Barts 2door LJ
#251 _@milco@_
Posted 05 October 2007 - 11:58 PM
#252 _Bomber Watson_
Posted 06 October 2007 - 04:44 PM
by the looks you will have to take the whole front x member down to get the exhaust out
still looks bloody good mate.
#253
Posted 06 October 2007 - 10:15 PM
Yeah your right unfortunatly but its the way its got to bei take it once the exhaust manifolds are done they wont be leaving the car very often...
couple more progress pics, it dosnt look pretty but i had to do it this way to clear the suspension arm when it swings up.
#254 _Flamenco_
Posted 06 October 2007 - 10:28 PM
#255
Posted 07 October 2007 - 01:08 AM
You could weld 4 extra flanges in just before the 4 to 1 collector so you can unbolt and remove each pipe separately - depends how often you think it will be coming apart.
M@
#256 _Viper_
Posted 07 October 2007 - 02:53 PM
#257
Posted 07 October 2007 - 07:41 PM
I was thinking of using another disc with the hub which sticks out another 16mm
maybe commodore?
#258 _JBird_
Posted 07 October 2007 - 07:50 PM
Datto's kit or Hopper's kit sticks out around there. I've been told commodore offset does the trick.not anymore after i saw what happened to one of the guys here.
maybe commodore?
I can see the walkies in the background. Hot stuff.
BTW what are you going to do for traction ?? lol
#259
Posted 07 October 2007 - 08:22 PM
#260
Posted 07 October 2007 - 08:45 PM
I dont want to fork out too much if its only commo discs i need that would be ok, reason i dont want to fork out too much is that i will upgrade to wilwood or other when cash allows later.
#261 _Viper_
Posted 07 October 2007 - 09:38 PM
#262
Posted 07 October 2007 - 09:42 PM
thats the thing i dont really want the kit for as good as they are, if i can get away with just commo discs i would be happy with that for now.Hoppers kit is $1200 and pushes it out 10mm But I think Dattoman (Neil) might do a kit closer to 1k??
I can get VB/VL disc for around $60 and that would be sweet for now.
http://cgi.ebay.com....1QQcmdZViewItem
Edited by Bart, 07 October 2007 - 09:45 PM.
#264 _lurkin308_
Posted 07 October 2007 - 10:28 PM
cheers caine
#265
Posted 07 October 2007 - 11:05 PM
#266
Posted 08 October 2007 - 12:06 AM
#267
Posted 11 October 2007 - 10:43 PM
#268
Posted 12 October 2007 - 12:26 AM
Awsome work Bart.
#269 _Keithy's_UC_
Posted 12 October 2007 - 09:38 AM
Its gonna be a real job to pull things apart, but hopefully you dont have to do it all that often!!
Keith
#270
Posted 12 October 2007 - 05:00 PM
#271
Posted 12 October 2007 - 07:10 PM
Good question.Just needed to ask what are you going to do about heat build up and how close to the tyres is the manifold going to be
Firstly the tyres wont be too close untill i steer and the car leans over (compressing the suspension bringing the wheel up closer to the manifold) and i wont be constanly steering.
Some airflow as the car is moving will reduce the heat somewhat and some thermal rap or ceramic coating should be enough to keep the heat under control.
The clearance is approx half inch from the manifold lock to lock.
Edited by Bart, 12 October 2007 - 07:13 PM.
#272
Posted 13 October 2007 - 09:59 PM
Basically I cut out an inspection lid drilled and taped the mounting holes and used stainless Allen key head screws. This is to allow me to stuff foam into the tank.
Also a fuel sender lid.
Large inspection lid
Fuel sender lid
#273
Posted 14 October 2007 - 10:47 AM
#274 _Bomber Watson_
Posted 14 October 2007 - 12:22 PM
#275
Posted 16 October 2007 - 07:19 PM
Basically you dont want to be doing a doughnut for to long (just kidding)Good question.
cant wait to see her finished
