Been away so nothing has been done but got back into it today.
This is the shim kit for the starter...
IMG_2087.JPG 142.7K
6 downloads
You can see the installed here which will sit between the starter body and the mount as mentioned by Andy to move the pinion 1mm further away from the flywheel.
IMG_2091.JPG 149.1K
4 downloads
This is it all installed back up. It's now quiet, no intermittent screeching and the lash must be good as it's very quiet when cranking too.
IMG_2095.JPG 103.76K
5 downloads
Really happy that job is out the way.
Once I got it back together, I installed the radiator overflow bottle and started it up. Got it up to temp and the overflow worked as it should, fans came on, engine remained in temp range so all great there.
I then put my intake jigsaw together and installed it up. Really happy with how that came out.
IMG_2097.JPG 170.38K
9 downloads
IMG_2103.JPG 136.8K
4 downloads
IMG_2105.JPG 159.78K
5 downloads
I really do need to install the fan blower
Thanks.
