HZ Premier wannabe
#51
Posted 12 June 2013 - 02:51 PM
Plenum is reasonable. Drivers side looks perfect on top when I stripped the paint off. looks good from the underside, no hint of rust at all... But I do worry about what I can't see.
The passenger side is a bit rusty. There were some small holes on top so I cut a section out to reveal a large-ish hole into the underside of the dash. It had all been bogged and sealed up previously which meant no leaks into the cabin, which normally means bad floors... Lucky for me the floors have been kept dry and are perfect. I got a rare spares cowl section so I'll replace all of the rusted plenum bits prett easily.
overall I'd say its better than average.
I'll take some pics next time I'm in the garage.
#52
_mick74lh_
Posted 12 June 2013 - 11:18 PM
Good as. Sounds like with the way you're tearing through it won't be all that long till you're smoothing and prepping it for paint.
#53
Posted 13 June 2013 - 02:51 PM
The passenger side... not so good. However I have seen much worse so I'm not too worried.
#54
Posted 15 June 2013 - 11:15 AM
You're doing some really great work here! Very nice
#55
Posted 16 June 2013 - 10:40 AM
Are you cutting/grinding away from the screen? Hot metal will embed itself in the glass.... wiper blades will show you where.
#56
Posted 16 June 2013 - 09:18 PM
screen is stuffed and is coming out soon, I'm not doing anymore work on this area until the screen is out. I just wanted to cut it now to see what I'll be up against later.
#57
Posted 17 June 2013 - 08:42 AM
Old glass shatters into nasty shards, not great in the case of an acco, so bin that sucker! haha.
Hows the rust around the heater vent opening?
Mine seemed to be localised around that part, and not so much up where yours has been chewed away.
Edited by orangeLJ, 17 June 2013 - 08:43 AM.
#58
Posted 17 June 2013 - 10:46 AM
didn't do much this weekend. busy with other stuff.
finished welding the old lpg fillerhole. Also finished welding the Rad support. came up great, I ground the welds down so it'll be hard to spot the repair after paint.
In other exciting news, My uncle is a mechanic and he had a customer years ago who put a brand new chev crate engine in his WB stato. Leaving the old Blue 308 behind. My uncle has had it under a tarp for a few years. It was running when pulled out, is still in ok shape despite sitting so long. He is selling it to me cheap, comes with a Turbo 400, convertor, pacemaker tri-y's and a felpro gasket kit, acl bearings and rings.
So I'll be giving it a freshen up and whacking that in! stoked!
#59
Posted 17 June 2013 - 11:32 AM
score on the engine deal!
things like that definitely make life easier.
I picked up a recoed 253 with a small cam (had less that 1000kms on it!) for a carton of beer when I first threw the ute together.
Made things much nicer!
#60
Posted 24 June 2013 - 04:07 PM
Did a little bit on the weekend. Was a bit under the weather so only did a few hours...
I basically just cut and patched the rear quarter/ door frame on the passenger side. Plus a bit on the dog leg. With the inner metal pice on the door frame I decided to wire brush all the loose rust off then give it the full KBS treatment. Used the convertor then the black sealer paint. Then welded in the new metal over the top. Through the week I'll hit it with another coat of the sealer paint on the inside of the cabin vent to be sure!
Pics tell the story:
dog leg pics, I forgot to take a pic of the inner panel painted in KBS sealer, but I did seal it all up before welding in the new piece.
#61
Posted 24 June 2013 - 05:33 PM
Yeh strangely around the heater vent is good... there just seemed to be a heap of dirt, leaves and crap up in the corner which has held moisture in that top corner and then caused the rust. I expected to see more around the heater vent opening but I got lucky I guess...
It'll possibly be a TH350 if it is from a WB, they never had a TH400. Could have been put in though.
#62
_Lazarus_
Posted 24 June 2013 - 08:41 PM
I think the sedans look good two-tone. I'd get some stainless strips, paint the body the original gold and the roof maybe cream or Antelope.
http://www.google.co...wQ9QEwBQ&dur=31
White looks a bit plain but I've seen a gold HJ with a cream roof and mags, used to be parked everyday up near the PO Hotel in Mossman FNQ years ago, that looked really sweet.
