Acrylic Lacquer Primer spliting?
6 replies to this topic
#1 _JohnUC_
_JohnUC_
Posted 30 January 2013 - 03:05 PM
Went to put my bay in acrylic lacquer primer today after spraying 1k etch. Sanded the 1k etch with 800 grit (had been dry at least 3 days) blew all dust off with water trapped air and then wiped well with wax and grease remover. See pics for what happened. Any ideas?
#2 _Quagmire_
_Quagmire_
Posted 30 January 2013 - 03:37 PM
it's reacted to the previous paint..or your prep work is not spot on
you did wipe the wax and grease remover (prepsol) off with a clean dry rag?
not much you can do but sand back those areas to metal and go again
just a tip i normally run the hose or a watering can over the panel after rubbing and before i dry/prepsol
Edited by Quagmire, 30 January 2013 - 03:38 PM.
#3 71xu1
71xu1
    Dave
  • 1,270 posts
  • Car:LC GTR XU1
Posted 30 January 2013 - 06:19 PM
What you have there is generally caused from over thinning and too heavy an application.
Cheers Dave
#4 _Bomber Watson_
Posted 30 January 2013 - 07:11 PM
Agreed Dave.
To hard to fast and possibly to hot.
#5 _Quagmire_
_Quagmire_
Posted 01 February 2013 - 03:05 AM
Cheers Dave
the solution is the same :)
#6 _Quagmire_
_Quagmire_
Posted 01 February 2013 - 04:17 AM
http://www.roadkillc...bleshooting.asp
#7 _JohnUC_
_JohnUC_
Posted 01 February 2013 - 01:28 PM
Cheers guys, I think it was from over thinning, reduced ratio and sanded back and sprayed again and all good.
