Barts 2door LJ
517 replies to this topic
#51 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 15 February 2006 - 10:55 PM
I was thinking of welding in GTR flutes in my lj S, but im not sure what position they should be in the gaurd.
Could someone let me know?
Thanks guys
#52 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 19 March 2006 - 04:39 PM
Little bit of progress, the inner and outer sills are off, well the inner sills are semi off, and door pillars are off ready for sand blasting, FINALLY. The VL motor and box is out and the HJ Kingswood 253 will go in with dummy turbo :tease:
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P3191321.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P3191322.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P3191324.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P3191327.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P3191330.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P3191332.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
Bits and Pieces for sand blasting, inner and outer pillar
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P3191333.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
Edited by Bart, 19 March 2006 - 04:43 PM.
#53 _jap-xu1_
_jap-xu1_
Posted 19 March 2006 - 04:49 PM
are you replacing the rb30 with a 253?
#54 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 19 March 2006 - 05:04 PM
As stupid as it sounds yes, but temporarily. There is a reason for this madness, and that is to get it regoed/engineered with a 4.2ltr turbo ASAP before the RTA changes the modification rules.
The next step will be to replace the 253T with a 4.1ltr turbo Nissan V8 (coming in a shipping container from Japan as we speak, arrive in April/ May) which will take considerably longer to achieve, because its not a straight forward fit, and by then the RTA rules would have changed but it wouldn�t matter as the Torana will be regoed/engineered with 4.2T before the rule change.
Long story short, trying to dodge the RTA legally. Hopefully. :rolleyes:
#55 _NVMYLH_
_NVMYLH_
Posted 21 March 2006 - 08:21 PM
Hey Bart, your project is looking good! How did you go about the EFI fuel pumps? Did you use the standard internal/external VL setup? I'm in the process of modifying my spare tank to accept a standard VL internal pump. What we're doing is using a pick-up/sender assembly out of a vl, but cutting the sender off, and mounting the pump straight off the mounting plate. (like cutting the pickup tube to about 1" long, and having the pump go straight off that). Then we're gonna mount that in from the top of the tank, and leave the standard torana pickup and sender untouched. But we are also going to use a 1.8Lt surge tank mounted in the boot, and have the 910 pump running off that. I'll try and get some photos for you asap. Goodluck dodging the RTA!!! Hope i can get my thing engineered!!!!!
#56 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 22 March 2006 - 10:30 PM
I used the original pick up, the Holley Blue lifted the fuel, pumped it into the surge tank, i used a VL pump from the surge tank to the engine. I used the original fuel line as the return line, the line going to the engine is stainless steel flexable.
#57 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 April 2006 - 07:06 PM
sand blasted
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P3291350.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
Inner sill sand blasted, note the front section of the inner sill is cut off as it was too badly rusted, in the previous pics i made up this new front section
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P3291349.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
new front section welded in
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P4011355.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
new front section before it was sand blasted
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/Innersillpatchpanel2.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
outer door pillar rusted section cut out and new one made and welded in
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P4021363.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
outer door pillar is also welded onto the sill as i cut it off before
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P4021362.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
sill end rounded off (alot of work to get that right)
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P4021361.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
#58 LC69GTR
LC69GTR
  • 2,761 posts
Posted 02 April 2006 - 08:13 PM
When can you do mines Bart as thats the type of good job i want keep it up looking good
#59 _dave720gtr_
_dave720gtr_
Posted 02 April 2006 - 08:23 PM
bart thats top workmanship you are really geting stuck in to it, those sill ends are tricky looks like my one but i put the original hole in the end and bung so you can rust proof it later
theres a lot of long nights dilling grinding cut fingers blood" huurr good work
#60 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 April 2006 - 08:53 PM
thanks guys appreiciate the compliments.
shit i forgot about the hole in the rounded section, i havnt welded the sill on yet so i can do it a little later.
When the weld thru primer and cavity wax arrives from Wurth i will weld the sill on and complete one side.