I
#63
Posted 25 June 2013 - 09:59 AM
#64
_Quagmire_
Posted 26 June 2013 - 03:53 AM
#65
Posted 26 June 2013 - 09:48 AM
#66
Posted 26 June 2013 - 05:25 PM
#67
Posted 27 June 2013 - 09:58 AM
I'm thinking at this stage I will be running a baby cam, maybe a 2000-2500 stall, and no higher than 3.5 gears in the diff. I think ideally I'd like to be runing 3.08 or 3.25's.
Most of my driving will be cruising around the city at 60-80 with occasional highway driving.
#68
Posted 30 June 2013 - 05:39 PM
The TH400 sucks more power than the TH350 too.
#69
Posted 01 July 2013 - 02:13 PM
Bodywork on the rear panels continues... high fill and long sanding block are the order of the day...still need a bit more but they are getting close to straight.
Started bolting the front on to see how it all lines up.
Drivers side gaurd is the Taiwanese one, needs some work around the top corner, the gap is rubbish and the top inside bolt doesn't line up. will have to cut the nut off, drill a new hole in the correct position then weld a new nut on.
It will be ok with some work so I suppose I'm happy enough with it.
Passenger side is great. Nose cone and rad support are great. pics tell the story:
Here is where I don't like the gap and the bolt hole on the inside:
Front trial fitted
only half bolted up on this side:
#70
Posted 01 July 2013 - 03:24 PM
Apparantly the 400 has a 4 stamped on it somewhere too? Doing a bit of reading I found that the 350 and the 400 are actually based on entirely different designs. The 350 being based on a powerglide while the 400 was a new design at the time. interesting...
They are easy to pick. One way to to try and pick it up, you'll soon know! TH400 is way heavier.
Another way is the TH350 is cable kickdown, TH400 is electric.
Pan shape TH400 is HUGE , TH350 is a small pan.
Easiest though if it is a Holden or Commodore box is the extension housing. TH400 is a short stubby extension, about 4" long with the rear engine mount under the extension. TH350 has about a 6" extension and the rear engine mount is on the body up behind the pan.
Another is the rear yoke, TH350 is the same yoke as a trimatic or Aussie 4spd, TH400 is a big monster John Holmes looking thing almost as big as your wrist!
#71
Posted 30 July 2013 - 09:54 AM
Well I got the Engine on Friday night and pulled it down. Very disappointed. It is rooted.
As you can see in the pics water got into cylinder 1 and 7 whilst the engine has been sitting around.
It was supposed to have been covered up but obviousely at some stage it has been out in the weather.
Anyway Good news is My uncle will probably help cover the cost of getting it sleeved or maybe sourcing another Block.
The Machinist we are using says he has a spare turbo pattern block so if it's the right price I might get that.
I'll have a better idea later this week when the engine is dropped off to him.
Pics:
and my nice new 560kg engine stand:
#72
Posted 06 August 2013 - 10:12 AM
Looking into maybe getting running gear from a 5L vn-vr commo or something. Might be best bang for buck I'm thinking.
#73
_mick74lh_
Posted 06 August 2013 - 11:35 PM
Thats pretty disappointing but I guess part of the lucky dip that is buying an old engine. VN-VR 5 litre would be great but I'd be prepared to rebuild that as well as they're not exactly that new any more.
#74
_Quagmire_
Posted 07 August 2013 - 01:45 AM
mine is 60thou over and needs a crank grind and bearings
the rings etc look ok but so i might save it
if your only going small valve heads it may pay to chase up a 253....they can be had for nicks....matter of fact i'm swapping some parts for a 20 thou over one this weekend
i'd keep all the brackets/sump off the old one especially if you intend going vn-t commie
#75
Posted 07 August 2013 - 12:05 PM
Theres a VR V8 on ebay at the moment that has supposedly done 140,000 k's. That's damn low!
Would be perfect I reckon.
I'm waiting on my uncle at the moment, I originally got the 308 of him to pay off $700 that he owed me, seeing as the 308 is junk he is now trying to get me an injected motor from some of his wrecker contacts.
that way I just give him back the 308 and he gives me the injected motor and we are square.
Mixed feelings about getting a wrecker sourced engine tho... on the plus side it would come with a warranty, I'd ned to get it in the car quick so I can fire it and test drive up and down the street!
