Youngy's LX Hatch
403 replies to this topic
#301 _youngy_11_
_youngy_11_
Posted 07 June 2011 - 07:21 PM
Yeah just put it in a battery drill. Better if you can get your hands on a proper rotary tool. Either electric or air driven.
That colour is the final colour. I Wanted to go away from just black to lighten up the lower engine bay. No need for bright colors as the engine bay is already pretty bright.
#302 MRLXSS
  • 12,400 posts
Posted 07 June 2011 - 07:24 PM
Looking great mate!
#303 _HRV74_
_HRV74_
Posted 12 June 2011 - 08:42 PM
Looking good Ryan! :spoton:
#304 _mick74lh_
_mick74lh_
Posted 13 June 2011 - 02:50 PM
Thats awesome. I would be pumped if that was mine! You should post some videos of this thing running when its done.
#305 _youngy_11_
_youngy_11_
Posted 13 June 2011 - 02:58 PM
Thanks fellas. Yeah I will put videos etc. once its running.
Once run in should be very similar to this VN.
VN L67 on Dyno
Ryan
#306 _billywest_
_billywest_
Posted 19 June 2011 - 07:24 PM
VN L67 on Dyno
Ryan
I BET YOU WILL HAVE FUN WITH THAT RYAN LOL :buttrock:
#307 _nial8r_
_nial8r_
Posted 19 June 2011 - 07:53 PM
shit mate she's gonna dance thats for sure :buttrock:
this is a worry for me though http://youtu.be/CxD-n6siUiY :DOH:
#308 _youngy_11_
_youngy_11_
Posted 22 June 2011 - 04:38 PM
haha. Im not going to be fussed if a worked 6litre can beat me. At least i will be able to be this suzki hahhaha.
Similar blower wine too!
Youngy
#309 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 22 June 2011 - 05:09 PM
Superchargers are cheating :P
#310 _youngy_11_
_youngy_11_
Posted 23 June 2011 - 01:28 AM
Lol. Nothing wrong with a LEGAL supercharged tori!. Lol. Fun times
#311 _nial8r_
_nial8r_
Posted 23 June 2011 - 08:37 AM
i wonder if the boys in blue will notice if i have a 6/71 hanging out the bonnet :dontknow:
#312 _rob350hatch_
_rob350hatch_
Posted 23 June 2011 - 10:34 AM
awesome that head work,i allways love to see what people can achieve when they have a go.which has been the whole story with your car.just a word of warning if you beat me at huntley or the drag day if you are going ill send you home lol :stirpot: .
i cant wait to see and hear it good on you.how far away from finish?
ps what did you do with your old engine.my vt has over 300k on it now lol
#313 _youngy_11_
_youngy_11_
Posted 23 June 2011 - 07:53 PM
Thanks rob, the internet is gold for learning things. Plus alot of patience but i want to get this motor right the first time.
Lol dont know about huntley but should go close down the strip hopefully.
I recon it wont be on the road until September.
Im going to sell the old motor, got someone interested in it for a hr conversion :).
Youngy
#314 _youngy_11_
_youngy_11_
Posted 26 June 2011 - 10:37 PM
After a top day at a local car show with ~20 torana's including some members on here, I decided it was time to take the tori off the road and get this upgrade happening lol.
Pic from Kembla Grange
The drop tank has been removed so that a surge tank can be built around the current pump, with another smaller pump feeding the tank. This is to stop it sucking air when going around right hand corners with <40litres of fuel.
The engine is just about ready to come out just need to remove some more wiring, tail shaft and bonnet.
Posted Image.
Some other work on the new motor,
Trial fitted the modified VS fuel rails with the 60lb injectors
Went through the wiring the other night and nutted out most of it, roughed it in on the engine.
SO much Air Con and auto trans shit that is not needed lol
Ryan
Edited by youngy_11, 26 June 2011 - 10:44 PM.
#315 _nial8r_
_nial8r_
Posted 27 June 2011 - 07:56 AM
looks like your well on your way mate, keep the pic's comeing
#316 Growla
Growla
  • 229 posts
  • Car:LX SL/R LS1 conversion completed July 2010
Posted 27 June 2011 - 11:22 AM
Youngy,
I used a BA falcon fuel pump setup. The falcon pump has screw holes in the top where the commodore (VY) has a recessed locking system. They have a small factory swirl pot and would meet your needs. I just recessed the top using a 10mm plate, and tapped the holes accordingly to fit it in. The other thing is it is quiet.
I wish I took photo's during the build and before I installed it.
