Barts 2door LJ
517 replies to this topic
#151 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 19 November 2006 - 09:33 PM
Where is Steve Janda situated?
Going by the carpoint/street machine site.
Steven Janda
9541 1500 and hes located at illawong.
thanks guys
that should be it, you will find him quite good i think as when i got my car engineered with him last time just wanted upgraded brakes and a good diff for the extra HP, made sure seats and seat belts were secure etc, prety general stuff.
#152 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 December 2006 - 11:37 PM
Engine mounts made, need coat of paint, might go mat black for now.
Need an external oil pick up, just got to figure out where the other oil galery is on the pump to suck the oil.
My Webpage
My Webpage
My Webpage
My Webpage
Edited by Bart, 02 December 2006 - 11:43 PM.
#153 _LHoon_
_LHoon_
Posted 04 December 2006 - 05:46 PM
Good to see more progress mate!
Those engine mounts look good. Its basically the same kind of setup we're using on the 1UZ.
Keep the progress coming! :clap:
#154 Com_VC
Com_VC
  • 411 posts
Posted 25 December 2006 - 12:20 PM
Hey mate what is the ID of the pipe that the bush goes into? Also OD of the bush and do you happen to know what ford it came from?
Looks like a neat way to do engine mounts.
#155 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 25 December 2006 - 04:30 PM
ill find out, but if youre near seven hills sydney Rod Andrews race cars sell all the bits :spoton:
#156 Com_VC
Com_VC
  • 411 posts
Posted 25 December 2006 - 05:44 PM
thanks. unfortunatly i'm in victoria.
#157 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 29 December 2006 - 10:26 PM
havnt forgotten about you com vc
have to have a look yet. :spoton:
#158 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 29 December 2006 - 11:59 PM
Cam covers have been cut, i made up some patches to be welded in. This is to make more clearance from the chassis rails.
My Webpage
My Webpage
VH41 looking more at home these days :spoton:
Its actually bolted in the cross member with the new engine mounts.
My Webpage
https://cache.gmh-to...IMG]]My Webpage
My Webpage
My Webpage
Edited by Bart, 30 December 2006 - 12:01 AM.
#159 TerrA LX
Posted 30 December 2006 - 12:10 AM
talk about shoe horn.
top work mate :spoton:
#160 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 30 December 2006 - 08:08 AM
its hard to see from the pics but there is clearance from the chassis rails. :spoton:
#161 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 07 January 2007 - 10:10 PM
Sincerest apology for not replying sooner, I haven�t had much time to have a good look at the engine mounts for you until now.
I.D. of the pipe is 5.5cm and the wall thickness is 3.5mm. O.D. is 6.3cm.
The engine mount is Ford, it is the full rubber type as apposed to the rubber with the holes in it, (the holey ones were to make a softer ride).
The Part # FA7334 and then on the opposite side says L9, I don�t know what that means.
If you are going to do the same thing i suggest buying the engine mount first and going off its measurements as it must be a press fit. :spoton:
My Webpage
Edited by Bart, 07 January 2007 - 10:12 PM.
#162 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 10 February 2007 - 11:16 PM
little update Sills in etch and primer
My Webpage
My Webpage
My Webpage
At the moment im making the front suspension upper mounting shafts out of 4340 round bar, ill post pics of it soon as iv nearly finished one, its really hard shit to turn in a lathe.
Also made up some spacers to clamp down on the cam covers while i get them welded.
#163 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 10 February 2007 - 11:43 PM
My Webpage
My Webpage
#164 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 11 February 2007 - 12:02 AM
I dunno if this has been covered before, but what colour is gunna be applied over these super smooth panels?
RIM
#165 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 11 February 2007 - 12:35 PM
It will be the same colour as the rest of the car, i will attempt to paint it myself, in a couple of years i will have the whole car striped and sand blasted and a colour change will definitly happen. At this stage i am only completing it at a level to pass engineers and rego so all the things i originally wanted to do wont happen until after i get it engineeded and regoed as you prob know the RTA want tp restrict the engine capacity rules so first thing is first. :D
#166 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 11 February 2007 - 07:49 PM
Suspension cross shaft nearly ready, needs to be millled flat.
Unfortunatly i dont own a mill yet so i need to get someone to do for me.
The material is 4340 chrome molly steel, this stuff is really hard to machine as i discovered but machines up realy nice.
My Webpage
My Webpage
My Webpage
Edited by Bart, 11 February 2007 - 07:51 PM.
#167 arrimar
arrimar
  • 3,134 posts
Posted 11 February 2007 - 08:45 PM
measure twice cut once. fantastic to see someone who isnt afraid to grab a grinder and have a go. first time ive read your pages and im glad i did. thank you for so many pictures.
my only suggestion would be to not run your mig through a double adapter and a power box. that may help the machine run smoother and certainly prevent a meltdown. all that great work i'd hate to see that old rope let go too. a short one tonne sling costs under $20 bucks and is a sound investment.
best wishes for your dealings with the rta,hope it all goes your way.
#168 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 11 February 2007 - 09:41 PM
Thaks for your kind words and suggestions, that rope is proven but i take your point, iv been meaning to make a cross bar and chain to lift the motor but not enough time.
I may just get that sling.
#169 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 11 February 2007 - 10:30 PM
Forgot about the fire wall
My Webpage
My Webpage
Chassis rail mod, this was required because of the timing chain sprokets.
My Webpage
#170 arrimar
arrimar
  • 3,134 posts
Posted 11 February 2007 - 11:27 PM
is the problem with the welder when you start each run or during the run?
it will add time to the job but will allow the panels to cool a bit anyway if you cut the burnt wire from your handpiece before each run.
your choice of gas is correct however a mix without the black band(oxygen) will be a cooler mix and may help with penetration/blow thru problems.
#171 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 01 March 2007 - 10:29 PM
Some sump pics, i had it modified, at the momonet im still thinking how i should plumb an external oil pick up, unfortunatly the original pickup point is where the flat part of the sump is now, so i may have to drill a hole through the flat part of the sump and poke a threaded tube through it and seal it off with a nut, then screw on/attach an elbo on it then to the external pich up.
My Webpage
My Webpage
My Webpage
My Webpage
#172 _fat-torrie_
_fat-torrie_
Posted 01 March 2007 - 11:04 PM
holy toshiba.
nice work mate. love the fabrication process of the whole project, cant wait tll shes on the road. :clap:
Chees
Troy
#173 _NRV051_
_NRV051_
Posted 02 March 2007 - 06:27 AM
Bart is your last name FOOSE or TREPANIER by any chance. Surly you are the Australian god of car crafting. So when are you visiting Brisbane next. I have an EH wagon which needs some tricky rust repairs doing.
Top work keep up the good effort and keep the pics coming. You are a true legend around here.
Gav
#174 _Rob 5000_
_Rob 5000_
Posted 02 March 2007 - 07:26 AM
Holy Cow BartMan this thread should be pinned. :D
#175 _noslx_
_noslx_
Posted 02 March 2007 - 09:48 AM
just read the full series start to now what an effort and a fantastic job ....well done makes me all inspired to attack mine once again cheers and keep up the good work
