aluminium vs steel flywheels, opinions please.
42 replies to this topic
#26 N/A-PWR
  • 9,637 posts
Posted 28 February 2013 - 01:26 AM
i cant remember where but im sure i read somwhere that light flywheels on supercharged engines had less of an effect on the idle qualitys of an engine.
as in it didnt want to stall or be a pig takeing off etc. any thoughts on that??
I can see the Supercharger being a flywheel mass in itself. Dave I
#27 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 28 February 2013 - 08:09 PM
Probably more due to the increased low end torque.
#28 ozyozyozy
ozyozyozy
  • 950 posts
Posted 28 February 2013 - 09:28 PM
used to have a light steel flywheel10kg and single plate clutch 10kg. Had problems with trying to rev the engine up on the downshift when heel and toeing, had to giv it a big stab. Spoke to alot of people, small clutches are great for racing but bad for street, they can't handle the heat soak of stop start. Had a clutch and flywheel made by alloy race components. Alloy flywheel 3kgs and a twin plate 9 inch clutch works great, the ONLY issue I have at lower speeds it dosent hold steady rpm, jst use a lower gear. this can be changed by using a steel flywheel. Drives just like a standard clutch good for far more HP then I have. Total weight clutch and flywheel 12kgs.
#29 TerrA LX
Posted 28 February 2013 - 09:40 PM
I would assume running an alloy flywheel needs a special compound for the clutch and would also mean having an alloy pressure plate?
#30 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 28 February 2013 - 11:33 PM
As Datto says, we put a fair bit of thought into it and in the end went with ian tates recomendation of a yella terra 10 kg job. Still going strong
#31 dattoman
  • 16,487 posts
Posted 01 March 2013 - 12:32 AM
Alloy flywheel still has a steel insert for the clutch to run on
Also made by Alloy race components in Vic
I used to run a ceramic button clutch with a pressed steel pressure plate
#32 TerrA LX
Posted 01 March 2013 - 08:49 AM
Ok, had visions of someone trying to run a clutch on a alloy face for some strange reason, thanx for clearing that up.
By pressed steel pressure plate you mean the hat or clutch cover?
The pressure plate (the face that backs the clutch) would have to be similar steel to what the face of the flywheel is?
I know a few people who run a steel flywheel (because than are safer than a cast steel one) but still run a cast steel pressure plate.
#33 dattoman
  • 16,487 posts
Posted 01 March 2013 - 08:57 AM
Just a standard clutch cover
Pressed steel hat and cast iron baseplate
With alittle more clamp pressure
#34 76lxhatch
  • 7,205 posts
Posted 01 March 2013 - 10:17 AM
They're all cast (before machining) aren't they? Factory flywheels are more iron than steel is all, hate to think what a true billet item would cost
#35 TerrA LX
Posted 01 March 2013 - 11:59 AM
Well if you put it like that then even a billet is cast before machining...
#36 76lxhatch
  • 7,205 posts
Posted 01 March 2013 - 12:29 PM
I guess, although I always understood the process of creating a billet to be a little more than straight casting though. Generally a part is either cast and machined, machined from a billet, or forged.
I would expect the likes of the Yella Terra flywheels to be plain old cast, just more steel than iron unlike the factory items. Although now I do wonder whether billet steel flywheels fit into the low-mid budget range or are highly expensive items only...? (true billet wheels are certainly 4-5x more expensive)
#37 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 01 March 2013 - 12:50 PM
Mate of mine used to make aluminium flywheels for his, and others racecars...way before Commodores were invented.
#38 TerrA LX
Posted 01 March 2013 - 01:00 PM
Most all steel (in layman's terms) is melted and poured (cast) just as an iron engine block is poured into a sand cast, steel is poured into a solid block, this is the billet that something is machined out of.
Forged is steel that has been cast as a rod/cube/flat bar etc then stamped in a die.
#39 76lxhatch
  • 7,205 posts
Posted 01 March 2013 - 03:40 PM
Yes but a "cast" flywheel is cast into that shape as opposed to into a billet which is subsequently machined with much waste into the shape, and I also thought additional steps are involved in the casting of billets?
#40 _oldjohnno_
_oldjohnno_
Posted 01 March 2013 - 04:59 PM
Yella Terra flywheels are machined from steel - I'm guessing from plate so there wouldn't be a huge amount of waste. Billets aren't usually just big lumps of cast steel, there's normally some amount of hot work done to shape it eg. rolled into flats or plates, slabs, rounds, square sections or whatever. Then these formed lengths are cut into "billets". So the internal structure is quite a bit different to a casting. Billet is commonly used to describe any hunk of metal that is machined into a product; most people would probably think of a piece of hot rolled section but it could also be made by extrusion or casting or any other method. CNC machining has made the manufacture of things from billet much cheaper than previously.
#41 N/A-PWR
  • 9,637 posts
Posted 01 March 2013 - 10:15 PM
I worked at BHP Newcastle where the Bloom Mill makes Hot rolled 4"x 4"x 150 foot lengths, then are carted when cold to the Merchant or Rod mill to be Cold rolled into sections, ie - rod, angle, flat bar etc, which is kind of forging by continous rollers. Dave I
#42 76lxhatch
  • 7,205 posts
Posted 02 March 2013 - 07:13 AM
Haha so I was wrong on both counts then, they're more like forged and machined. At any rate good to know how they're made and like TerrA said less prone to self destruction than factory cast iron. Sorry for deviation from topic...
#43 _pinklx_
_pinklx_
Posted 02 March 2013 - 11:02 AM
i kinda think deviation from topic is good. learning a bit about a subject ive never really spent alot of time thinking about.
