LX project
469 replies to this topic
#326 _LS1 Taxi_
_LS1 Taxi_
Posted 22 February 2014 - 10:29 PM
No, didn't strengthen anything....did you?
It's not twisting up and lifting wheels off the ground but as it happened after I played with the bonnet I'm thinking I moved the bonnet enough to reduce the strikers bite. Then on hard launch it flexes just enough at the front to pop it?
#327 _LHSL308_
_LHSL308_
Posted 23 February 2014 - 06:48 AM
You would think if anythings gonna flex from a hard launch it would be the chassis not the bonnet latch area. Maybe you just need to frOck around with it to get it adjusted properly. Are you sure the striker is getting all the way through the latch and catching properly.
I have got a chassis kit installed on my car and I don't see or feel any twisting whatsoever.
#328 _LS1 Taxi_
_LS1 Taxi_
Posted 23 February 2014 - 08:07 AM
It hasn't happened since I adjusted the latch to give it more bite mate but like I said it did surprise the crap out of me when it happened.  Maybe the latch was never adjusted correctly? Just seemed strange to me that the only 2 times it did it were on hard acceleration from a standing still...but anyway, like I said it hasn't happened since :)
#329 _LS2 Hatch_
_LS2 Hatch_
Posted 23 February 2014 - 08:08 AM
Yeah I extended my rails to the rear shackles and strengthened the existing.
I met a guy that had a 400 in a sedan, wasn't on the road long and his gaps had turned to crap.
To be honest gaps don't stress me, it's the cause that does.
Just keep an eye on things, it can always be added if need be
#330 _LHSL308_
_LHSL308_
Posted 23 February 2014 - 08:26 AM
Yeah might have been just the latch wasn't lining up properly with the striker, they don't need to be out by much.
#331 GMHAz
GMHAz
    Driving the Dream
  • 1,175 posts
  • Name:Aaron
  • Car:1977 Hatchback
Posted 23 February 2014 - 09:12 AM
Nice sedan Daz, credit to you mate
Az
#332 _LS2 Hatch_
_LS2 Hatch_
Posted 23 February 2014 - 06:51 PM
I've worked it out!!!!!!
It's cause it's AUTO!!!! (skirt wearing bible basher!)
#333 _LS1 Taxi_
_LS1 Taxi_
Posted 23 February 2014 - 07:04 PM
Attached File  ROFLMAO_2GuysToonAN.gif   20.27K   6 downloads
#334 _Red One_
_Red One_
Posted 23 February 2014 - 07:54 PM
Dont you just love it when a plan comes together?
Great and fast build. Well done man,
Brad
#335 _LS1 Taxi_
_LS1 Taxi_
Posted 05 May 2014 - 06:32 PM
Thought I'd update on what's been happening.
So, since finishing the car have just been driving the wheels off it and having a ball.  Heaps of fun and really reliable.
Have put 3000km's on it without an issue.
Anyway, yesterday I took it to Heathcote to give it a run and see what it runs in current form.  The plan is to run it as is (done), then start changing a few things around and run it to measure the improvements.
Got 10 runs in yesterday with a best of 12.92 at 107mph.  Was really consistent actually. The last 7 runs all came within a 1/10 of second or so.
Here is some pics of the fun (cheers to my mate for taking them).
Attached File  10154276_10152009479985974_6001758551045711788_n.jpg   84.92K   15 downloads
Attached File  10178109_10152009480050974_7520232183690229226_n.jpg   111.65K   16 downloads
Attached File  10246357_10152009480195974_2199956782554049835_n.jpg   75.43K   7 downloads
Attached File  10269612_10152009480220974_750357149401499137_n.jpg   118.19K   8 downloads
Attached File  10297679_10152009480215974_3413354085348639019_n.jpg   101.03K   8 downloads
Attached File  10308088_10152009480175974_8112762883098552813_n.jpg   73.94K   8 downloads
Attached File  10342774_10152009480185974_2117848105494040206_n.jpg   89.08K   7 downloads
Attached File  IMG_2957.JPG   237.32K   8 downloads
I had quite of bit of wheel spin off the line and actually once when it changed from 1st to 2nd the arse kicked out and scared the shit out of me so the first thing to change will be the rear tyres.  Going to go for a set of MT ET street radials.  Will be hunting for rims and tyres in correct offset in the next few days hopefully.
