Muffler Choice for hot street car
Posted 20 June 2006 - 04:29 PM
Soooooo, it's time to quieten her down a bit. Regardless of my upcoming noise test, I've wanted to quieten it down a bit anyway. It is too noisy for cruising the streets, I'm always paranoid cos of how loud it is, especially driving it at night, if you open her up it shatters the night time silence and you know people will hear it literally km's away. Plus it's gotta irritate the neighbours, particularly on those early morning starts for car shows etc....
My current mufflers are Supercat straight-through's (but with an expansion chamber in the middle). It's a twin 2.5" system the whole way (Chev 383 V8 with Tri-Y's). I recently also had a 10" resonator welded into each bank before the mufflers.
My plan is to remove these mufflers and replace them with a good quality triple flow. So what options do I have? I'd like something that will take some noise out, but not be overly restrictive (is there such a thing?). Obviously, I want them to sound good too. Anyone have any good suggestions?
And also, what are your thoughts on performance/HP loss by switching to a triple flow after running straight-through's??? Would it really sob that much???
Any thoughts and ideas would be much appreciated!
Thanks all.
_MAWLER_
Posted 20 June 2006 - 08:33 PM
There was a thread a couple of months back on mufflers and sound quality and I suppose this adds to it a bit because we are talking about reduction in volume as well as sound quality.
Along with Bretts question regarding triple flow mufflers I'm going to throw in 'straight through' mufflers as well. Is it possible to get a legal db level with straight throughs or are triple flows the only option?
Cheers,
Posted 20 June 2006 - 09:50 PM
Posted 20 June 2006 - 10:01 PM
I am running some offset in centre out mufflers (supercat I think) and they sound good and are not too loud. I take it yours are centre in centre out?
_1QUICK LJ_
Posted 20 June 2006 - 10:58 PM
_LH SL/R 5000_
Posted 20 June 2006 - 11:29 PM
Posted 21 June 2006 - 07:36 AM
Idle noise tested 86Db at tailpipes.
Don't know how loud you can have it in Vic. But 86Db is what mine is ment to be at 4,500rpm not idle. (3/4 of peak power rpm is were its measured)
Edited by LS1LX, 21 June 2006 - 07:37 AM.
Posted 21 June 2006 - 10:54 AM
makka - I believe my current mufflers are an offset style straight-through (with a chamber in the middle). To shut the chev up a significant amount, it's going to need a much more restrictive muffler I believe.
1QUICKLJ - The Walker Dynomax turbo's you mentioned - they are Lukey right? Would this be them?....
http://www.lukey.com...=CONTENT&sid=64
Nothing on the site for the link above actually describes the internal design of that muffler, I assume it is a tradtional triple flow type design (ie. up, back, up again)...
Thanks for the other suggestions too, I will look them up next.... but have thinking of possibly trying some Lukey's.
LS1LX - thanks for the info too - WOW 86dB is super quiet! In Vic we are allowed 96dB, and my car is WAAAAAY over that. You're running an injected motor right, maybe that's half the reason why you've been able to get yours down so far. Will suss out those Borla mufflers though too...
Cheers all, keep the comments coming!
Posted 21 June 2006 - 10:56 AM
_MAWLER_
Posted 21 June 2006 - 04:43 PM
86db at idle is not what I would have called quiet Brett, because when taken up to the 3/4 of max RPM it would be way above the legal 96db, just like ours are, Seeing it is measured at 3/4, thats where its important to be under the 96db.
According to the Lukey site (under advice, explaining muffler designs), the glass packed straight throughs offer a better result than the triple flows, and will obviously have better flow as well I was originally going for a Magnaflow offset in/out which are glass packed, I was told from several sources they offered the best noise restriction. Different exhaust guy ended up doing the job so I ended up with the SuperCats offset in/out.
Interesting thing I noticed on the Lukey site as well was in regard to the muffler size, bigger equals quieter, my mufflers are really quite small, being only about 8" wide and maybe 12" long.
Peace,
Edit: Try this site Brett for some info on the DynoMax and MagnaFlow http://www.a-1perfor...flers/index.cfm
Edited by Liam, 21 June 2006 - 04:48 PM.
Posted 21 June 2006 - 05:09 PM
Thanks for the other link too, will have read of it when I get a chance.
As for the glasspacking - I thought our Supercats were glass-pack too???? Maybe not....
One bloke I spoke with today said he likes the Redback triple flows - said they would be a lot quieter, but still good on performance. And they are one of the better flowing triple flows around...
The research continues... I think I'm going to buy myself a dB meter from Dick Smith. Even if it's not dead-accurate, it will give a good indication, then I can play around
_coupe202_
Posted 21 June 2006 - 05:30 PM
Posted 21 June 2006 - 06:58 PM
http://www.vpw.com.a...6&PrdGrpID=2781
Might call VPW tomorrow and get some info on them. Are they a quiet muffler? I reckon they would still make a fair bit of noise???
