126_185831.jpg   263.21K   3 downloads
Attached File  20220126_185851.jpg   332.57K   5 downloads
#207 smeer
smeer
  • 1,526 posts
  • Car:1970 LC 4-door
Posted 26 January 2022 - 09:49 PM
Not really worth the risk damaging the threads of the rack by drilling out the peening.
Dremel a small cut in the lock ring and crack it in 2 with a screw driver. It's not very strong and should break off the threads allowing you to remove the unit.
I think there is a preload spring inside but replacement ends are a much simpler one piece item and simply thread onto the rack, no lock ring or whatever.
Edited by smeer, 26 January 2022 - 09:49 PM.
#208 S pack
  • 15,762 posts
Posted 27 January 2022 - 07:05 AM
If possible pries the indentations up in the lock collar, the metal is soft but be aware bits might break out or tear. If you need to drill them out that is fine as there are no threads near the indentations, just use the smallest size drill bit required to do the job.
Personally, if your existing original tie rods and seats (keep the parts as a matched set) are in serviceable condition I would re-use them rather than those aftermarket things, but that is just my preference.
#209 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 27 January 2022 - 09:10 AM
Thanks for the info Gents, I'll get onto it today.
I did consider keeping the old rack ends but they are a bit floppy so I think it'll be best to swap them out for new ones.
#210 S pack
  • 15,762 posts
Posted 27 January 2022 - 09:22 AM
They may just require adjusting.
#211 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 27 January 2022 - 11:42 AM
Got them both off.
It's hard to get a decent photo but this is the passenger side one and it's pretty worn.  I can feel a catch in this one also so I'm not really happy to put it back on.  I didn't do any damage getting them off so I will keep a hold of the originals and maybe revisit them if there's an issue with the replacements.
Attached File  20220127_115224.jpg   331.64K   6 downloads
#212 S pack
  • 15,762 posts
Posted 27 January 2022 - 11:51 AM
If you can feel distinct wear marks then they are probably done unless a machine shop could build up the worn spots with weld, machine them and re-heat treat them.
#213 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 27 January 2022 - 05:37 PM
Yeah into storage for those for now.
The crossmember is painted and the rusted lower control arm bushes came out without too much fuss after a few days of WD.  Just need to clean up and paint the arms and hubs so I can start putting it back together and then get onto the rear end.
Made up a new set of crossmember brake lines today and have a new master cylinder to fit also.
Attached File  20220127_175740.jpg   321.29K   4 downloads
#214 Indy Orange
Indy Orange
  • 2,982 posts
  • Name:Paul
Posted 27 January 2022 - 06:32 PM
Nice job.
#215 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 27 January 2022 - 07:12 PM
Nice! I really enjoyed making brake lines for my Torana, it's a cool process over a couple of beers.
#216 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 04 February 2022 - 07:15 PM
Yeah I agree, it's good fun making up new brake lines.
Not much progress this week due to work but I did get some time in on the wire wheel.  Didn't really enjoy that part but the pieces are slowly getting painted up and should have the front end going back together soon.
Attached File  20220204_183937.jpg   366.76K   2 downloads
Attached File  20220204_183942.jpg   324.51K   3 downloads
#217 claysummers
claysummers
  • 3,714 posts
  • Name:Clay
Posted 04 February 2022 - 07:22 PM
Nice work. I love wire wheels on the 18v drill.
#218 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 05 February 2022 - 05:25 PM
Got some painting done and stripped down the rack today.
A few questions on putting it back together.  One of the spring washers was broken and there was only about a third of left in the housing, not sure where the rest went but probably stuck in the crappy boots I took off it...  I've done a search for replacement washers but could only come up with Rob's lawn mower blade Bunnings items, are these still the best bet or is there another solution?  Are there gaskets available for the covers or should I just cut some myself from gasket paper?  Finally I've noticed people are not bothering with the gear oil and just lubing the rack with grease, is this the way to go, there was certainly no oil left in it when I dismantled it!
Here's the remains of the spring washer!
Attached File  20220205_164003.jpg   418.25K   5 downloads
The rest of it looks ok but I'll probably change out the bearings since I've got it stripped.
Attached File  20220205_164445.jpg   360.6K   8 downloads
Attached File  20220205_173114.jpg   293.14K   4 downloads
#219 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 06 February 2022 - 03:22 PM
Fitting the upper control arm bushes and not having much luck.  Only one of the bushes needed to be pressed in, the other three are loose in the holes.  Are there oversize ones available or another method of making them fit?
Also not sure if I should be using the washer on the inside of the bushes.  This was how they were fitted when I removed the old bushes but I can't see that washer in any of the service or parts manuals and it seems to be making the control rod too wide for the bushes to seat in the upper control arm.  Should I ditch them?
This is the washer, inboard of the bush on the control rod.
Attached File  20220206_151245.jpg   321.19K   2 downloads
This is the extra space on the right hand side that the bush hangs out of the upper control arm with the washers fitted.  I have measured the upper control arms and they are the correct width, just over 8 inches apart.
Attached File  20220206_152204.jpg   409.16K   4 downloads
Attached File  20220206_152232.jpg   372.11K   2 downloads
#220 MustardGTR
MustardGTR
  • 243 posts
  • Car:72 GTR, 73 GTR
Posted 06 February 2022 - 10:24 PM
I would be interested to know how you go if you decide to replace that lip seal. At the time I struggled to source a new replacement.
#221 warrenm
warrenm
  • 2,130 posts
  • Car:1972 LJ Torana
Posted 07 February 2022 - 05:38 AM
Take the inner washers off, that will allow the bushes to go in further.
#222 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 07 February 2022 - 05:10 PM
I took the washers off the control rod as suggested and had a better result today.  Pondered the problem of the bushing holes being too big to hold onto the bushings for a while and decided to try resize the hole instead of the bushing.  I cut down a bearing race from the front hub and pressed it over the flange on the upper control arms to squeeze it in a little and it worked a treat.  Only needed about a quarter of a turn on the hand press to sort them out.  Got all the front end bushes and ball joints pressed and fitted today.
With regards to the oil seal on the rack, the one I have doesn't seem to be in bad shape.  I'll add it to my list of shims and spring washers that I need to find for the rack rebuild and see what I can come up with.
Attached File  20220207_135258.jpg   279.59K   6 downloads
Attached File  20220207_174132.jpg   393.88K   8 downloads
#223 neglectedtorana
neglectedtorana
  • 1,057 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 07 February 2022 - 07:27 PM
Nice work re-sizing the bushing hole Steve, that's a great idea!
#224 Bruiser
Bruiser
  • 871 posts
  • Name:Bruce
Posted 08 February 2022 - 06:48 AM
Yeah, i'm impressed with that, too
Very clever
#225 Heath
  • 18,403 posts
Posted 08 February 2022 - 10:41 AM
Mate, that is really impressive! Nice work with the re-sizing. I've got a big grin after reading that.