After running like that I plan to pull the motor and box and change cam, valve springs, torque converter and a retune on the dyno before running it again.
This will all be some time off but I'm starting my research and planning from today :)
#336 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 05 May 2014 - 07:06 PM
Good result.  What diff gears are you running?  My hatch ran a 13.5 @ 107 MPH.  It was a manual M21 with 3.36:1 gears.  It had a 12 in it but I couldn't get off the mark quick enough. The auto makes a difference too I reckon..
#337 _LS2 Hatch_
_LS2 Hatch_
Posted 05 May 2014 - 07:08 PM
Great shots Daz, and a base line time to be happy with. One thing thou, you need a bigger helmet hehehehe
When considering a cam, if not changing pistons you can only o to a certain lift before you hit the valve on pston. Check out that before hosing a cam. Could save you a bit of grief.
Look forward to seeing your changes and gains.
Good luck
#338 _LS1 Taxi_
_LS1 Taxi_
Posted 05 May 2014 - 07:27 PM
Thanks Gerry. I am very happy with it.  I thought mid 13's would be about the go but I think grip was better than expected. It certainly grips better than when I am terrorising the regular streets :D
I have 3.5 gears in it.
I know! What a frOcking blockhead. Those pics must make it much worse though  :blink:
Being tall has it's drawbacks. With the stupid stackhat on the damn helmet was just pressing on the roof.  It always makes me laugh how small even the big toranas are.  It's like putting a V8 in a Corolla :lol:
Oh....and Grant, check out the water pissing out the tailpipes in a few of the pictures!
Random as.
#339 _LS2 Hatch_
_LS2 Hatch_
Posted 05 May 2014 - 07:48 PM
Where is the water coming from? Do you loose water at all. Will be interesting once you remove your heads to see if there is a leak from a water jacket at all
#340 _LS1 Taxi_
_LS1 Taxi_
Posted 05 May 2014 - 07:56 PM
I haven't used a drop in 3000kms mate....and I always check. Weird as hell.
#341 _mello92_
_mello92_
Posted 05 May 2014 - 08:35 PM
Its not just flicked up water trailing along the exhaust is it?
Looks good Daz, impressive times, looking forward to see what the changes bring.
#342 _hlk76_
_hlk76_
Posted 06 May 2014 - 07:04 PM
yep i know how you feel those cae starters aren't the best.had one chew a flexplate on my ls2 in my torrie.so i put a factory starter on and a new flexplate,absolutly awesome now not a single bit of trouble.
#343 LS1LX
LS1LX
  • 1,931 posts
Posted 09 May 2014 - 06:07 PM
My LS1 Torana was running 11.90s @ 116mph, only time I went 12.90 and 105mph was just before the bottom end bearings all let go :(
Similiar setup, 3.55 gears and 17" 245 nankangs
#344 _LS1 Taxi_
_LS1 Taxi_
Posted 09 May 2014 - 07:23 PM
I best pull it for a rebuild  :blink:
11.9 is very good going  B)
#345 _LS1 Taxi_
_LS1 Taxi_
Posted 09 August 2014 - 05:37 PM
Well a few small things have been going on.
Been busy with everything else so not much time to make changes but I have been doing plenty of driving!
I wasn't happy with the boat like (and unpredictable) handling through corners so fitted up a Whiteline front mount 24mm sway bar kit.
