replaced starter motor with hi torque on 308,new bolts are shorter not confident enough thread to secure should I use old bolts,also will connections be the same battery right side other centre bottom.
starter motor
_pgb73_
, Mar 24 2013 07:04 PM
1 reply to this topic
#1 _pgb73_
Posted 24 March 2013 - 07:04 PM
Posted 24 March 2013 - 08:58 PM
By all means use the original bolts. I wouldn't be keen on using bolts that are shorter.
The end of a solenoid isn't that big so I can't imagine the position of the power connections being that much different from an original fitment solenoid.
