original a9x motor
92 replies to this topic
#76 _hutch_
_hutch_
Posted 01 June 2013 - 09:32 AM
Great reading,surely there must be somone around who played with these engines during development ect,we are only talking around 40 years ago.for example I went to an old engine rally celebrating 90 years of Ronaldson Bros & Tippet back in the 90's and the organisers had got workers who where there in the 20's and the amount of info these old guys had stored away in the grey and balding heads was amazing,at that time that was over 70 years in the past
#77 TerrA LX
Posted 02 June 2013 - 12:47 PM
^ I have spoken to "someone from around this time" and they tell me that a part only had to be "available" thru Holden to be listed as a part etc... it did not necessarily have to be on the shelf...
#78 _Got1UR1_
_Got1UR1_
Posted 02 June 2013 - 12:59 PM
How many MC7 gearboxes would Holden have kept "on the shelf" ? Blister patches for this box ? Possible examples of this theory?
#79 yel327
  • 13,633 posts
Posted 02 June 2013 - 02:19 PM
Same with 12 bolt axles for HK-HT. By special order only.
#80 _LXSS350_
_LXSS350_
Posted 03 June 2013 - 02:23 AM
Perhaps, but its just something that would be good to prove.
I can't say for sure if the A9X crank, cam and piston pins are different (or what is different about them) as I have never stripped or rebuilt an engine out of one, but I have plenty of std 308 engines in bits to compare should someone be rebuilding (refreshing) an unmodified factory A9X engine.
I have always thought the only real difference between it and any other 1977 308 was the lack of engine fan.
But then again been wrong many times before.
#81 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 03 June 2013 - 10:20 PM
There is certainly a lot of speculation and guessing going on here with this one. Lets look at it logically. It's been covered a lot of times now over and over. Australian Muscle car magazine has just released a compilation of the V8 Torana stories that should help along the way though.
Firstly, what were the A9X and L34 before it built to do? They were built to homologate the parts required to put a race car together within the rules, but in such a way Holden only had to develop the parts that were not free to change.
With the L34 they put all the good bits in the engine but didn't worry about all the parts that were free to change. A good example is the exhaust past the first break.
With the A9X, it was an evolution from the L34, so all they needed to do was fix the problems they encountered with the L34.
So, why does the A9X have a different crank to any other 308 of the same period while the L34 had the same crank as any other 308 of its period? Logic would suggest the crank was improved with the release of the A9X. Holden only had to do just enough to comply with the rules, and to save money they only fitted it to the cars they had to.
Holden also produced a list of parts required for race teams that were converting their L34's to A9X spec, this had updated part numbers for cranks and blocks.
As for the cam, why is it different to the cams in any other 308 of the period, while the L34 shared the same cam as any other 308 of its period? Why bother changing it when the cam was free to change for race teams?
I was told two reasons many years ago, the first being the flogging Holden had copped in the press over the 308 with ADR27A, and secondly the journals had been made bigger to allow larger journal cams to be used in race cars.
If it was made to fix ADR27A issues, then why not extend it to the rest of the range? The timing on the A9X was slightly different too, so perhaps it was a matched set for their so called performance car? Maybe they wanted it to stand out a little? All press reports of the day suggested the engine felt much stronger than other 308's with ADR 27A they had driven. Was it designed to make the most of the 2.6 diff? Perhaps, that makes sense too, maybe it just so happens it was a good match and they inadvertantly fixed the issues with ADR27A with the same stone? The fact is though, it is different to the standard 308 cam of the period.
#82 yel327
  • 13,633 posts
Posted 04 June 2013 - 07:34 AM
So the crank on an A9X is a rope or neoprene rear main seal? AFAIK L34 were neoprene.
#83 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 04 June 2013 - 11:12 AM
From my memory it was rope in mine, and mine hadn't been out before. My 253 SS of the same build date was rope also.
#84 _The Baron_
_The Baron_
Posted 04 June 2013 - 01:27 PM
Rope for mine too. I must get around to looking at the crank too as it is out of the car at the moment. Cam was long gone when I got the car.
#85 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 04 June 2013 - 02:25 PM
I like your thinking Red.
Many times we miss the 'big picture' when trying to work out the factory intentions.
