* * * * * 1 votes
The Marty Report
LJ GTR Build
1095 replies to this topic
#251 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 30 November 2013 - 10:32 PM
Thanks John and Craig.  Not a fan of the shiney boot, it's a satin so it should flatten out as it drys.
Would love to paint something small in the orange but it's a big process.  All base coats in 2k then I have to undercoat in Acyrilic, then white acrylic then the Tangerine.  I reckon this will glow in the dark.
Marty
#252 Potta
Posted 30 November 2013 - 10:41 PM
Haha yeah mate, not trying to make you rush it, just got a tad excited when you showed us the colour and looking forward to seeing it on the car.
I bet you are too!
#253 frash da bucket
frash da bucket
  • 1,890 posts
Posted 07 December 2013 - 09:50 PM
G'day Martin,
So what have you done to it this week.
Regards John.
#254 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 07 December 2013 - 11:36 PM
Not much John, Getting battery tray in is tricky. Had to get some paint down first in the areas you can't get to once the tray is in. Welded it in then KBS d it.
Attached File  ImageUploadedByTapatalk1386423263.053630.jpg   57.21K   35 downloadsAttached File  ImageUploadedByTapatalk1386423278.285449.jpg   66.08K   33 downloadsAttached File  ImageUploadedByTapatalk1386423292.938465.jpg   67.2K   36 downloads
Also painted inside the plenum.
Attached File  ImageUploadedByTapatalk1386423328.221356.jpg   54.65K   33 downloads
Next step is the front inside guards with stone chip then the engine bay.
Marty
Edited by sibhs, 07 December 2013 - 11:39 PM.
#255 Potta
Posted 08 December 2013 - 12:17 AM
Then colour ??? :-)
#256 N/A-PWR
  • 9,638 posts
Posted 08 December 2013 - 12:22 AM
 Good Job Marty,
Hey, didn't Triples have an angled Battery Tray?
#257 Potta
Posted 08 December 2013 - 12:24 AM
He's not doing triples Dave, he's got an original ww I think.
#258 N/A-PWR
  • 9,638 posts
Posted 08 December 2013 - 12:26 AM
ah, cool - jumped the Gun as usual
#259 Potta
Posted 08 December 2013 - 12:40 AM
I only remembered cause he was looking for a carby and filter when he was at my place a while back.
#260 _LONA-CK_
_LONA-CK_
Posted 08 December 2013 - 05:53 AM
keep going mate you will get there,,, under that plenum should be painted the same color as the car mate,, just letting you know that just in case.
looking good.
cheers gong
#261 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 08 December 2013 - 08:08 AM
Boot is painted. Used black with 10% white paint. It may not be totally the right colour but from what I've heard as long as it's not black it should be ok. bymuruta.jpgattachicon.gifImageUploadedByTapatalk1385807295.883988.jpgattachicon.gifImageUploadedByTapatalk1385807313.765234.jpgThis is where I did that repair using a piece of sump. Came up a treat. attachicon.gifImageUploadedByTapatalk1385807422.366133.jpgStarted sanding the.first hifill in the engine bay. zeqybazu.jpgMarty
It looks like it's coming along nicely, well done Marty.
I don't think that there is any single shade of grey that is correct for Adelaide built boots or engine bays, I think each car varies depending on the batch of paint that they were trying to use up. Your colour looks similar to mine, so you should be happy with your result.
#262 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 09 December 2013 - 10:32 PM
<br />Then colour ??? :-)
Steady on Craig, Colour will happen when it's ready, it is tempting to try it though.
<br /> Good Job Marty,<br />Hey, didn't Triples have an angled Battery Tray?
Yep no triples on this power plant, thanks for looking out for me.
<br />keep going mate you will get there,,, under that plenum should be painted the same color as the car mate,, just letting you know that just in case.<br />looking good.<br />cheers gong
Thanks Gong, didn't realise that, i'll do it in Tangerine when the body is painted. I'm glad your keeping an eye on this build, appreciate it.:-)
I've applied the anti gravel to the front guards and given them a good thick coating up the tops. After see a few cars with damaged paint from stones flicking up underneath and denting top of guard.
Coated the inspection plates in position then removed them when I paint the under guards black tomorrow.9eqyzapu.jpga5azery5.jpg
Applied it to battery tray area aswell cause it was a bit pitted.
Marty
Edited by sibhs, 09 December 2013 - 10:39 PM.
