Have you had the engine in the car? Just noticed the ATI damper and the drive to run the oil pump stick out a long way, will it all fit in with the radiator?
regards.
Posted 15 November 2018 - 12:02 AM
regards.
Posted 15 November 2018 - 11:27 AM
regards.
No. I'm not too confident it will clear either.
Not 100% sure what to do in that regard. Whether there's room to space the engine back a fraction, or change the radiator setup. I've talked to PWR about doing an internship with them as part of my degree, perhaps I'll have to design myself a custom radiator and mounts lol.
Posted 17 November 2018 - 02:59 PM
An internship could work for you.
I hope the degree is going well.
Posted 19 November 2018 - 03:07 PM
Cheers Warren, it's going well!
Posted 21 November 2018 - 11:46 PM
I suppose the LC grille doesn't go back as far as the LJ grille as it is flat, might be some room to bring the radiator forward, fiddle around with the support panel, there is always a way of doing things. look at the crazy way intercoolers get mounted and in very tight spaces. regards
