Need help in choosing the right products
#76
_chev400_
Posted 18 February 2013 - 09:30 PM
#77
Posted 18 February 2013 - 09:38 PM
Don't worry Rob, just buy them, and when your finished with them I will come take them off your hands so you never have to see them again.
Oh and if their no good then they didn't cost me a thing.
Cheers Terry.
Edited by TerrA LX, 18 February 2013 - 09:39 PM.
#78
_Lamo_
Posted 18 February 2013 - 09:42 PM
TerraLX is right. From my very limited experience, I don't think they will be any good for larger flat panels but the boot lid and rear pillar posts etc would be good areas for the smaller blocks. I use the 5 inch and 10 inch versions,
Edited by Lamo, 18 February 2013 - 09:43 PM.
#79
_chev400_
Posted 18 February 2013 - 09:45 PM
Cheers for all your help and tips fellas, next update most likely tomoz night.
#80
_Quagmire_
Posted 19 February 2013 - 02:34 AM
#81
_chev400_
Posted 19 February 2013 - 05:59 AM
Before i took off to work I took a quick pic of the paper I'm using, I'm 95% sure this is the right stuff as I heard if you don't use that shit that starts with a "p" it can vary the outcome, let me know if this stuff is wrong?
http://s1131.beta.ph...html?sort=3&o=0
#82
Posted 19 February 2013 - 12:31 PM
Where do you buy your paper?
If your close to VG's maybe you should start shopping there.
#83
_chev400_
Posted 19 February 2013 - 03:08 PM
#84
Posted 19 February 2013 - 04:09 PM
Also, if your wet sanding use clean water and squeegee regularly (to clear the surface or waste)and rub sunlight soap into the paper to help prevent clogging.
If your dry sanding change the paper as soon as it's worn (also applies to wet sanding).
Don't try to rub the life out of the paper, just buy a box of the grade you need and change it often.
Edited by TerrA LX, 19 February 2013 - 04:15 PM.
#85
_chev400_
Posted 19 February 2013 - 04:56 PM
#86
Posted 19 February 2013 - 07:19 PM
#87
_chev400_
Posted 19 February 2013 - 08:43 PM
#88
Posted 19 February 2013 - 09:08 PM
You find a spray bottle delivering enough water to keep the paper clear?
#89
_chev400_
Posted 19 February 2013 - 09:59 PM
#90
_Quagmire_
Posted 20 February 2013 - 02:04 AM
i just add detergent to the bucket...Also, if your wet sanding use clean water and squeegee regularly (to clear the surface or waste)and rub sunlight soap into the paper to help prevent clogging.
starlight soap? squiggees?
frock that's a flash way of doing it
#91
Posted 20 February 2013 - 07:32 AM
Hey quags,
Detergent in a bucket does not have the same effect as rubbing soap into the grit.
How else do you remove the water and crud if you don't use a squeegee block?
#92
_Quagmire_
Posted 20 February 2013 - 01:31 PM
yeah i get the therory
i normally run a hose over it
but then i'm just a bush "painter" lol
#93
_chev400_
Posted 23 February 2013 - 06:35 PM
"Felt similar"**
#94
_chev400_
Posted 25 February 2013 - 03:35 PM
Any ideas guys?
#95
_chev400_
Posted 25 February 2013 - 04:46 PM
#96
_chev400_
Posted 25 February 2013 - 06:25 PM
#97
_chev400_
Posted 26 February 2013 - 08:05 PM
As bomber has stated on another thread I should sand 600 wet and throw more coats on, with that 600 wet do I get it flat with no peel before applying the next 3 coats? Or just sand to get adhesion? I'm guessing to get it flat but just checking with you guys first
#98
Posted 26 February 2013 - 08:10 PM
I usually go min 7 coats of solid acrylic for coverage and to counter for chopping back and buffing and/or flow coating.
if your doing metallic there should be no sanding between colour and clear.
#99
_chev400_
Posted 26 February 2013 - 08:40 PM
#100
Posted 26 February 2013 - 08:44 PM
Same as blocking the primer, the flatter you get it the flatter the final coat will be.
