Youngy's LX Hatch
403 replies to this topic
#376 _LJ355_
_LJ355_
Posted 04 November 2011 - 03:07 PM
looks awesome well done good to see somthing different
#377 _youngy_11_
_youngy_11_
Posted 06 November 2011 - 01:47 PM
Thanks hatchman and Lee.
Just wait for that blower wine at 6000 :) This was only 1700rpm.
https://cache.gmh-to...05-12-02-01.mp4
#378 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 07 November 2011 - 12:12 PM
That sounds sweet as, can't wait to hear it cruising, especially at 6000.
Don't forget to record that.
#379 _nial8r_
_nial8r_
Posted 07 November 2011 - 06:51 PM
she dont sound like any old V6 dunnydore donk now mate :clappin: lol @ ^^^ cruising at 6000rpm :driving:
#380 _youngy_11_
_youngy_11_
Posted 21 November 2011 - 08:49 PM
OK guards, nose cone and bonnet on!
With out needing modification. Posted Image
There is about ~8mm clearance above the pulley which is the closest point.
Just have to modify the bonnet latch so that the manual release finger doesn't foul on the inter-cooler.
Spoke to the engineer he wants a noise and emissions test, will ring my mate from the exhaust shop and get the noise test done and see where its sitting.
Getting close.
So basically it is on the road now! 9 months after purchasing the engine.
#381 MRLXSS
  • 12,400 posts
Posted 22 November 2011 - 10:48 AM
Woohooo!!!! Looking good! The Bumper should hide the intercooler yeah?
#382 _youngy_11_
_youngy_11_
Posted 23 November 2011 - 07:51 AM
Took it for a drive last night, just a dab up up to 1/2 throttle and straight away up to 5psi on the gauge. Need to take it easy until its run in :)
#383 orangeLJ
Posted 23 November 2011 - 08:28 AM
Looks SCHMICKO!
Most people wouldnt even notice the intercooler, very stealthy (black would be stealthier haha)
I think we will need a chrissy cruise this year to see what everyone has been up to!
#384 _youngy_11_
_youngy_11_
Posted 23 November 2011 - 08:54 AM
Yeah sounds good. Ill be keen to put kays on it.
Yeah i had planned to paint it back but couldnt be #@$^%& as I wanted to get it on. Im happy with it though.
#385 MRLXSS
  • 12,400 posts
Posted 23 November 2011 - 11:28 AM
That looks SWEEEEEEET!!! Love it!
#386 _ass308_
_ass308_
Posted 24 November 2011 - 07:52 AM
nice job ryan
#387 _V6 UC_
_V6 UC_
Posted 24 November 2011 - 11:01 AM
Looks good Ryan. Now u too will become addicted to the little engine that could. Cant wait to see it on the strip. 11s will be a walk in the park
#388 _youngy_11_
_youngy_11_
Posted 11 January 2012 - 08:21 PM
Sorry been a bit lazy and pretty busy lately.
So the car is finally engineering and registered with the new motor, after a stuff around as they brought in new engineering laws.
I have done about a 750km on the motor and im stoked. Did an oil change at 500km.
Just doing some more kays until I really get into it. Will be fitting the 3.45 diff gears and lokka centre after its run in.
Ryan
#389 _homer_
_homer_
Posted 11 January 2012 - 09:21 PM
Looking Good. Sounds nice too.
#390 _AD_75_
_AD_75_
Posted 12 January 2012 - 08:24 PM
Sounds nice mate! should take it to powercruise if ya wanna give it a squirt or three. ;)
#391 _nial8r_
_nial8r_
Posted 13 January 2012 - 07:31 PM
well done Ryan good to see you have it back on the road :D
#392 _youngy_11_
_youngy_11_
Posted 13 January 2012 - 08:52 PM
Cheers guys. Keen for powercruise but I might wait to the year after. See how busy it is this year.
#393 _youngy_11_
_youngy_11_
Posted 08 April 2012 - 08:20 AM
Cars been going well. Have fitted the the 3.45 gears (were 3.9) and lokka centre. Happy with the outcome the 3.45 gears are much more useable and are quieter than the old set. The lokka is great and puts the car sideways with a stab of the throttle mid corner. The ticking noise isn't too bad. Only downside i am finding when going around sharp corners roundabouts or hair pins on steep sections when one wheel is spinning heaps faster than the other. If i have it still in gear and just coasting around, the car develops a harmonic, bunny hop. As soon as i get on the throttle its fine or with the clutch in its fine.
Any ideas??
I have just returned from a trip out to bathurst car went well and was averaging a bit over 10l/100 by my rough calcs.
Was out there for the motor festival. Caught up with Rob Shaw and met another member off here who was racing his VZ clubby.
Had a great time and rob got some awesome footage with my new go pro camera.
Rob and Vaughan
Ryan
#394 76lxhatch
  • 7,191 posts
Posted 08 April 2012 - 10:27 AM
Looking good!
With the Lokka in the tight corners, you should find that you can either decelerate or accelerate (doesn't need to be by much, but you can't coast in between) throughout the entire corner until pointing straight again and you won't have any hassles, but anywhere in between and it will lock up. You can switch from off the power to on by slipping the clutch (sometimes you can get it just right without if you're really quick) but generally I try to avoid doing this in tight corners.
#395 _youngy_11_
_youngy_11_
Posted 23 April 2012 - 09:24 PM
So of you may of heard but I was getting the car tuned(on road) on Saturday and after the 5th run while downshifting back to 2nd heard a bad noise, which continued once I pulled over. Decided to shut it down and get it car tralied home.
The car was performing great during the tune and wasn't knocking or loosing fuel all the way to 6400rpm. The tuner put a fair amount more timing in and was very happy with the performance so far.
So yesterday and today worked on pulling the motor out suspected the worse as I noticed the oil pressure dropped to 20psi for a short amount of time when I was loading and unloading in 2nd gear.
Luckily I have dodged a bullet. The issue was the flywheel bolts had worked loose and a dowel had came out.
Still have to look into the oil pressure issue, but pretty happy atm.
Bit of damage on crank and flywheel but should clean up ok.
Thinking of wiring the bolts together to stop the chance of them coming loose also thinking about using spring washers.
Going to take the sump off and have a good look inside.
#396 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 23 April 2012 - 10:19 PM
Crank is farked.
#397 _mick74lh_
_mick74lh_
Posted 23 April 2012 - 10:50 PM
Hey I can't tell if that is stuffed or not, but sorry to see that happen. Hope you don't have to pull the engine right down. I really like what you've done with this car.
#398 _youngy_11_
_youngy_11_
Posted 24 April 2012 - 05:21 AM
Why's that Kevin?
#399 ls2lxhatch
  • 5,332 posts
Posted 24 April 2012 - 10:37 AM
I don't know what the factory V6 flywheel bolts look like but most flywheel bolts have a flange or oversize head.
I would see what ARP has to offer.
#400 orangeLJ
Posted 24 April 2012 - 10:55 AM
I'd be pulling the crank to check for other damage, that looks like it copped a fair whacking.
I dont know if your flywheel will seat properly on such a munted surface? was there anything special about the crank? or just a standard job?
might be worth relpacing just to be sure.
