Replacement Fuse Box?
Posted 29 January 2013 - 04:16 PM
Does anyone know if you can get replacement fuse boxes? I was just thinking of replacing the old fuse box with one utilising the modern blade fuses. So i wondered if you could buy one over the counter or maybe use one from a wrecked vehicle.
Cheers,
Scott.
Posted 29 January 2013 - 05:42 PM
just a straight oblong plastic box but don't have a common rail for power, all individual in/out fuses
Posted 29 January 2013 - 06:32 PM
_hutch_
Posted 29 January 2013 - 06:43 PM
Phillip
Posted 29 January 2013 - 10:40 PM
http://www.ebay.com....=item4d07a9d06b
or this
http://www.ebay.com....=item43b36d0077
or the mini type fuses
http://www.ebay.com....=item35bf6de775
or if you have a few extra bells and whistles :-)
http://www.ebay.com....=item3f205bd286
Posted 29 January 2013 - 10:42 PM
What do you not like about glass fuses, that makes you want to change to a blade fuse box?
Posted 29 January 2013 - 11:15 PM
Fuse Boxes at Summit Racing
Edited by ls2lxhatch, 29 January 2013 - 11:16 PM.
Posted 30 January 2013 - 06:50 PM
http://www.ebay.com....1#ht_2700wt_932
Posted 30 January 2013 - 06:57 PM
If it aint broke... Why fix it?
Because I habit of messing around with things and have them end up worse than when I started!!
Actually it was just a simple reason. I was somewhere the other day and had a fuse blow and the nearest store didn't have any glass ones. I then thought it might make a neat rainy day project.
_434LX_
Posted 01 February 2013 - 10:22 AM
Part # FBX-N54431. Available from Alanco or anyone else that deals with Narva.
But if you want to replace the whole fuse box, I would be looking at retro fitting a painless or other wiring kit.
To be honest, make your rainy day project finding glass fuses and chuck a bag of them in your glove box. There's nothing wrong with them.
Posted 01 February 2013 - 10:45 AM
Needed a Glass Fuse one Day and could not get hold of one, but then I saw a Beer cap and the rest is History.
So the Beer cap makes a great tempory Fuse if needed. Dave I
Posted 01 February 2013 - 01:02 PM
Posted 01 February 2013 - 05:19 PM
Grant..
Posted 01 February 2013 - 06:53 PM
Posted 01 February 2013 - 08:22 PM
Posted 02 February 2013 - 08:43 AM
_Turk32_
Posted 18 February 2013 - 11:32 AM
Posted 25 February 2013 - 04:36 PM
I bought a baintech one from battery world. 12 way and mounted it in the glovebox. $69 I think it was. They also sell them on ebay. 1 main positive feed and 1main negative feed with 12 individual circuits max 30 amps each.
Posted 25 February 2013 - 08:08 PM
Main advantage I can see to the mini type fuses is you can replace them with mini CBs and not have to worry about replacing them, just reset if they pop.
The mini circuit breakers sound like a good idea, are they easily available?
Posted 25 February 2013 - 08:37 PM
Anywhere that sells Hella products should be able to get them.
http://db.hella.com....ssories#Circuit Breakers
#21
Posted 25 February 2013 - 08:42 PM
Thanks for the link.
