* * * * * 1 votes
LC GTR - FATHER AND SON GROUND UP RESTORATION
754 replies to this topic
#251 _gorto_
_gorto_
Posted 04 September 2013 - 12:00 PM
EDIT: The wheels were bolted onto a standard length banjo in this picture.. we just put them on for a picture (have got a custom diff made)
Edited by gorto, 04 September 2013 - 12:01 PM.
#252 N/A-PWR
  • 9,636 posts
Posted 04 September 2013 - 12:02 PM
Nice GTR Ryan,
Shiny Mags too, Great Job. Dave I
#253 _gorto_
_gorto_
Posted 04 September 2013 - 12:47 PM
Thanks Dave
Here's a picture of the torana on the rotisserie that we got off ebay
#254 _gorto_
_gorto_
Posted 04 September 2013 - 12:50 PM
Opinions on the exhaust tip anyone? not sure..
#255 Ice
  • 15,199 posts
Posted 04 September 2013 - 01:02 PM
Look good to me
#256 _gorto_
_gorto_
Posted 04 September 2013 - 01:05 PM
The injection has been pulled apart by the engine builder and ported, still got a little bit more to go
Heres a picture of the head after porting
#257 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 04 September 2013 - 05:42 PM
looking good, i should have bought one of those manifolds instead of webers..
#258 _gorto_
_gorto_
Posted 04 September 2013 - 09:44 PM
manifold cost is similar, but then you have to factor in fuel delivery, wiring, sensors, cpu etc. gets real expensive, real quick.
#259 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 04 September 2013 - 10:19 PM
just had a look back through the earlier pics, fair bit of meat take out of the manifold! what head are you using?
#260 _gorto_
_gorto_
Posted 05 September 2013 - 08:55 AM
Yeah i know right! He laughed at me when i dropped the manifold off, he said "well that will be a bit lighter when you get it back"
Yella Terra 12 port alloy head
#261 orangeLJ
Posted 05 September 2013 - 09:04 AM
Have you decided on an achievable compression ratio with the YT head?
#262 _gorto_
_gorto_
Posted 05 September 2013 - 04:22 PM
What do you mean achievable? I think we could run what ever compression we wanted, just depended on the fuel we were prepared to use
Decided to keep it legal and run pump fuel instead of avgas, comp will most likely be 10.5, any higher and there will start to be slight detonation
#263 _gorto_
_gorto_
Posted 05 September 2013 - 09:29 PM
Heres the front end assembly to get the 16x7's to fit
2inch drop spindles (so we can still run standard length springs but have a lower ride) and dba gold ford leyland p76 disc (brings wheel-track in 7mm each side) with a custom made spacer to fit the bearing
hydraulic clutch set-up that we used, had it lying around from dads old sprintcar
A9 altrac powder coated chrome molley adjustable arms
Custom length Borg Warner with chrome molley tubes with billet 28 spline axles and commodore brakes
Harrop/Eaton truetrac diff centre
Re-priming the engine bay, for the last time (i mean it this time!)
#264 _gorto_
_gorto_
Posted 05 September 2013 - 09:33 PM
engine bay once primed
Sanding the floor with his fathers day present between his legs haha
#265 _Macka_
_Macka_
Posted 05 September 2013 - 09:37 PM
Brilliant. I can't wait to see this car come together. The attention to detail and quality of components is going to make this an amazing car. Keep up the great work.
#266 _gorto_
_gorto_
Posted 05 September 2013 - 09:39 PM
Thanks Macka,
Have you ever taken your car to toranafest?
#267 _LS1 Taxi_
_LS1 Taxi_
Posted 05 September 2013 - 09:53 PM
Your old man looks like a dude.
Great build - very interesting too :)
#268 _gorto_
_gorto_
Posted 06 September 2013 - 08:16 AM
haha he is, he was posing for a picture for one of his mates to prove he was working on a sunday!
#269 Redzone
Redzone
  • 517 posts
  • Car:Mini torana's - Gemini coupe 10.787@123mph, log booked Group A DOHC Gemini under resto..
Posted 06 September 2013 - 09:50 AM
If you have a united servo nearby with e85 on the pump, consider running that instead, you can run 13-14:1 on e85 in an n/a motor quite easily, especially as you are running programmable efi!
#270 _Hamster_
_Hamster_
Posted 06 September 2013 - 12:26 PM
lewking goood man.
#271 _AD_75_
_AD_75_
Posted 06 September 2013 - 06:47 PM
If you dont want the hassels of setting up a fuel system to run E85 another good alternative for united Pump fuel is P100. Its their 100 octane ethanol blend fuel (5% eth)
#272 orangeLJ
Posted 06 September 2013 - 07:40 PM
If its a new yet alloy head, it will be open chamber, limiting the compression you can run without running into dramas or welding up the combustion chambers
#273 _gorto_
_gorto_
Posted 06 September 2013 - 10:36 PM
unfortunately no, we live in a rural area, + there are some problems with efi, its harsh on everything and engine builder said even driving it once a week would only just be enough to keep it from eating away at it. He wanted me to run through pump fuel through it to clean it nearly every time too i think, which i don't have the time or patience to do. And when i leave school and g to uni the car will stay here at the house so it wont get started at all unless i get dad to do it..
It wasn't a new head, bought it 2nd hand off a mate
dad tried this in his 11.2 comp 588c.i big block (normally uses bp 98) and didnt think it was as good, maybe just in his head though
#274 Redzone
Redzone
  • 517 posts
Posted 07 September 2013 - 12:12 AM
Fair enough. There are a lot of myths with e85 btw. I'm considering changing my turbo gem over to it but i'd have to bring the comp up greatly as it's only 7:1 currently.
#275 _gorto_
_gorto_
Posted 07 September 2013 - 11:26 AM
The engine builder has built many engines on e85, loves it, but only if you have the time to maintain it and keep everything nice.
Theres an extremely quick full carbon fibre wrx hill-climb car here. He recently changed over to e85,.did it all properly fuel system and injector wise, but says its hard to maintain everything
