Need help in choosing the right products
_chev400_
Posted 30 January 2013 - 03:52 PM
4 litres of high build filler.... Question is, which type? I'm painting acrylic, whats the pros and cons of 2k vs 1k?
4 litres of primer surfacer.... Any tips?
4 litres of black.... Can anyone name any good deep gloss black Colours from spies hecker?
4 litres of clear.... Suggestions?
20 litres of thinners and also what's the other thinners you use with colour and clear? I'm sure my mate use a different thinner type for those
Im off to the paint shop over the weekend so hope to get it all in one hit
Any help greatly appreciated, cheers guys
_Quagmire_
Posted 30 January 2013 - 04:12 PM
general purpose thinners are fine with primers
but if your buying 20 litres just use that
gun wash to clean out your guns is a good investment too
spies hecker/ppg(protech) or any of the good name brands are fine
stay away from motospray/hi chem
just comes down to personal preference really
_chev400_
Posted 30 January 2013 - 04:22 PM
_chev400_
Posted 31 January 2013 - 07:10 PM
Posted 31 January 2013 - 08:27 PM
Tinters are what puts color in your paint. Adding more will change the color, not give it a "deeper look"
Apart from that, you want to use spies hecker, so buy all the above products in spies hecker and go for broke.
If your going a straight black (if you want black as black get Jet black) then you will not need a clear, but you can apply one if you wish to be forever trying to polish out fine scratches.
I dont really see anything else that needs answering that hasnt been covered 100 times recently in this very section of this very forum?
Posted 31 January 2013 - 08:40 PM
_chev400_
Posted 31 January 2013 - 09:55 PM
Posted 31 January 2013 - 10:01 PM
He used to work the counter, A1 service there, just walk up and tell them what you need and they will sort you straight.
_chev400_
Posted 31 January 2013 - 10:32 PM
Posted 31 January 2013 - 10:35 PM
IMO find a supplier that deals with local panel shops day in day out, no offence but a guy selling spare parts all day can only know so much about a paint product.
Posted 31 January 2013 - 10:38 PM
Edited by TerrA LX, 31 January 2013 - 10:39 PM.
Posted 31 January 2013 - 10:41 PM
Posted 31 January 2013 - 10:47 PM
Fantastic help and price on their own products.
They also run a one day crash course that is free (but you have to book), still includes BBQ lunch and discount offer AFAIK.
Next one is Sat Feb 9th.
Edited by TerrA LX, 31 January 2013 - 10:49 PM.
_chev400_
Posted 31 January 2013 - 11:00 PM
Posted 31 January 2013 - 11:11 PM
If you have a gunner who specifies spies heck then stick with it.
Edited by TerrA LX, 31 January 2013 - 11:11 PM.
_Quagmire_
Posted 01 February 2013 - 03:03 AM
_chev400_
Posted 01 February 2013 - 09:14 AM
by the way it's "SPIES HECKER"
does anyone recommend House of kolour? are they much more expensive? are the same basic materials used?
Posted 01 February 2013 - 11:40 AM
Mixing ratios may vary slightly buy you always follow the manufactures recommendation with these kind of things.
FWIW undercoats/hi fills etc vary slightly from brand to brand, one not necessarily being better than the other, just formulated to achieve different results, top coats are all the same, to be honest when it comes to spraying and paint in my opinion it is 5% product and 95% the guy behind the gun.
_chev400_
Posted 01 February 2013 - 01:49 PM
i did paint my last car which was a supra but it was only rubbed back and flow coated, i guess time will tell..........
Posted 01 February 2013 - 07:10 PM
Personally i use Protec, and always get exceptional results...
_chev400_
Posted 01 February 2013 - 08:00 PM
#22
_chev400_
Posted 01 February 2013 - 08:04 PM
#23
Posted 01 February 2013 - 09:35 PM
First time i painted my LJ, this is acrylic, did it when i was 15, long before i was the knowital trade qualified painter type i am now, in protec. This was done under a gum tree in the back yard.
Now re application, the way i sprayed it in that case was just lay everything on cause i didnt know any better.
If i was to do it again in acylic i'd go the latter method you mention. Dont sand between base and clear, but a bit of blocking here and there doesnt hurt. Makes the finish that much more special. Theres a reason guys charge 15k to do an acrylic job, and thats after the car is prepped ready for a prepsol mask and tack. Its because of teh time in spraying and blocking.
Good finish, lay everything on, color till hiding (no shadows) then clear till you think you have enough to buff.
Unreal finish, take your time and block between stages.
I agree dont sand before clear, perhaps your not understanding that properly. You should nto put down the color with a metallic, then sand, then clear, this will expose the aluminium fleck to much and make the color totally different. You are wshing to spray in black, so although i wish you would totally forget about a clear, if you really must put a clear coat on then you can sand that before clear, so long as its uniform.
Cheerrs.
Edited by Bomber Watson, 01 February 2013 - 09:36 PM.
#24
_chev400_
Posted 01 February 2013 - 10:34 PM
Another quickie......... I have a 1.4 tip gravity fed, I know that's ok for the base but can I get away with 1.4 for applying the filler and the surfacer? I was hoping I can or Am i going to have to buy another gun? If so can it be a cheapie? As its under the base.
Posted 01 February 2013 - 10:48 PM
Metallics only turn out funny if your useless. The car in the pick above is a pearl metalic and i was 15, looked orright, so you gotta be real useless.
1.4 is no good for acrylic, get a 1.8.
Cheapies are ok if you only wanna do one car.
