Anything you can see in the undercoat will be visible in the top coat.
Need help in choosing the right products
#51
Posted 18 February 2013 - 07:46 PM
#52
Posted 18 February 2013 - 07:56 PM
A solid acrylic does hide a lot though :-)
#53
Posted 18 February 2013 - 08:00 PM
^ agree, if the scratches are fine, by the time you hammer 7 or 8 top coats on and chop out 3 or 4 after cure time.
#54
_chev400_
Posted 18 February 2013 - 08:13 PM
#55
Posted 18 February 2013 - 08:27 PM
Sometimes I go 800 if i am not happy,
What does the instructions recommend?
Is ANYTHING showing up in a second guide coat?
Are you using a hard block?
Have you let the primer/filler/surfacer cure correctly before sanding?
All I can say is trial a test panel if your not sure, practice practice practice.
Edited by TerrA LX, 18 February 2013 - 08:29 PM.
#56
_chev400_
Posted 18 February 2013 - 08:33 PM
#57
Posted 18 February 2013 - 08:36 PM
Either you have used black undercoat or there is no pic there sorry, can't see it.
#58
_chev400_
Posted 18 February 2013 - 08:37 PM
#59
FYI don't be scared to re use the guide coat as you sand, at all times if possible I prefer dry sanding.
#60
_chev400_
Posted 18 February 2013 - 08:38 PM
#61
Posted 18 February 2013 - 08:39 PM
Can't help with the pic sorry, I use a lap top and photobucket (ie upload/store the photo on line then post a link here).
#62
_chev400_
Posted 18 February 2013 - 08:42 PM
http://s1131.beta.ph.../image.jpg.html
#63
#64
_chev400_
#65
Posted 18 February 2013 - 08:46 PM
Ah I see it now.
Oh fark, they look like train tracks, does it wipe off or are they permanent?
I sand in a cross hatch pattern.
#66
Posted 18 February 2013 - 08:48 PM
Double post
Edited by TerrA LX, 18 February 2013 - 08:51 PM.
#67
_chev400_
#68
Posted 18 February 2013 - 08:49 PM
Like this ^
#69
_chev400_
Posted 18 February 2013 - 08:54 PM
#70
Posted 18 February 2013 - 09:06 PM
I refer to the equipment and technique, use the largest hardest blocks/boards that will contour to the panel.
Also I sand in a cross hatch pattern (70 to 90 degrees to each other) by sanding one way then sand again in another, ie top left to bottom right then again from top right to bottom left.
Never in one back and forth direction and never in circular motion.
#71
Posted 18 February 2013 - 09:09 PM
So like in this example I would use one board for east/west sanding and the other contoured board for north/south sanding.
#72
_chev400_
Posted 18 February 2013 - 09:15 PM
#73
_Lamo_
Posted 18 February 2013 - 09:19 PM
#74
As large (long) as you can comfortably fit to follow the contour of the panel.
Soft blocks are only good for colour sanding. JMHO.
Edited by TerrA LX, 18 February 2013 - 09:23 PM.
#75
Posted 18 February 2013 - 09:22 PM
Anything that is too flexible will not allow you to apply even pressure.
Sorry can't comment on the new dura blocks, they sound good but I have yet to update my old school equipment.