#86 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,418 posts
  • Name:facebook dave
Posted 04 June 2013 - 05:23 PM
rope seal for mine too!
original block
#87 S pack
  • 15,721 posts
Posted 04 June 2013 - 08:35 PM
GM Parts & Accessories News 7th November 1979.
L34 High Performance parts serviced for LX Torana Performance Equipment Package Option A9X.
GMP&A have released the following L34 high performance parts for fitment to LX Torana vehicles equipped with the A9X option package.
92005960  Crankshaft
92011190   Pistons & Rings with Pins
etc etc etc
The high performance parts will enable owners of LX Torana models equipped with the A9X option, to increase performance of their vehicle for trial, rallying and other competitive sports. So let prospective customers know that the above L34 option parts can be supplied.
Just on a side note. Another GMP&A News from 1980 lists the L34 replacement block (lip seal type, presume that's a neoprene type seal) fitted with pistons as currently available.
Nice summation a few post back there Red, however it still leaves me wondering why GMH would send out the above info to the Dealers with the crankshaft mentioned as being an L34 part and advising that it can be fitted to LX A9X as a performance upgrade if the A9X L31 engine already incorporates said crankshaft?  Admittedly this advice was sent to the Dealers in November 79 and the A9X's mainstream racing career was near it's end, so I'm thinking maybe GMH just wanted to move their remaining stocks of L34/A9X performance parts from the shelves.
#88 _LXSS350_
_LXSS350_
Posted 09 July 2013 - 01:14 AM
Reading in a magazine Harry Firth gives his explanation for this. He says that the front of the L34 camshafts used to break so in the A9X they made the cam 1/8" bigger in the front section. The L34 crankshaft also showed weakness so with the release of the A9X the crankshaft was made with a thicker web between the No1 main bearing and the No1 big end bearing. So it was done for Homologation for race teams to be able to have stronger bits. Happy with that explanation and that all makes perfect sense why the A9X had different part numbers.
#89 _outer control_
_outer control_
Posted 15 July 2013 - 09:44 PM
Curious to know at what races were crankshaft and cam breakages attributed to DNF ,s in a L34
Edited by outer control, 15 July 2013 - 09:45 PM.
#90 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 15 July 2013 - 09:53 PM
You'd need to know every meeting, results and causes of DNF's for that. I would suggest Harry and perhaps other teams were finding cracks or other issues when they were pulling engines down after race meeting. They wouldn't just change it for the sake of changing it.
#91 _LXSS350_
_LXSS350_
Posted 16 July 2013 - 12:39 AM
There was so many blow-ups,smoke signals and dnfs over the period you would have to review each race for the exact cause. Engine,gearbox, diff and brakes where the main L34 gremlins. Thankfully sheer numbers meant Torana fans increased our chances. The rice bubbles L34 torana's certainly had a tendency to be a hit and miss affair. I know it used to be gut wrenching to see the reliability issues put out what looked to be a winning drive.
#92 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 16 September 2013 - 09:39 PM
  Reda9x is on the money ..
#93 yel327
  • 13,633 posts
Posted 03 March 2016 - 06:20 PM
Oldish thread I know, has anyone found anymore info about the A9X camshaft part number 9933211?
I note it was removed from parts history as early as July 1978.
The camshaft having a bigger nose makes a lot of sense. Note that from HJ onwards the 308/304 all used the same camshaft timed at 0deg (prior to HJ the 308 used the same cam as a 253 but it was advanced 5deg) right through to the end of VL 5.0 with carby. The only GMH produced engines to get a bigger cam were the A9L engines, the rest all got the same camshaft which incidentally has the identical grind to the HK-HQ 350 camshaft - the GM general performance camshaft. This cam grind was good enough for the L48 350/300 engine with Fuellie heads so is a pretty decent cam spec for a 308 with smaller valves and smaller ports and 42ci less than the L48. I can't imagine the A9X needing anything different timing wise, unless it was bigger as mentioned a few posts up or maybe it had extra advance ground into it rather than using a different cam sprocket?
Funnily enough too the part number of the post HJ 308 camshaft 2825882 sits smack bang amongst other parts from early HG which is when Harry was first playing with the 308 engine for a lightweight Bathurst HG GTS, this is when he first developed his wish list for the 308 much of which became the L34 engine. Thinking "Harry-like" for a minute, imagine the discussions about a better cam for the 308? "The cam in the HT 350's works well, let's try that grind". Maybe.....
