Welding helmet, auto darkening not working quick enough
18 replies to this topic
#1 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 08 February 2013 - 11:49 AM
Hi All
I have one of those Techmen auto darkening solar powered helments , Din3 to din11 and lately it
seems to randomly fail to auto darken immediately leaving me with that temporary blindness
in the beginning untill it switches and then I cant see where in welding till the eyes readjust again.
Admitedtely most of my welding these days(arc or mig) is usually under the car or inside the cabin where there is less
existing ambient light. Would this cause it.
Is this common or is the normal for these helmets to do that ?
Thanks, Archie.
#2 kiwi-lilj
kiwi-lilj
  • 1,428 posts
  • Name:Blair
  • Car:LIL J
Posted 08 February 2013 - 11:58 AM
Try a new battery.
#3 TerrA LX
Posted 08 February 2013 - 11:59 AM
Lighting factors may influence the timing of the auto darkness but I have found mostly it is in the quality of the item, I use a cheap one and just learn to shut my eyes just before I arc up helps alot.
#4 Statler
  • 6,318 posts
Posted 08 February 2013 - 02:16 PM
Clean the sensors.
They get clouded with smoke & perform like that.
Failing that, as Blair said, change the batteries.
#5 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 08 February 2013 - 03:34 PM
Don't know about the Techmen helmet but the CIG I have has a small switch (DIP type switch with 3 different settings) on the inside above the lense section to adjust the sensitivity of the darkening function. If yours has the same switch maybe it has been bumped to the least sensitive setting which can result in the slight delay with the auto darkening function.
#6 _toranatime_
_toranatime_
Posted 08 February 2013 - 03:57 PM
If it has a sensitivity setting then have a play with it and the delay settings. But like others have said, clean your lens and sensors first.
Also on some of the cheaper helmets with only 2 sensors your arm or an object can block them causing it not to darken.
Good luck mate, hope you get it sorted.
#7 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 08 February 2013 - 04:32 PM
Thanks Guys,
The glass is clean and it doesnt have any adjustment but Question? What bloody batteries?
It doesnt have any, its a sealed , non serviceable solar powered unit .
Maybe I just need more ambient light shining directly into the solar cells of the helmet in these low light scenarios.
Edited by fuzzypumper, 08 February 2013 - 04:43 PM.
#8 _greenmachine215_
_greenmachine215_
Posted 08 February 2013 - 04:55 PM
Or go buy a speed glass helmet!
#9 _toranatime_
_toranatime_
Posted 08 February 2013 - 06:18 PM
A new helmet with adjustments might be the go then, Lincoln viking 3350 or miller digital elite are both great haha :)
The cigweld helmets are quite good for their price and have enough adjustability. Never take chances with your eyes.
#10 _434LX_
_434LX_
Posted 08 February 2013 - 06:32 PM
Agreed, some things you can save on. A quality welding helmet is not one.
You get what you pay for with welding helmets and you only have one set of eyes !
#11 rodomo
  • 18,039 posts
Posted 08 February 2013 - 10:01 PM
I find mine (same brand) works good if I sit it facing the sun for 1/2hr before I begin work.
#12 Statler
  • 6,318 posts
Posted 08 February 2013 - 10:17 PM
It's a speedyglass you have. Throw it in the bin.!
They come with a 12mth warrenty usually. I went thru 2 before they gave me my money back! Solar powered? Line of 'panels' across the top?
#13 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
  • Car:LXSS, VUSS, VESSv & the mighty HB
Posted 09 February 2013 - 08:19 AM
I have 3 millers and one similar to yours, can't remember the name, it came with the alloy MIG, if it plays up like you have described, I sit it in the sun like Rob said, but for a few hours, I just grab another helmet. :)
#14 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 21 February 2013 - 02:06 PM
I tried one of these when they first came out here, around 1988ish(?). They cost over $500, and I wasn't impressed as it didn't darken quick enough. I would have thought they'd be proply sorted by now???
#15 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 22 February 2013 - 09:17 PM
I have been welding for just under 25 years and have used the auto darking ones and still always go back to the most trusted one of them all. The good old fixed shade $15 special. There is no room for error when it comes to your eye sight and if your not carefull you will end up with welding flash, (very painfull.) I use the std sheild for all types of welding from tig stick and mig. I just change the din shade lense.
#16 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 22 February 2013 - 09:44 PM
M
My preference,too,Dave.
#17 Statler
  • 6,318 posts
Posted 22 February 2013 - 10:44 PM
+1. (except for T.I.G.)
#18 TerrA LX
Posted 23 February 2013 - 08:30 AM
M
The old head flick, or do you leave a gap on the lenses flap?
#19 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 23 February 2013 - 07:37 PM
old head flick mate 100% safe