Yes alot of late nights but thats ok as that is when my brain works well, sort of :blink: , if only i had a workshop out in the sticks with nobody to keep awake i would be in heaven :D hehehe
hopfully next weekend i will get most of the other sill done fingers crossed.
thanks again guys :spoton:
#61 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 April 2006 - 10:26 PM
https://cache.gmh-to...ar/P4021371.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P4021372.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/P4021373.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
#62 _LHcruzn_
_LHcruzn_
Posted 03 April 2006 - 08:53 AM
Looking the good's mate!!! fancy a trip to melbourne to help with the monaro?? hehe ;)
#63 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 03 April 2006 - 07:42 PM
id love to work on a Monaro :spoton: one day ill buy one like Tinys :spoton:
#64 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 03 April 2006 - 07:50 PM
you can come work on mine any day bart ;)
THe work your doing to yours is top notch mate! Ive gotto do some to the monaro sooner rather than later.. and ive got an SLR that needs quite alot done to it too!! hehehe
Cheers mate :) Your doing a top job! :spoton:
#65 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 07 April 2006 - 08:30 PM
thanks Tiny, this weekend ill be stuck into it :spoton: hopfully nothing else comes up :furious:
#66 gtrboyy
gtrboyy
  • 3,207 posts
Posted 08 April 2006 - 01:39 AM
Damn,I haven't even touched my car in a few weeks.How's it going with the engineering hassles,any news?
#67 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 08 April 2006 - 02:14 AM
naa mate havnt got to that stage yet, if you remember a few months back i found out the rules were going to change just when i chopped out the sills and the front end was off, now its a race against time to weld it up and prime it up for rego and engineer with 253 dummy turbo. :rolleyes: :rolleyes:
last i heard the rules havnt changed yet :furious:
#68 gtrboyy
gtrboyy
  • 3,207 posts
Posted 08 April 2006 - 03:13 PM
I haven't heard anything either,I've finally got some cash saved up to get back into but I'm not sure whether to get what I have passed or to get a full rollcage put in if I want to step up & still race at wsid as well drive the car on the street.Ive always wanted to put a vortech on mine,just not sure about the timeframe,not to mention those damn rule changes.
#69 _user asked to be removed_
Posted 09 April 2006 - 02:04 PM
I cant wait to see this car finished.... It will look awsome
#70 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 09 April 2006 - 02:09 PM
just get it engineered as is, then if you want, get the roll cage later, otherwise your whole car will be illegal :cry: :cry: and that would be a damn shame mate
Today im upto the rear lower window sill as it was rusted out and i just welded the new rare spares one in, today im cleaning it up. :spoton:
then hopfully get other sill started
#71 gtrboyy
gtrboyy
  • 3,207 posts
Posted 09 April 2006 - 05:41 PM
I'll have a chat to an engineer first.I've just found a 253/m20 kingswood so I might end up going the same route as you but I should have it planned out by end of next week after speaking to an engineer.
#72 _PSI_
_PSI_
Posted 09 April 2006 - 06:06 PM
Bart, I have a few words to say, "oh this brings back the memories for me"
Well done mate!! Very impressed and I will be watching this thread for updates. You can work on my girl anytime. :clap:
Cheers mate.
PSI
#73 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 10 April 2006 - 07:08 PM
Hey PSI thanks mate, "work on your girl" is that a job offer?? :tease:
Ill have some updates shortly, i just hope to have it regestered soonish before the RTA change engine capacity rules. :furious:
#74 mrlctorana
mrlctorana
  • 572 posts
Posted 10 April 2006 - 07:35 PM
Hey Bart, Been watching this thread since day one, and glad to see updates are a pretty regular thing. Your definately into it in a big way and by the way she's coming along she's gunna be one hell of a nice car, Good on ya mate, keep us posted.
Les
#75 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 10 April 2006 - 10:49 PM
hey thanks for all your kind words mrlctorana/guys :spoton: :D