Attached File  IMG_3125.jpg   55.02K   7 downloads
Attached File  IMG_3126.jpg   28.84K   6 downloads
Attached File  IMG_3127.jpg   31.41K   7 downloads
Attached File  IMG_3131.jpg   47.14K   7 downloads
Basically has some brackets that go from the front bar brackets to mount the sway bar just behind and below the radiator.  Pretty rigid once bolted in and simple install.  Only needed to mod two small things so that's always a bonus :)
Attached File  IMG_3134.jpg   56.28K   6 downloads
Can see it hanging out underneath the front....I've got a front spoiler to paint and fit up to toughen it up a bit from the front.  Idea stolen front Grant   :lol:
Just after I fitted the sway bar I took it out to Heathcote.  Grant had his hatch there the same day so we had a few runs and a bit of a laugh.  I fitted up some MT ET street radials on the back and ended up going .15 quicker - 12.77 @109mph.  Definitely need more HP to go faster.
Attached File  IMG_3138.jpg   67.38K   8 downloads
On the last run of the day I threw the accessories belt at about the 400ft mark (according to the marshal) and saw the light come on but kept my foot into it anyway until the finish line  :spoton:
It got pretty hot - gauge was maxed out  :o
Attached File  IMG_3145.jpg   59.88K   6 downloads
So towed it home, ordered a new belt, fitted it up and all good. Runs just fine.
When I was taking the ET streets off I noticed I'd flogged out a few of the studs on the rear. They had come loose and wouldn't tighten up. Instead of pulling axles and welding on them (first thought), I ordered all new studs.  When I popped the drums I noticed on one side I had a tiny weep of brake fluid from the wheel cylinder and on the other side I had a decent axle seal leak.  So I ordered axle seals for the 9" and new wheel cylinders.  Put it all back together and all good.
While I had it in the air I decided to drop the tail pipes and fit little dumpers infront of the diff.  I'd actually planned on doing this after I got it engineered and on the road but I never got around to it.  So ordered the bits and made them up.  Noise inside the cabin didn't increase much which is good and I prefer the rear look of it all now   B)
Attached File  IMG_3257.jpg   51.19K   5 downloads
Attached File  IMG_3259.jpg   41.79K   5 downloads
Attached File  IMG_3264.jpg   36.19K   7 downloads
Thanks.
Edited by LS1 Taxi, 09 August 2014 - 05:39 PM.
#346 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 09 August 2014 - 06:35 PM
The ET radials look to have helped you a bit. A 12 second street car is a very good package! I fitted some new ET's to my car today in readiness for August the 31st drags :-).  Can't wait.
#347 _LS2 Hatch_
_LS2 Hatch_
Posted 09 August 2014 - 10:59 PM
Did dumping the pipes make it much different outside?
Surprised its made little difference inside. I thought it would drone
#348 _LS1 Taxi_
_LS1 Taxi_
Posted 09 August 2014 - 11:10 PM
A little louder mate but not really noticeable - still a quiet car to me. It might have droned more if I didn't have so much dynamat and insulation? Dunno. I think it's a subjective thing.
#349 _LS1 Taxi_
_LS1 Taxi_
Posted 23 April 2015 - 09:31 PM
Time for a mini update, been driving about heaps and clocking up the kms. Really is awesome fun to drive.
Anyway, fitted up a front spoiler a few months back.
Last time I ran down the strip I threw the serpentine belt mid track....and clocked up a PB :lol:
Anyway, while booting about I've noticed the belt is slipping near redline and on 1st/2nd hard changes. Did some research on the commodore forums and turns out it is common as the factory tensioner isn't up to it. So, ordered on of these Aeroflow billet things and fitted it up. Problem solved!
I've also been having traction issues (lol) and decided I needed bigger rubber on the back.
So, I ordered in some 8 inch rims and had some sticky Dunlop 235/45r17s fitted to them.
Old boots and new boots.
Next thing I plan on doing is a bigger fuel tank as I aim to drive this up to toranafest this year and be buggered if I'm filling it up 3 times on the way up.
I also need top as a cup holder to my custom console.... :)
#350 SmacT
SmacT
  • 1,007 posts
  • Name:Sam
  • Car:LX 4dr 355, TKX, BW
Posted 23 April 2015 - 10:06 PM
Cool update - obviously enjoying your car! Can't wait to be at your stage...
Did the bigger rubber help? The spoiler finishes the car off nicely too IMHO.
