Hi Guys,
Got the two coats of 50/50 on followed by three coats of clear. Rubbed it all back today and must say rubbing clear is better than colour. Less mess plus your left with a uniform finish.
Also got the doors and boot on. Any advice on this issue appreciated. Drivers door closes fine but passenger door needs a bit of force. The spring on passenger door stretches more causing the door pressure. Both door straps exactly the same. Springs just bought from parts boner, Pics below
This shows doors shut, there is a different distance between roller and first notch between doors. Not sure why.
Here's some rubbing pics.
Just had to put the badge on, make sure it's still in position.
Now boot's on, I'll do a bit of patch painting where scratched while fitting. Then fit the zinced bolts.
Marty
