Here we go.
As the car was already on the hoist I had to make it where it was. The first thing I had to do was make sure the body was sitting level.
I used a spirit level to get the shell level and I did this by screwing the pads on the hoist arms up or down as required.
You can see in this picture how far out the shell is from level.
I decided to attach the dolly at the front at the front rail where the bumper bar bracket mount attaches to the rail.
The rear is attached to the exhaust tail pipe mount on the rear chassis rails next to fuel tank.
As stated earlier I made the dolly out of some scrap steel I had lying around around. These orange beams are left over pallet racket beams. The length silver C channel was leftover steel from the mezzanine level that I built in the shed.
The wheels I got from BCF and are small trailer jockey wheels.
I needed to make brackets to mount the front legs to the chassis rails so I used the C channel. I cut out some small plates.
I then measured the distance between the holes and then drilled plates to suit.
I then worked out where the front legs are going to placed on the rails but first I had to cut the ends of the pallet rack beams.
This made it easy to work out where the legs need to go.
Before cutting the legs to length I had to work out what finished height I wanted it to be.
While working out the finished height I had to take into account the size of the wheels which were 200mm from the bottom of the bracket to the bottom of the wheel.
Front legs cut to length with the paint cleaned off reading for welding.
