Tandem versus Tri axle trailer - recommendations please
14 replies to this topic
#1 _ht467_
_ht467_
Posted 16 May 2013 - 08:51 PM
Hi,
Have sorted out most of the trailer as per the other thread but seem to be going around in circles with this one. I feel its a pretty improtant decision and i'd like to get it right.
Intention is to build an enclosed car trailer which will be around 6.5 - 7.0 metres long (Plus draw bar) Is to carry the race car, tools, spare gearbox, diff e.t.c which i expect to total around 2.0 tonne. (Trailer will weight somewhere up to 1.5 tonne)
I've got different camps recommending different things and was after some opinions or feedback from people that have used either or both.
Have been told will need a tri axle due to the weight and that they tow better and are more stable.
Have been told not to get a tri axle as they dont turn as well, scrub out tyres and you are dragging around the extra axle for no real benefit (At this weight)
Have been told a tandem will be fine with the newer type rocker suspension versus the old slipper type and they can be rated to 3.5 Tonne
Have also heard of stories of constantly blowing tyres on a tandem due (assumed due to weight)
Again, any feedback is much appreciated.
Regards Jeff
#2 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 16 May 2013 - 09:07 PM
Tyres would not be an issue on a tandem if you run light truck tyres.
#3 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 16 May 2013 - 09:16 PM
Our car trailer is a tandem, full chequerplate floor etc (not a pure car trailer, also used for carting general shit around). We just run light truck tyres on 14x7 HQ rims, never had any issues blowing tyres. Trailer is quite regularly used to tow full roadgoing cars, so well over 2 tonne including the trailer...
#4 _Bomber Watson_
Posted 16 May 2013 - 09:25 PM
THe four light truck tyres on my tandem car trailer are rated at 3650kg combined.
The springs/axles are rated around the same.
Triaxle will scrub like a mafaka, chew your yard up and dont even think about trying to move it around by hand.
#5 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 16 May 2013 - 09:38 PM
^^ What macka said.
I've towed my hatch across the paddock twice now and i helped a mate bring a brock commode and spare shell back from sydney. We towed his car on one trailer over and bought a trailer there for the two car return trip.
With the exception of a wheel falling off once ( operator error) all trips were completed at high pace with no issues. I'd take a tandem over a tri for every day use all day long.
leave the tri's for machinery or specialty loads.
#6 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,428 posts
  • Name:facebook dave
Posted 16 May 2013 - 09:56 PM
^^ What macka said.
welby
if you had put the hatch on the front of the trailer
and put the original tow car on the trailer
the trip would have been much faster!
just my opinion of course
#7 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 16 May 2013 - 10:24 PM
I appreciate you thinking that, but trust me, it was fast enough.
48 hours perth to bathurst, 44 hours return.
#8 _ht467_
_ht467_
Posted 16 May 2013 - 10:31 PM
Thanks all for the feedback.
Luv it, 44 / 48 hr runs including sight seeing photos!! :blink:
#9 _DocDamage_
_DocDamage_
Posted 16 May 2013 - 10:46 PM
I have an unsprung triaxle & I love it. It's the best towing trailer I've used & no problem with turning. The extra tyre is an obvious extra cost but its not like i tow on a daily basis. As for moving it around, it sits nose heavy on the front axle & I can push it around the yard with a stock car onboard easier than pushing the stock car on its own.
#10 RallyRed
  • 8,213 posts
Posted 17 May 2013 - 08:30 AM
Hi mate....just re the dual axle setup........we have had big caravans for years, most around 2.5 tonnes total weight ( van + all the crap, water, personal stuff  etc). As you would see out on the road 99% of all big vans are dual axle....only the real big ones ( say over 26foot long ) seem to have tri-axles. To me that seems to suggest that 3 axles are not required for that sort of application.
I'd be thinking that any extra weight in the trailer itself ,is weight you don't need.
As soon as the total weight of the trailer + load exceeds 2500kg, then you exclude a whole lot of tow vehicles from legally towing it.
Irrelevant of course, if you have a Landcruiser or Furd "F' truck or similar....but something to consider.
IMHO
#11 orangeLJ
Posted 17 May 2013 - 11:16 AM
Rising from the dead? havent seen your username pop up in a loooooong time.
#12 yel327
  • 13,788 posts
Posted 17 May 2013 - 03:26 PM
Hi,
Regards Jeff
What are you going to tow it with? Might sound like a silly question but with the length you are talking about, and how you intend to load everything on it, it will probably have a pretty big towball weight (especially with tandem axles) which can have a large impact on the tow vehicle. Some of the current crop of Asian trucks with over-the-top towing claims can't carry much more than 4 x people and their luggage with say a 350kg towball weight, as it grossly reduces the load carrying capability of the truck (eg Nissan Navara STX auto carrying capacity is 776kg, but reduces by 250kg with 350kg towball weight). So a tri-axles may help reduce the towball load to an acceptable value.
Note also that you will have a little bit of trouble finding rims capable of much more than 700kg per rim, depending upon the stud pattern you run. If you use a Ford stud pattern the 2WD Hilux rims will do the trick, but if you go Commodore you'll struggle as only the 15x7 Crewman and tonner rims are rated for 750kg (so 3 tonne with tandem). Going to 3.5 tonne may be an issue with tandem (875kg per wheel) without going to something like a 6 stud and running 15" Sunraysias with light truck tyres (at least 116 load index).
The other thing to remember is that you are adding up the total weight of the trailer, car on the trailer and the extra stuff on the trailer and coming up with 3500kg. The axles and wheels only have to carry that total weight MINUS the towball load, so if that is 350kg then the trailer suspension and tyres only have to be good for 3150kg as does the tow vehicle.
#13 _ht467_
_ht467_
Posted 17 May 2013 - 10:10 PM
Hey mate,
All valid point and i think have taken most of them into consideration. Is a 200 series Landcruiser so towing capacity is 3500kg.
As for loading will be a case of juggling things around to get enough weight on the ball to make it behave while towing. May even end up with all the tools and spares at the front and even the car on backwards.
Am happy to go to 6 stud wheels and will defenitley be 8 ply light truck tyres.
Thanks for the info, Jeff
#14 yel327
  • 13,788 posts
Posted 18 May 2013 - 10:52 AM
You'll probably need airbags in the back of the 'cruiser to tow that much. They only have coils, so can't load as much as a leaf sprung rear end without help!
You are also going to have to watch the vehicle's load, I think these are only good for 690kg which includes passengers and luggage and fuel and towbar and bullbar etc. Take say a 300kg towball load off and you are left with 390kg. Remove say another 70kg of fuel, 60kg of towbar and you are left with 260kg. Noty much left if you stick 2 x 80kg people in the car!
Sahara only has 635kg capacity so even worse!
Edited by yel327, 18 May 2013 - 10:54 AM.
#15 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 22 May 2013 - 08:38 PM
A tri axle traler will eat tyres quicker than a twin axle. If you really want the ultimate, consider a dog trailer with 9.5R17 tyres all round. Better load capacity, better brake potential, less tyre wear, better steering and better ride quality. That's what I almost got built until I bought a truck with a 16 foot long tray.
