Hey Matt if youre going to do it and if you get a chance elongate the mounting holes so you can get more caster
This is what i wanted to do, may do later. Also an idea may be use tubular upper suspension with bushed rod end or spherical rod end, if you use rod ended upper arms be aware of the diameter of the bush/spherical bearing as it may be different in size compared to regular bushes, you wouldnt want to machine the shaft too much or too little, Anyway im sure you can work all that stuff out.
Also i almost forgot, if you can be bothered doing the research perhaps find out if you can use titanium rod as the amount you would need wouldnt be over the top in price, just find out what grade is suitable, this would make it light weight and while youre there make up some titanium tube upper suspension arms
but seriously if you can go for it.
These guys could probably help you
http://www.aerospace...eriorFrame.html
Edited by Bart, 05 November 2007 - 09:58 PM.
