V8 lc4dr
#51
Posted 12 April 2014 - 08:18 PM
Would think it would be heavier with the V8.
Cheers Bullet
#52
Posted 12 April 2014 - 08:25 PM
The Red 308 V8 is only 22Kg more Heavier than the Red 202 6Cyl
You would think that if GMH rego one back in 1972, it would open the door to V8 LJ. I thought ???
#53
Posted 12 April 2014 - 08:45 PM
Was there a news paper artical or anything recording the rego or was is hush hush at the time?
Cheers Bullet
#54
Posted 12 April 2014 - 08:48 PM
I have a copy of the original rego papers from Vic Roads for LGN307, I own the Number Plates, the Engine was a QT Engine, says 308 and says Eight in Engine part on rego papers, and 4.0" Bore and 51 HP for Horsepower
Red 202 6 Cyl HP on Vic Road rego papers is 31 HP
Edited by xu2308, 12 April 2014 - 09:00 PM.
#55
Posted 12 April 2014 - 09:30 PM
What you have you would think would be enough proof, in my eyes anyway.
#56
Posted 12 April 2014 - 09:34 PM
#57
Posted 12 April 2014 - 09:40 PM
I think we are talking BHP from that time frame I reckon, that's why its 51 HP (BHP my bet)
It says Rego by GMH and it says its a Brand New Car on the Rego Papers
#58
Posted 13 April 2014 - 10:25 AM
Those HP figures are only RAC taxable horsepower, nothing to do with the HP that the engine produces.
It is calculated by using the bore dimension & number of cylinders only.
See here:- http://en.wikipedia..../Tax_horsepower
Dr Terry
#59
Posted 13 April 2014 - 10:50 AM
Thanks Dr Terry
#60 _Lazarus_
Posted 13 April 2014 - 03:09 PM
I find that very hard to believe.
Can anyone confirm this ? I thought 6 was approx. 180kg and V8 235kg. (these figures are taken without ancillaries I gather ?)
#61
Posted 13 April 2014 - 07:04 PM
#62
Posted 15 April 2014 - 08:31 AM
GM-H's official weight difference between a 6-cyl HT/HG Kingswood & the 253 V8 version was 90lb (41 kg). This would include all ancillaries, flywheel & clutch etc. In the HQ series this difference was listed as 170lb (71 kg), but this would have included the Salisbury diff as well (HT V8 had a Banjo)
An XU1 engine would probably weigh slightly more than a stock 186/202, so when you consider the 3 carbies & the 2 exhaust headers, 35 kg would be an intelligent guesstimate. I find the 22 kg figure a little difficult to believe.
I was talking to Harry on this topic back in the 90s & he said at the time that his XU-1 V8 prototype was lighter & handled better than a stock 6-cyl XU-1. He said this was because the centre of gravity of the V8 was further rearwards than the 6-cyl & that he had fitted a fibreglass bonnet, which saved more weight than the difference between a 6-cyl & a V8.
Dr Terry
#63
Posted 15 April 2014 - 10:40 AM
#64
Posted 15 April 2014 - 02:31 PM
Hi Al, if vic roads except Dr Terry's press release a 308 will make it easy, should be able to go to 336ciIf its 41kg, that is even better, need more weight to get the LJ up there to get a 308 V8 for rego status
1102 x 5 = 5510cc which converts to approx 336ci.
Cheers Bullet
#65
Posted 15 April 2014 - 04:49 PM
Cheers Bullet
It's not 'my' press release, it is an official GM-H press release from the day of release of the original LC XU-1.
Dr Terry.
#66
Posted 15 April 2014 - 05:41 PM
remember you are talking LC for you, i believe the LJ are different weight to the LC Torana's
#67
Posted 15 April 2014 - 06:07 PM
Al, I thought they might group the two together but after reading one of the links that Dave put up I would say I'm wrong.
Guys like yourself know there are many many differences between the two but the goose behind the counter at vic roads wouldn't have a clue. I suppose all they see is that one is an LC model and the other an LJ, they probably don't know the body shap is the same!
Cheers Bullet
#68
Posted 15 April 2014 - 07:50 PM
#69
Posted 29 May 2014 - 03:10 PM
Hey Guy's, just let ya know that Vic Roads approved my application to fit a 327ci chev in my LC.
Thanks again Dr Terry for the press release, i think it made all the difference.
Cheers Bullet
#70
Posted 29 May 2014 - 03:51 PM
That's got to be good news for a few people especially you
#71
Posted 29 May 2014 - 04:13 PM
Great News, Vic Roads 3 Cheers
#72
Posted 04 May 2015 - 09:29 AM
Looks like every thing I have checked for LJ TARE weight is
LJ XU1 is 1048 kg in The Holden Torana GTR-XU1 Book (The CAMS Doco stuff)
Spotlight on Holden Torana Book weight for
LJ XU1 is 1099.6 kg
Torana Tough Book from a sales Ad thingy from back in the day
LJ GTR is 1058.6 kg
Now the NCOP says the Original Tare weight has to be over 1100 kg to fit a 308 V8
Now if the LJ XU1 was Heavier than the LC XU1 then why does the weight not say this in these publications
The GMH Press Release for the LC XU1 says the Approx Kerb weight 2430 LBS that equal 1102.23 kg. So that is over the NCOP to get a 308 into a LC Torana, now if LJ XU1 is heavier then we need the GMH Press release for the LJ XU1 that includes the kerb weight to say that, the LC/LJ is the same as in body type etc, but will the engineer accept that for the NCOP thingy ???.
Edited by xu2308, 04 May 2015 - 09:32 AM.
#73
Posted 04 May 2015 - 12:13 PM
The problem is that Kerb weight is more than tare weight as it represents a car with a full tank of fuel. Tare weight is with 10 litres of fuel. All mods are/should be based off tare weight not kerb weight. Been down this path many a time before :-)
Edited by Redslur, 04 May 2015 - 12:14 PM.
#74
Posted 04 May 2015 - 02:59 PM
Virtually all weights that GM-H have published in their literature since 1948 are kerb weights.
Dr Terry
#75
Posted 04 May 2015 - 08:52 PM
Seems to me NCOP set the scale for 1100 kg for 5.0 Litre, So LC/LJ can not have a 5.0 Litre put in them, Crazy when there is a Chassis Kit made for that type of application and a upgrade to LX Discs and LX Calipers to handle the breaking and the LC/LJ is very close to the weight of 1100 kg any way.