Posted 21 June 2006 - 10:36 PM
Posted 22 June 2006 - 02:33 AM
Are you looking to just pass the EPA, then fit something thats quieter, not get as much attention but still maybe over the limit a little bit???
Cos i think its only becuase atm ur car is really F-ing loud which draws unwanted attention to you, if it was just a little bit over they prob would let you slide a lot of the time....
p.s When we going for a spin next?
Posted 22 June 2006 - 09:58 AM
If the muffler you are currently using is the Lukey (or redback copy) I reckon they are crap. I removed these (2 of 2.5") and replaced them with the Walker Super Turbo (also 2 of but in 2.25" ) and picked up a tenth, and heaps quieter. I used to swear by the Lukey, but paint used to always burn away from the middle of the muffler (where the expansion chamber is). That got me thinking that it was obviously a large restriction (gases getting confused). Also removing the Lukey equipped exhaust and running open pipes gained me .25 sec ET and 2 MPH (too big a difference). I have also used a single 2.5" Super Turbo on a 12 sec 308, removing it had no effect on ET or MPH, despite losing about 40Kg of weight.
The Hookers sound and flow great, but are not the quietest. Perhaps they would work OK in association with what you have. A mate has a 12 sec SBC and runs twin 3" to the diff with the Hookers. Sounds great and goes as well as open pipes. For street use he bolts on a pair of 2" press bent tail pipes with resonators!! This knocks heaps of noise out of it and still retains drivability. Won't rev past 5000rpm though !!
Good luck with whatever you decide on.
_Lostit_
Posted 22 June 2006 - 10:55 AM
As for restritive and things that bullshit for streetcars.. if you spent the money on the correct stuff it will go just as fast as with full pipes on.
As formyself with the 400SBC im running 13/4 primaries into 1 .. 3" dual pipes all the way with custom mufflers made up .. seems to muffler the motor well apart from motor noise itself .And as for power lose with pipes on or without Honestly i reckon the motor revs more cleanly with the pipes on then without.
Only reason i take em off at drags is sounds soo mush TUFFER.
Anyway back to the garage !
Posted 22 June 2006 - 11:57 AM
Struggler and Lostit, thanks for the thoughts guys.
Struggler - interesting what you mentioned about the heat/paint burn off in the middle of the mufflers around the expansion chamber - I noticed mine are doing this when it was up on a hoist the other week (only slightly, but definitely noticeable). These are SuperCat mufflers. I am definitely getting ridding of them now.
Lostit - with my previous exhaust system, I too also found it felt better and smoother & revved a lot cleaner with the system fitted (as opposed to open pipes), and open pipes made no difference to quarter mile time at all. I haven't had a chance to run my new setup open pipes though just yet.
Ok, it looks like I'm now chasing the biggest possible mufflers I can fit.
Cheers again all, this is great stuff to read...
Posted 22 June 2006 - 12:19 PM
What's the go with Walker? Are Walker and Lukey one and the same or not? On Lukey's website I can only find a Turbo muffler, no sign of a Super Turbo....
Posted 22 June 2006 - 12:53 PM
Triple pass, I know they look restrictive but they have always worked for me.Also one more question Struggler - the Walker Super Turbo's you mentioned - what design are these mufflers? (triple flow or still straight-through??).
No, I think Lukey and Walker are two seperate entities. I know Walker is a worldwide exhaust manufacturer, believe Lukey is Australian only.
OK, just did a search..... the old Walker brand is now manufactured by Dynomax. Plenty of info on their site.
#21
Posted 22 June 2006 - 01:56 PM
Anyone know of any places in Australia that distribute Dynomax mufflers???
#22
Posted 22 June 2006 - 02:29 PM
Edited by makka, 22 June 2006 - 02:29 PM.
#23
Posted 22 June 2006 - 04:13 PM
#24
_82911_
Posted 22 June 2006 - 04:16 PM
Last time i had the XU-1 out at the track i had at least 5 people come up to me in the pits and enquire about the exhaust. Most saying that it was the best sounding 6 they had ever heard.. "man that sounds tuff" and things like that...
That has NEVER happened before!
The difference between now and then????
A 3" Hooker muffler!!!!
They work.
Cheers Greg..
#25
_MAWLER_
Posted 22 June 2006 - 04:35 PM
How big are the truck mufflers you are talking about Struggler? Is it the length or the width that makes the difference to quietness?
I'd be interested in your tests Brett to see what you're running now and then how the new mufflers make a difference. I'm also looking for a change in actual note, I'd like a deeper sound, these mufflers are a little to putt-putty still.
So the most popular suggestions at the moment are
Dynomax
Redback
Hoooker
Magnaflow
