Well done Marty, looking awesome and the only way to throw your Engine and gearbox in.
Thanks for the encouragement at Toranarama to do it this way Dane.
It really was easy and all done single handed. KFrame to lower chassis had plenty of room, no need for straps to pull in. I'm also glad I have bushes' the way it was made, otherwise the frame would of been stretched to meet chassis, possible causing a crack.
Finished hood lining and started the rear window seals. Note you start and finish under a hinge, then glued together.
Spent a good hour cleaning the gunk out of screen rubber. Then gave it some magic.
Test fitted the stone guard, made some adjustments where the rubber steering boots get close. Now I can weld the bracing in place then paint.
Marty
Edited by sibhs, 26 September 2014 - 09:07 PM.
