Posted 13 April 2014 - 11:50 AM
Posted 16 April 2014 - 10:09 PM
Had the rear seats stripped by trimmer so he can use foam as a guide for retrim. Took wire guts home.
Test fitted them to rear, good thing I did, they needed a bit of bending to fit nice, something you couldn't do once trimmed.
Gave them the rust blast treatment so now ready to paint.
Can't believe I tried to cure the manifold in the kitchen oven. Thankfully it didn't fit and had to think of an alternative. The BBQ, how simple.
Cooked at 180 degrees for an hour.
Marty
Edited by sibhs, 16 April 2014 - 10:12 PM.
Posted 16 April 2014 - 10:13 PM
Very Smart Marty,
Never seen so much done the way You have done, it is like you are building a Brand New Torana. Dave I
Posted 16 April 2014 - 10:17 PM
Posted 16 April 2014 - 10:22 PM
Those bricks are gunna be hard to chew i reckon
Had a chuckle, you're a cunny funt,.....sometimes:-)
Posted 16 April 2014 - 10:26 PM
Straight from the horses mouth
Bricks are used in Kilns too
so Marty knows what he is doing Gene
Posted 17 April 2014 - 07:09 AM
Some sauce, they"ll be spot on.
Edited by warrenm, 17 April 2014 - 07:10 AM.
Posted 17 April 2014 - 12:37 PM
Posted 18 April 2014 - 12:14 AM
Posted 18 April 2014 - 12:48 PM
Posted 22 April 2014 - 05:33 PM
Thanks Jonesy, may as well do the best you can, doesn't take that much longer and no regrets.
Hi John. This weekend has been about chasing Salmon around the South-West.
Did manage to paint the frames though.
This week is getting the blackouts done and diff bushes pressed in.
Marty
Edited by sibhs, 22 April 2014 - 05:35 PM.
Posted 22 April 2014 - 10:34 PM
We see you having a break Marty,
Now get back to work. Dave I
Posted 22 April 2014 - 11:02 PM
Posted 27 April 2014 - 09:36 PM
Posted 28 April 2014 - 10:27 PM
Posted 06 May 2014 - 10:29 PM
Posted 07 May 2014 - 10:31 AM
Howdy all,
been a bit busy with work so progress is slow but here's what been happening.
Applied the cavity wax to chassis rails. What a balls up, the shultz gun I used was like turning on a tap, it could pump out 1 litre in 2 seconds, not good when it's $25 per litre. I had containers scattered trying to collect the excess to re-use.
IMG_5084.jpg 47.66K
25 downloads
IMG_5081.jpg 60.35K
25 downloads
This is the gun and the nozzle size it comes with, take it from me, this gun is good for the underbody stone chip but sucks with rust proofing application.
IMG_5086.jpg 63.77K
23 downloads
IMG_5085.jpg 49.18K
23 downloads
I ended-up buying some cavity wax in a spray can for all the tricky bits, used the excess from the spray gun to pour into doors, boot and let it flow to all seams and brush on the sides.
Little tip, jack-up the car to flow the wax to both ends, I'm glad I did this, otherwise you will also get pools of the stuff drying in low points. I also blew air through to spread it and get out the excess.
IMG_5073.jpg 55.83K
27 downloads
Patched the rocker cover and re-primed. I know these should be chrome on the GTR but until I find a good one this one will be red.
IMG_5066.jpg 46.48K
21 downloads
IMG_5097.jpg 46.61K
22 downloads
Started bolting bits to the engine.
IMG_5117.jpg 56.53K
25 downloads
IMG_5118.jpg 52.44K
27 downloads
I was going to get black-outs done soon but i'm putting that off until I can rub back and compound the whole car. Leaving the paint for 3 months before this happens. The countdown is on - 6 weeks to go. I'll just have to heat the booth before spraying.
Marty
Edited by sibhs, 07 May 2014 - 10:32 AM.
Posted 07 May 2014 - 11:30 AM
Hey Marty,
Looking good mate - making good progress.
I've got the same gun and yes, they spray heaps - made a real mess on a previous car of mine. I'm not looking forward to doing mine with the same so may have to investigate other options.
Jeff
Posted 07 May 2014 - 02:56 PM
Posted 07 May 2014 - 06:17 PM
Posted 07 May 2014 - 07:10 PM
Hi Mike, yeah for rust prevention. It's ment to be better than fish-oil, definatley more expensive. Forum member has applied both and left outside in weather with cavity wax out lasting the fisholene. That was good enough for me.
Marty
Posted 08 May 2014 - 07:35 AM
I have the same type of gun, & found the same problem, but reduced the air pressure pretty low & it was better.
Posted 18 May 2014 - 10:53 PM
Lost track of how long it's been since painting but it's been at least two months. Decided to do some cutting back and compounding.
Started with 1200 and worked my way up through 1500 to 2000. Then using a damp foam pad and some "Juice" cutting compound I got to work with the buffer.
Here are some pics of progress.
Before
after rubbing
after compound
I'll leave judgement to how it came out to those that see it in the flesh.
The diff and axles are getting new bearings and should be ready this week.
Marty
Edited by sibhs, 18 May 2014 - 10:57 PM.
Posted 18 May 2014 - 11:07 PM
Bluddy bewdiful Marty. Happy days at last.
Posted 21 May 2014 - 11:42 PM
