Youngy's LX Hatch
#276 _LXATIV_
Posted 02 December 2009 - 09:57 AM
#277 _youngy_11_
Posted 02 December 2009 - 10:54 AM
#278 _beige_lj_
Posted 14 December 2009 - 08:51 PM
Really like the car, well done on finshing it and the feature in the mag
#279
Posted 27 January 2010 - 01:18 PM
#280
Posted 27 January 2010 - 02:18 PM
obviously LJs arent popular enough to get in young guns!
#281
Posted 27 January 2010 - 07:52 PM
I just bought Street machine today knowing that your car would be in it,
great article and an inspiration to all of us
my son Daniel and I think your car is AWESOME!!!!!!!!!!!!
#282 _moot_
Posted 28 January 2010 - 02:17 PM
#283 _gibbo88_
Posted 28 January 2010 - 04:25 PM
#284 _youngy_11_
Posted 29 January 2010 - 08:29 PM
No worries Gary anytime, I will have to head down to your shop with the car soon.
#285
Posted 30 January 2010 - 05:55 AM
Cheers Mick.
#286
Posted 13 February 2010 - 12:32 AM
#287 _A9XOSS_
Posted 13 February 2010 - 09:38 AM
aswell i had a look at your re-build album. cheers Colin.
#288 _doogs_
Posted 21 July 2010 - 06:04 PM
#289 _mick74lh_
Posted 21 July 2010 - 08:48 PM
#290 _youngy_11_
Posted 07 March 2011 - 04:21 PM
Main reasons:
Same sump, engine mounts, T5 will bolt on, will make more power than a cammed 304, blower wine )), keep it different.
Found myself a L67 locally for $900. The engine had approx 200,000kays. The engine had a suspect blown-head gasket, which I later found was not a blown head gasket but a blown LIM gasket. The LIM gasket was in pretty poor shape when I removed the LIM. The head gaskets seemed to be intact.
I picked the engine 1 week ago and after 4 hours I had both heads off.
I have since removed timing cover, so the bottome eng is ready to go to the machine shop.
The piston tops look ok, and the bottom end spins freely with a socket on the cranks bolt.
I will be taking the heads to a machine shop to inspect. Once I receive the 105pound springs and new valve seals I will get them to service the heads(Surface regrind, valve seats cleaned up, valves cleaned up too)
I will also be doing a DIY mild port/polish job to clean up the rough castings.
The M90 spins freely and seems fine.
One head had a small crack and I have sinced sourced another head and its at the machine shop getting check over.
Plans are
BYE A2A intercooled
600x300x76 intercooler
BYE U bend
85mm LS1 TB
JNT airbox
Ported Blower +LIM
XP HOT cam (Comp cams)
105pound valve springs
Chromoly Pushrods
Comp cams lifters
cometic head gaskets
42lbs injectors
Deleted balanced shaft with plugged oil feed.
Smaller pulley don't know what size yet. Prob 2.6"
MAFLESS tune by Dick. Hopefully I will be using the VT etc. ECU but if not I will jsut run the VP ECU and loom.
Hopefully I can just fit a bearing kit through the bottom end and retain the stock pistons to save a bit of cash.
Engine will make >300rwhp easy.
Cheers Youngy
Edited by youngy_11, 07 March 2011 - 04:24 PM.
#291 _nial8r_
Posted 07 March 2011 - 07:19 PM
#292 _uctorry_
Posted 08 March 2011 - 11:08 AM
doing the same with a mates four door using a vt supercharged V6
tko 5 speed
so far so good
keep the pickies coming
#293
Posted 08 March 2011 - 11:41 AM
#294 _youngy_11_
Posted 08 March 2011 - 07:36 PM
#295
Posted 09 March 2011 - 06:40 AM
Mark
#296 _youngy_11_
Posted 09 March 2011 - 05:05 PM
#297 _Torrie_Man_
Posted 09 March 2011 - 08:51 PM
#298 _youngy_11_
Posted 07 June 2011 - 04:08 PM
Work completed over the past couple of months.
I ported both heads my self and smoothed combustion chambers. (~15 hours)
All done by this little tool, no need for expensive dremmels
The blower was completely disassembled so that it could be ported, plus remove all the casting marks and polish to a mirror finish (~20 hours)
80 grit
While the blower was being polished the bottom end was taken to APM to be balanced.
240 grit
Finshed
The blower snout was also disassembled and polished
The intercooler plate didnot have the carbon fiber covering, so with a help of a mate we applied carbon fiber. I also cleaned up all ports to help air flow.
I received the short block back from the engine shop last week.
This shot shows the deleted balance shaft with plugged oil feed
Fitted ARP head studs and cometic head gaskets
I have rebuilt the oil pump, re fitted timing cover and fitted lower intake manifold to the block.
Today I masked up the engine and painted it.
Cheers Young
#299
Posted 07 June 2011 - 05:48 PM
#300 _TJ355_
Posted 07 June 2011 - 06:10 PM
