Fingers crossed then. Would you run a manifold on it for carby? Or go with the injection?
HZ Premier wannabe
#76
_mick74lh_
Posted 07 August 2013 - 01:40 PM
#77
Posted 07 August 2013 - 02:05 PM
#78
Posted 27 August 2013 - 01:52 PM
VS Clubsport engine, Apparantly low k's, leb spec paint job, extractors, ECU, Loom, Turbo 700!
#79
Posted 29 August 2013 - 07:05 AM
#80
Posted 10 September 2013 - 01:47 PM
Cleaned up the Gilmar drive
Painted the Block and fitted the HZ sump
Also did the headers in hi temp paint
Engine coming out:
I'm cleaning the whole front end at the moment and I might paint the firewall, it is really clean already but I think it might look funny if I paint the inner guards and the firewall paint still looks a bit old.
that's all for the moment
#81
_mick74lh_
Posted 11 September 2013 - 08:56 PM
Engine looks sweet. I like how you've run the leads.
#82
Posted 16 September 2013 - 05:59 PM
I pressure washed the chassis rails and gave them a quick scuff up with the wire wheel then just squirted them in black enamel. you can see I haven't bothered with the suspension yet I kinda just sprayed around it. That will all be coming off for some tlc later...
sat the engine in place but I still need to sort out the trans cross member. should have that sorted soon.
pics:
#83
Posted 23 September 2013 - 05:33 PM
Also been playing around with the trans crossmember.
I was thinking of just getting a CRS unit but when I had a bit of a look at the old trimatic one i got crazy ideas:
Looks like a bought one!!
I know welding a crossmember is frowned upon by engineers/RWC mechs but its cheap (had metal sitting around) and will look like a factory unit so nobody will notice hopefully.
Its 3mm plate so its damn strong, probably stronger than it was before!!
#84
_mick74lh_
Posted 23 September 2013 - 10:52 PM
Very nice. A lick of paint and nobody will notice.
#85
_Quagmire_
Posted 24 September 2013 - 03:13 AM
#86
Posted 24 September 2013 - 09:01 AM
The trimatic crossmember I think is too wide for that, by the time the z bar bit hangs off the back of it, the front edge will be hitting the pan on the tranny I reckon.
I was considering buying a t400 statesman x member that the wrecker had but he wanted $200 for it!!
I thought I'd try this first... if I have any drama with it then at least it has only cost me time to knock it up...
#87
Posted 03 February 2014 - 03:55 PM
I've been working on getting the engine running mostly. I got a Facet lift pump and a VL Commodore High Pressure Pump, Also went to the self serve wreckers and cut out a relay/ruse box from a VS Commodore.
Initially I went about wiring up the engine and relay box in a temporary fashion, There were wires all over the place and it was very messy. But my theory was to fire the engine and make sure everythin worked before I waste any time making the wiring tidy.
I didn't want to make it all neat only to rip it apart if I ran into any issues... Which I did...
Same went for the Fuel pump mounting, I just kind of plumbed it all up and left the pump hanging under the tank, now I have it running I will sort out mounting brackets and fit properly.
So when I initially tried starting it I had spark and fuel, after fiddling around checking fuel pressure and replacing the PCM computer I finally Learned that I needed a re-flashed Memcal with the security program removed.
Finally I ordered a performance memcal with no vats from Ebay and the thing started at last!
It's just running straight out the extractors and not got a radiator at the moment so I can only run it for a few seconds, but it sounds tough without an exhaust, wish I could leave it like that! Mind you it will sound really nice with mufflers when I get to that stage.
So now that is runs I've neatened up the wiring and mocked up the battery and Relay box where I want it. I still need to fab a proper battery tray and bracket but it will basically sit as pictured.
I ran most of the wiring out of sight so it should look pretty neat.
Next on the list is get the thing moving. I would like to be able to shift the car around under it's own power, so for the moment I'll weld up the old trimatic tailshaft as a temporary unit and get hold of a nice Ebay shiny radiator. That should be enough so I can drive it in and out of the garage easily. Then I can start making a mess with more bodywork again.
#88
Posted 23 September 2014 - 01:54 PM
#89
Posted 23 September 2014 - 04:13 PM
#90
_Macca97_
Posted 23 September 2014 - 04:36 PM
looks great, will be one great cruiser
#91
Posted 24 September 2014 - 12:19 PM
Ain't it a great feeling to get something accomplished??? Just one thing at a time and it'll all get done in the end.
Oh, you have my wheels! I need to go up in diameter within three years cause the 235/60/14's are VERY thin on the ground (just fitted four new ones and usually get three years outra them), gunna pick up exactly those rims from Summit... don't tell the missus!
#92
_Lazarus_
Posted 24 September 2014 - 03:19 PM
There are heaps of different brands of new 235 X 60 X 14's on ebay last time I looked for around $130 each.
#93
Posted 25 September 2014 - 03:18 PM
Unfortunately freight kills that idea.
#94
_LJdave_
Posted 26 September 2014 - 02:22 PM
I like the way this is coming along. good ol home engineering skills at work here
cant wait to see the result, theres some real tuff looking H-J-X-Z's creeping round
melbourne a mate of mine has a HJ 355 that likes a sniff of nitrous accasionally
#95
Posted 26 September 2014 - 05:13 PM
thanks guys! I'm setting a goal to get all the bodywork done in the next 2-3 months, I'd like to be spraying colour on the car this side of xmas before it gets too hot!
I'd love to get a nice 28-30 degree spring day, spray the car in the shed then puch her out into the sunshine to dry!
#96
_Macca97_
Posted 26 September 2014 - 06:18 PM
i said the same thing haha, 18months took for the body work than sprayed it in the shade on a 40 degree day, haha, hope you can stick to your goals cause i sure cant,
youve done an awesome job so far.
#97
Posted 26 September 2014 - 06:25 PM
#98
Posted 27 September 2014 - 09:52 AM
I had to replace some rusty sill a coupla weeks ago... over winter. Mrs thought her old hairdrier was rooted so bought a new one, I 'salvaged' the old one and it works fine, and perfect for lousy day painting. Fishoilene inside and PA10 outside will keep it like new for years to come.
#99
Posted 29 September 2014 - 10:23 PM
#100
Posted 22 December 2014 - 04:29 PM
Any updates mate?