Mark
#317 mitchg
mitchg
  • 3,111 posts
  • Name:Mitch
Posted 27 June 2011 - 01:06 PM
Looks good Ryan, cant wait to see how this one goes!
Pic from yesterday
#318 _youngy_11_
_youngy_11_
Posted 27 June 2011 - 02:05 PM
Thanks for uploading mitch.
Mark, was this similar to what you used?
http://www.ebay.com.au/itm/FORD-FAIRLANE-FALCON-LTD-BA-BF-6CYL-V8-FUEL-PUMP-ASSY-/200567327220?pt=AU_Car_Parts_Accessories&hash=item2eb2be89f4
Are you using the BA pump to feed the fuel rail?
Can you explain further how it works/ your setup?
Another shot from a while ago
Thanks mate
Ryan
#319 Growla
Growla
  • 229 posts
Posted 28 June 2011 - 10:58 AM
Yes, that's the type I used, accept mine is from XR6T/8.
There are three outlets.
Fuel out
Fuel return and
Breather.
LS1�s have a single line to the fuel rail and bleeds off either at or after the fuel filter. I used GF822 AC Delco filter/pressure regulator as it was already setup prior to this fuel pump update.
However, the Falcon setup has a pressure regulator that is the same as the LS1 and could have done this conversion using a standard commodore fuel filter setup but it more time and more fittings. (Just check what specs a Supercharged V6 regulator is as I couldn�t it on the net). You may need to run an external fuel pressure regulator.
Get some quick fittings to connect the fuel lines and I get the electrical plug from a wreck.
To make a seal I went to Clark rubber and bought a piece of fuel resistant rubber /neoprene and a tube of sealant. Tried the Ford original seal and it leaked.
Hope this helps
Mark
#320 _youngy_11_
_youngy_11_
Posted 28 June 2011 - 10:40 PM
Thanks Mark.
So did you mount the above pump setup vertically?
Whats the purpose of the plastic thing surrounding the pump lol?
Does it have to sit on the bottom?
Your suggesting removing my current pump and only using the BA pump on its own?
Ryan
#321 ls2lxhatch
  • 5,332 posts
Posted 28 June 2011 - 10:51 PM
I think the ford pump is similar to the VZ Commodore pump but not as tall. They are basically a EFI pump, lift pump and surge tank in one.
See manual pages 88-90 for a full description Holden Gen III V8 Engine Management Service Training Manual.
#322 _youngy_11_
_youngy_11_
Posted 29 June 2011 - 09:20 AM
Thanks Andy. Exactly what I was after to explain the setup.
This setup would definitely be better than my current setup but I think it is still easier to modify my current setup by fitting a lift pump, pumping into my current swirl pot. I just have to block holes drilled in swirl pot so that fuel is retained.
Also Im considering running E85 fuel and I don't think a BA XR6 pump will be able to deliver the fuel required.
#323 Growla
Growla
  • 229 posts
Posted 29 June 2011 - 11:46 AM
You can use a later model pump, as it the same setup with a mini swirl pot. You will have drill holes in the top plate if you use a commodore or FG falcon type. Maybe make a metal ring over the top to ensure it doesn't leak. I realise could have used the VY setup I had, but by the time I decided to go with a drop tank I had sold it. I'm not sure about depth of each model but the ford one worked out best for me.
Andy that�s a great photo of the pump setup.
Also these pump setups can be squashed down from about 9" to 6" from memory. My tank was 8"-8.5" deep where it sat in the recess for clearance of the outlet connections.
Mark
#324 ls2lxhatch
  • 5,332 posts
Posted 29 June 2011 - 05:33 PM
I looked at at using the VT-VX pump which is probably the same at the VZ.
When pushed down to the minimum height it was (240 mm/9.5") and needed 40 mm clearance above the pump.
My tank is only 160 mm deep.
Edited by ls2lxhatch, 29 June 2011 - 05:35 PM.
#325 _youngy_11_
_youngy_11_
Posted 01 July 2011 - 11:01 AM
The VP V6 engine is just about ready to come out, just another hours work to nut out a couple more wires before cutting. We have also nutted out most of the L67 loom, with the majority of the AC and Auto Trans wiring to be removed (not much left lol).
Yesterday I fitted the 600x300x76 (3" ends) front mount. I was very tight but just fitted, within 2mm lol.
Had to modify some of the grill, but this will be hidden when the chrome bumper is re fitted.
The bonnet catch setup was also modified.
Thanks Glen for alot on info on the best inter cooler setup
http://www.gmh-torana.com.au/forums/topic/43495-lx-hatch-rb30-turbo/page__p__476706#entry476706
Ryan
Edited by youngy_11, 01 July 2011 - 11:07 AM.
