Barts 2door LJ
517 replies to this topic
#401 _UNVSM8_
_UNVSM8_
Posted 22 September 2008 - 05:08 PM
i too have red back mufflers and so do a heap of my mates and never had a problem and they sound good too
#402 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 23 September 2008 - 12:26 PM
Cool. I�m still thinking about it, I had a look at the Edelbrock mufflers.
I have an issue with my gearbox not going into reverse properly; I think the clutch is not disengaging properly, may have to adjust the clutch pedal linkage.
#403 orangeLJ
Posted 23 September 2008 - 01:37 PM
Bart, we are on the central coast (Long Jetty)
#404 _JUNK3R HR_
_JUNK3R HR_
Posted 23 September 2008 - 01:45 PM
i was running a luky 16' turbo muffler behind the 192 in the ute sounded very nice
#405 orangeLJ
Posted 23 September 2008 - 01:48 PM
wouldnt touch lukey with a ten foot pole.
Thats just me though....
#406 _JUNK3R HR_
_JUNK3R HR_
Posted 23 September 2008 - 01:50 PM
the only proble i have found with it was that it was to quiet on idle but get over 3000rpm and it was a bit loud
#407 orangeLJ
Posted 23 September 2008 - 02:16 PM
IMO they are just crappy quality these days.
#408 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 23 September 2008 - 04:12 PM
So these Redbacks will be ok for a twin turbo setup?
Also I have to run twin cats and it has to pass emmision testing.
Also has to pass noise testing.
What would the mufflers and cats be worth? I may be heading down to lovely Long Jetty this Sat and I may need a X pipe.
Im using 3" pipe
Edited by Bart, 23 September 2008 - 04:17 PM.
#409 orangeLJ
Posted 23 September 2008 - 04:27 PM
The noise testing is going to be the biggest drama, but it can be overcome (benefit I suppose is that you are running turbos, which will quiten the exhaust note slightly)
for decent metal centre cats you are looking at 400ish each cat (so 800 for two)
As for mufflers, you could run straight throughs, but I doubt they would do too much to pass noise limits, so offset centre mufflers would be the go (still straight through but diagonal) they will be 200-220 a muffler in 3"diameter.
If you arent running a STD tank then you can run twin pipes the full length, Im getting a price on one of the new X flow crossovers from pacemaker (supposed to be the best thing out at the moment) I should have one by tomorrow.
more then likely you will need to run 4 mufflers though (two per side) a 12 inch hotdog on either side, and come offset centre mufflers at the rear should be reasonably enough to quiten it down.
#410 _Bomber Watson_
Posted 23 September 2008 - 05:43 PM
They recon Hooker Aero chamber mufflers are a fairly good thing.
http://store.summitr...mp;autoview=sku
#411 orangeLJ
Posted 24 September 2008 - 09:48 AM
They are also worth a fair bit too bomber.
#412 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 24 September 2008 - 12:11 PM
I was speaking to a guy in Belmore, hes alot closer to me, he sells Redback stuff also, but yeah still thinking about which way to go.
Did an oil flush and change, time to mount the turbos tonight hopfully, then maybe not as i have to fabricate some stainless steel tubing for one of the oil lines whch goes to the oil filter, at the moment im using rubber braide but a little risky as its near the exhaust manifolds.
#413 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 24 September 2008 - 03:00 PM
Anyone ever use ACE radiators?
They seem to be a little on the cheap side compared to PWR, but that would be ok as long as theyre good.
#414 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 24 September 2008 - 05:04 PM
At the moment I have an aluminium Skyline radiator but its pretty wide and fouling on the air filters on the turbos.
So im looking at getting a good radiator, preferably aluminium.
Edited by Bart, 24 September 2008 - 05:05 PM.
#415 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 25 September 2008 - 01:28 PM
http://s50.photobuck...nt=MOV02494.flv
Edited by Bart, 25 September 2008 - 01:40 PM.
#416 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 26 September 2008 - 12:31 PM
Hey Bomber, i saw some hookers at Rare Spares for $130 in 2.5"? (approx) I didnt like the look of the welds but then its nder the car i know but still the welds should look nicer i believe.
#417 MODNIZD
MODNIZD
  • 460 posts
  • Name:Phil
  • Car:4 Door LC RB25DET
Posted 26 September 2008 - 06:29 PM
Awesome! Its running... I have been hanging to see a video like that. You must be happy.
#418 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 October 2008 - 02:52 PM
Thanks mate im very happy.
Still have to bol ton the turbos.
Hey has anyone used ACE radiators?
Or used a radiator not as expensive as PWR etc, just wondering if its worth spending the extra $$ for PWR or similar
#419 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 November 2008 - 02:16 PM
My PC is now working. okish
Bolted turbos on is sounds nicer
Nexton the list:
exhaust
Radiator
Bit of wiring to get all the dash lights going.
Engineer certification
Rego
Edited by Bart, 02 November 2008 - 02:17 PM.
#420 _LJ355_
_LJ355_
Posted 02 November 2008 - 02:26 PM
Hey bart spend the extra go the PWR :spoton:
#421 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 November 2008 - 07:18 PM
I would love to but $800 is a little steep, im sure its worth it but a little too much for me.
#422 _BCR42Y_
_BCR42Y_
Posted 02 November 2008 - 07:22 PM
A friend of mine had Micks Metalcraft make him a custom radiator for the Mini about 6 years ago and he hasn't had a problem with it, I do recall though that he paid a fair bit for it as it was a custom one off, you could get a price from them?
#423 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 November 2008 - 07:32 PM
I got him to make me a sump and it was way off the dimmensions i gave him, i even gave him a template but still went way off. Also the amount he charged me was way off also.
I wouldnt pay him to make my lunch. But e does do good work and welds good just cant stick to dimmensions and $$$
#424 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 21 November 2008 - 10:06 PM
Some Hooker pics
My new radiator
Turbo with plumbing installed, all ready to go
RB electric scavenge pump
Edited by Bart, 21 November 2008 - 10:12 PM.
#425 _studricho_
_studricho_
Posted 21 November 2008 - 10:33 PM
Are you concerned about the heat near that brake line?
