* * * * * 1 votes
The Marty Report
LJ GTR Build
1095 replies to this topic
#751 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 01 August 2014 - 09:51 AM
Hi Adam,
Yeah they will try and fix-it. Their concern was if they try fix it, and it warps, the thing is stuffed.
If it does go bad, they will re-chrome another one if I get one.  All no extra charge.
Their attitude was helpful, so I'm happy and hopeful. Find out next week.
Marty
#752 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 02 August 2014 - 01:28 AM
she.s starting to look rather ravishing marty,good to hear the chroming guys will redo another cleaner at no extra cost
how do you get the fascias off the the temp instrumentation bud
#753 frash da bucket
frash da bucket
  • 1,890 posts
Posted 02 August 2014 - 03:08 PM
Hi Marty,
Great job on your grille badge fantastic !!!
And its comming together nicely.
Like the dash and the way its come up a treat.
And comming back together slowley,bit by bit.
Regards John.
PS Have entered all holden day tomorrow,
with my xu-1 club,will take photo's !!!
#754 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 August 2014 - 03:38 PM
Hi Marty. Can my mate Danny get a set of low dash decals off you.His number is 0427321288. Cheers Gary
#755 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 14 August 2014 - 11:01 PM
Hi Madaz, getting the fascia off is a bit messy, just used a small flat blade and work my way around the lip to stretch it. Once repaired I think I'll leave them loose. Don't want to tap it back into shape cause the guage will shake.
I've got the front indicators sorted with single wires.
Getting the kFrame off the table.
Some wheels on it and almost on the ground.
Brake bracket zinced and fitted.
Got a new speedo cable and fitted that. Used a bit of wire to guide it through the pedal assembly mount.
Cable looks pretty good, just needed a cable tie to stop the attaching nut from sliding down the cable.
Mounted indicator, made a new earth bolt.
Started stripping the box.
Sand blasted the casings.
Ready to lift engine onto kFrame. Just not sure where to grab it from. I'm thinking straps under the sump with bits of wood to spread the load? And a strap between box and motor.
Wish me luck.
Marty
Edited by sibhs, 14 August 2014 - 11:07 PM.
#756 _sunburst73-xu1_
_sunburst73-xu1_
Posted 15 August 2014 - 06:53 AM
Looking awesome Marty.
Well done.
#757 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 15 August 2014 - 07:48 AM
Great job Marty, great job.
#758 308 Sunbird
308 Sunbird
  • 975 posts
  • Name:Stuart
Posted 15 August 2014 - 12:48 PM
Just finished reading the lot after being "tipped off" by a mate,
all I can say is WOW. Well done Marty.
#759 LJGTR6
LJGTR6
  • 309 posts
  • Name:Steve
  • Car:1977 LX SL 4 Door and 1973 LJ 2 Door
Posted 16 August 2014 - 07:36 AM
That engine is pure porn Marty. Beautiful work.
steve
#760 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 16 August 2014 - 04:42 PM
time to make one of these Marty?
57E09367-A8D7-4FE7-A4E8-16C9CD03B7D4_zps
#761 S pack
  • 15,764 posts
Posted 16 August 2014 - 05:05 PM
Hey Marty, you've been spending way too much time on that car, you're nuts have turned blue.  :tease:
BTW, your outrigger bushes are installed the wrong way around.
#762 Potta
Posted 16 August 2014 - 08:29 PM
Motor looks great mate, so does the front end.
It was just sex but now its sex on wheels  :badabing:
Gonna be hard to get that motor in without scratching it but I used a load balancer with a handle on the front so you can tilt the motor forward and back when I pulled the motor from Dave's car.
Attached to chains using head bolts.
As recommended by Bomber.
Lets you manouvere it in or out.
Attached File  IMG_0690 (Small).JPG   89.45K   26 downloads
Attached File  IMG_0692 (Small).JPG   78.8K   25 downloads
Edited by Potta, 16 August 2014 - 08:39 PM.
#763 hanra
  • 11,033 posts
Posted 16 August 2014 - 08:55 PM
Can you do a body drop onto the motor already installed onto the k-frame like us big torana fellas do?
Edited by hanra, 16 August 2014 - 08:56 PM.
#764 Ice
  • 15,221 posts
Posted 16 August 2014 - 09:25 PM
Yes he can that would be the easy option
#765 dattoman
Posted 16 August 2014 - 09:53 PM
So not painting the springs and shocks original colours ?
#766 Potta
Posted 16 August 2014 - 09:54 PM
Ya, sure would especially seeing as everything is already removed from the body.
It will be a bit scary lifting the body but I reckon it would be just as scary if not more to swing the motor over the top of that beautiful paintwork.
#767 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 16 August 2014 - 11:09 PM
Great looking engine Marty, top work.
Cheers Graham .
#768 MODNIZD
MODNIZD
  • 460 posts
  • Name:Phil
  • Car:4 Door LC RB25DET
Posted 17 August 2014 - 10:51 AM
This is the way I prefer to do it. When I do it the other way I think "What if this fell on the nose cone...."
#769 _greg2240_
_greg2240_
Posted 17 August 2014 - 12:11 PM
Marty already said he was going to put the engine on the k frame 1st, then obviously to drop the car over it, that's how I read it anyway.
#770 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 August 2014 - 02:09 PM
Hi Guys,
Gary, yes I've sent a set to Danny.
Well done.
Thanks Dane, satisfying at the moment.
Cheers Jonesy
Hi Stuart, welcome to the build.  Always good reading a start to almost finished thread, instant results.
steve
Hi again Steve,  I reckon the colour will really jump-out once in the engine bay. Cheers
Hi Stinga, not sure what that bolts too, but I didn't want to unbolt any manifolds or head bolts etc. Managed to lift it with strap.
#771 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 August 2014 - 02:12 PM
Hi Dave, blue nuts means they still need tightening.
That bush is in the same way it came from factory. I have a theory that once you turn the bush the other way, as recommended by somebody from GMH in a tech upgrade (probably and apprentice) you have more chance of cracked K-frames. My frame was perfect and I know of others that have the bush my way with no cracks after 40 years. You probably find all the cracked Kframes have the bush the wrong way.  I look at things from a logical perspective and this way makes sense.  :-)
Hi Craig, yeah it scares me more lifting an engine over than lifting the body up. (not that I've ever lifted a front end). I do have that gismo but when removing the engine it was still tight and hitting firewall etc.
Hey Neil, Shocks and springs stay as is, I like the colour combination better than original. The car will look original but it won't at the same time.
Cheers Graham .
Thanks Graham, hopefully another few weeks and it'll be in.
Exactly :-)
Edited by sibhs, 17 August 2014 - 02:12 PM.
#772 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 17 August 2014 - 06:30 PM
i dont have one of them so im just guessing, but possibly the earth screw on the head and the coil bolt?
#773 S pack
  • 15,764 posts
Posted 17 August 2014 - 06:32 PM
The outrigger bushes in mine were installed the way you have them and my brace arms had cracks.
The NOS crossmember I installed around 25 years ago I installed the bushes the correct way around and no cracking to date.
I believe these service bulletins are compiled by GMH Engineers not apprentices.
Totally your choice what you do. Just trying to help.
#774 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 August 2014 - 07:43 PM
I really appreciate your help Dave, just tying to wind-up some discussion I suppose. Might be having second thoughts after another chat today with a member. "Me confused"
#775 S pack
  • 15,764 posts
Posted 17 August 2014 - 07:51 PM
 "Me confused"
How so?