#263 Ice
  • 15,200 posts
Posted 09 December 2013 - 11:02 PM
Thats the way to do it marty nice and thorough it will be the last time any body has to go there again
i cant wait for colour either
still think you should paint it SMP ha ha ha ha ha
#264 N/A-PWR
  • 9,638 posts
Posted 09 December 2013 - 11:46 PM
here is the Code Geno has served Marty - Strike Me Pink. Paint Code: 13891, Trim Paint Code: 1840
#265 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,418 posts
  • Name:facebook dave
Posted 10 December 2013 - 10:14 PM
looks like a very fine build marty
especially to attract the attention and praise of john gong!
but he's right!
can't wait to see colour on it cheers
davemc
#266 frash da bucket
frash da bucket
  • 1,890 posts
Posted 11 December 2013 - 09:04 PM
Hi Marty,
Its looking good keep up the good work.
Regards John.
#267 Potta
Posted 12 December 2013 - 11:18 PM
Take your time Marty and do it right just like you have from the start.
We all want to see colour but we want to see it done right.
I don't think you'd have much luck at the moment anyway, the paint would harden before it hit the car  :blink:
#268 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 12 December 2013 - 11:43 PM
Was just about to paint the engine bay today when I checked some masking lines. Found a note mentioning the accelerator return spring tab was deleted in 73. Bugger, after some frantic phone calls and checking a heap of photos the decision was made to take it off. That's put me back a day.
Attached File  ImageUploadedByTapatalk1386855770.714704.jpg   50.6K   29 downloads
Attached File  ImageUploadedByTapatalk1386855786.078618.jpg   52.04K   27 downloads
Attached File  ImageUploadedByTapatalk1386855797.946087.jpg   54.48K   26 downloads
Attached File  ImageUploadedByTapatalk1386855809.932385.jpg   51.2K   26 downloads
Attached File  ImageUploadedByTapatalk1386855821.065045.jpg   51.33K   25 downloads
Marty
Edited by sibhs, 12 December 2013 - 11:47 PM.
#269 Ice
  • 15,200 posts
Posted 12 December 2013 - 11:50 PM
If you still have that tab can you bring it with you tomorrow marty
#270 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 12 December 2013 - 11:56 PM
will do.
#271 Ice
  • 15,200 posts
Posted 12 December 2013 - 11:57 PM
#272 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 15 December 2013 - 11:44 PM
Had a fail, painted the engine bay Friday morning but it looked bad. Problem was I'm using a Matting agent in my paint which I mixed up last week. This makes the paint gluggy once left for a while and even though it was strained It was too thick to get out the gun without heaps of air. Caused dust like effect.
Attached File  ImageUploadedByTapatalk1387114708.468003.jpg   57.91K   29 downloads.
This is first coat followed by two more then the effect I was left with. Have since rubbed it back and will try again tomorrow with a fresh paint mix.
Attached File  ImageUploadedByTapatalk1387114844.051271.jpg   67.43K   29 downloads
Rubbed back and ready to go again.
Attached File  ImageUploadedByTapatalk1387114867.219186.jpg   63.57K   27 downloadsAttached File  ImageUploadedByTapatalk1387114994.003090.jpg   87.95K   27 downloads
Think I'm going crackers. Marty
Edited by sibhs, 15 December 2013 - 11:47 PM.
#273 N/A-PWR
  • 9,638 posts
Posted 15 December 2013 - 11:49 PM
Better Crackers Tomorrow Marty,
Good Luck
#274 Ice
  • 15,200 posts
Posted 16 December 2013 - 12:06 AM
Im not even going to ask what there hangin in there for
Oops i just did
#275 TerrA LX
Posted 16 December 2013 - 12:28 AM
I had bonnet gap issues, back to cowl is square, good gap LH side but drivers side was too narrow. What to do?
Had a panel beater come over for a look and he helped with a twisted door, a guard sitting high, but what was suggested for this problem worried me.  Hit the top of the guard with a bolster then hit the guard out. (sounds bad, and it was) I started this process but after 5 mins I realised this isn't working, plus There will be a visible crease in the top of guard when looking from below. I decided to cut the guard, pull the edge over and weld it up. Then ground weld under guard so no visible sign.  Was some scary shit there but now I'm satisfied.
I have seen and done some pretty out there stuff when gaping Holdens but I have never seen anyone split a guard like that.
