6 Cyl Trimatic to v8 Trimatic
column trimatic v8 auto gearbox
1 reply to this topic
#1 _Kal05_
_Kal05_
Posted 16 May 2013 - 12:49 PM
Hi
Just wondering if I convert a 6 Cyl column shift trimatic to a 253 V8 with Trimatic,
will the 6 cyl Column Shift and linkages work with the V8 trimatic box??
car is an LH Torana.
Kal
#2 yel327
  • 13,717 posts
Posted 16 May 2013 - 04:16 PM
Yes, as long as the trimatic you get is a RH shift one. They are the same basic box, just a different bellhousing and pump on the front. You'll need a V8 banjo and V8 tailshaft too, although the 6cyl stuff will work you are better off with the bigger unis. Rest is the same.
Also tagged with one or more of these keywords: column, trimatic, v8, auto, gearbox
