Edited by pocock, 01 February 2013 - 11:03 PM.
Need help in choosing the right products
#26
_pocock_
Posted 01 February 2013 - 11:02 PM
#27
_chev400_
Posted 02 February 2013 - 11:23 AM
#28
_Quagmire_
Posted 02 February 2013 - 12:03 PM
black is the hardest colour to spray/prepOk I did some research on some single stage paint and I have to say WOW!!! I seen some great jobs out there, I will deffo give it a trial on test panel, I have heard pros and cons to using ss v's bc/cc, but for 3 main reasons that it's going to be black, its better for beginners, and the car won't be a daily driver so I will give it a crack, question is now, what type??? Is acrylic the same shit as paint with a hardner etc? 2pack? And judging by a lot of pics I'm not going to cheap out on paint quality, the best pics I seen were with house of kolor and ppg etc, also what are you're thoughts on clearing over ss? As I seen a guy do this and it looked amazing, cheers mate
it's like been naked....every blemish is exposed
if you insist on doing black yourself i'd advise a acyrlic job
just because if you are not happy with your work
then it is easier to repaint/repair than 2k
#29
_chev400_
Posted 02 February 2013 - 02:17 PM
Ok so looks like I'm going to trial single stage acrylic, I know this might be a silly question but want to be sure, with single stage the same prior process applies? Primer fill and surfacer then colour?
#30
Posted 02 February 2013 - 02:38 PM
#31
_chev400_
Posted 02 February 2013 - 02:59 PM
#32
Posted 02 February 2013 - 05:04 PM
Black is pretty easy to paint, the prep work is the hard part.
If you want a hard colour to spray try a flip flop.
#33
_chev400_
Posted 06 February 2013 - 07:18 PM
#34
Posted 06 February 2013 - 07:38 PM
#35
_chev400_
Posted 06 February 2013 - 07:56 PM
#36
Posted 06 February 2013 - 07:58 PM
Polyester, U pol hot shot or dolphin glaze are good.
Yeah, I use these no problems, AFKI it doesn't even need priming when used under 2k top coats.
#37
Posted 06 February 2013 - 08:29 PM
#38
_chev400_
Posted 10 February 2013 - 04:29 PM
Just to add: it was approx 25 degrees and approx 55% humidity, cheers
#39
_Quagmire_
Posted 10 February 2013 - 05:25 PM
you using it as a filler yeah?Ok I primed up a panel today with acrylic primer filler (3 coats) it came out pretty rough like sand paper, it states on the can to apply straight from the can without thinning, I used a 1.8 tip but I think it may have been too thick cause I had to keep opening up the fan control (ended up opening fully) to get a hand span width from a hand span away from the panel, should I ignore what it says on the tin and thin it out 10-20% and go for another shoot and see if it improves? Or maybe change it to a 2.5 tip?
if so you can leave it and sand then thin the rest and use it as a primer...
if it's a primer you want thin it up to 50%
i have added thinners to 10-20% but it didn't fill as well sprayed a lot nicer but
a 2.0 tip may help but i tend to use upol for my pin holes
Edited by Quagmire, 10 February 2013 - 05:27 PM.
#40
_chev400_
Posted 10 February 2013 - 06:31 PM
#41
Posted 11 February 2013 - 07:38 AM
IMO throw some thinners it it and don't built it too high with each coat.
#42
_chev400_
Posted 11 February 2013 - 11:53 AM
#43
_Quagmire_
Posted 11 February 2013 - 03:00 PM
#44
_chev400_
Posted 11 February 2013 - 04:01 PM
#45
Posted 12 February 2013 - 01:04 AM
I have found enamel (especially in those fiddly bit's cans, is the worst thing to use as guide coat as it has to be rubbed harder to show up imperfections that you can end up chopping out before you get a chance to pick them up.
FWIW when you know what to look for you don't even need guide coat half the time, especially with dry sanding.
#46
_chev400_
Posted 12 February 2013 - 03:19 PM
#47
Posted 12 February 2013 - 07:36 PM
#48
_chev400_
Posted 18 February 2013 - 07:02 PM
#49
_chev400_
Posted 18 February 2013 - 07:04 PM
#50
_chev400_
Posted 18 February 2013 - 07:07 PM
