lx coil over suspension
Posted 25 May 2013 - 07:56 AM
Wondering if I will need an engineer cert once its fitted
And how much of an improvement over standard set up are they .
_JChantrey_
Posted 25 May 2013 - 09:33 PM
What are the details on this kit? if you dont mind me asking.
I cant find it on their site
Posted 25 May 2013 - 11:30 PM
I have the fronts coilovers (QA1) and no you don't need an engineers as a lot of cars come standard with coil overs. So long as they mount in the standard position with the same spring location you are ok, that what I was advised.
Posted 26 May 2013 - 09:11 PM
Arguably the lower spring mount has changed on the coil-over so it could require engineering.
The only real advantage you get from fitting the McDonald Bros (QA1 Pro Coil) coil-over shock setup is ride height and shock adjustment.
As far as performance goes the QA1 Pro Coil coil-over shock setup has no advantage over an equivalent quality shock and spring using the factory setup.
The biggest problem with the QA1 Pro Coil coil-over shock setup is finding springs with a suitable height and spring rate to suit a Torana. Last time I checked McDonald Bros were supplying 250 lb/in or 350 lb/in springs which you then cut to suit the Torana. The standard Lovell V8 springs are 650 lb/in.
The reduced height available for the coil-over spring would probably make it impossible to fit a spring with a rate suitable for track work..
Posted 27 May 2013 - 07:44 PM
Thanks for your response
Posted 27 May 2013 - 08:10 PM
I doubt an engineer would pass the cut front springs if they saw them. The spring tower in the Torana is designed for a flat top spring, the cut springs will have a pigtail top.
I have found a flat top spring available in 375, 500, 600 and 700 lb/in that may be suitable for QA1 Pro Coil setup in a Torana. I have a 600 lb/in spring to test but I have not had time to put the car together to see how it will sit
Posted 27 May 2013 - 09:21 PM
Mine sits perfectly with the springs, ride pretty good and yes you need the spring with the flat top, -2 at the end of the number if I remember. I have the 350 springs, with the alloy engine its about the same weight as a 308. if I went 250's I probably have a bit more adjustment but tyre is just below flair and I like the ground clearance I have.
Posted 27 May 2013 - 09:39 PM
If you cut a spring and it had the same amount of coils as a standard spring after the surgury, that should be fine. Reducing the number of active coils is illegal.I doubt an engineer would pass the cut front springs if they saw them.
Posted 27 May 2013 - 10:15 PM
The factory spring is flat at the top and has a pigtail at the bottom. If you cut a factory style spring at the bottom you still have a pigtail so it will seat in the lower control arm.
The QA1 Pro Coil spring is flat at top and flat at the bottom for the shock. The spring that McDonald Bros supply is too tall for the Torana so it needs to be cut. If you cut the spring you will end up with a pigtail which the engineer should knock back.
Edited by ls2lxhatch, 27 May 2013 - 10:16 PM.
_UFO304_
Posted 09 December 2015 - 05:22 PM
I bought a set and its sitting about 2" too high at max adjustment.
Or does anyone know who can reset the spring?
_LS2 Hatch_
Posted 09 December 2015 - 06:42 PM
_UFO304_
Posted 09 December 2015 - 08:24 PM
_LS2 Hatch_
Posted 10 December 2015 - 02:42 PM
Posted 10 December 2015 - 03:38 PM
The QA1 Mustang spring is the only option I have found off the shelf to suit a Torana with QA1 Pro Coil Shocks.
The 600 lb/in and 700 lb/in springs would the two options depending on preferred ride height and engine weight.
http://www.qa1.net/s...-system-springs
The Lovells Standard Torana spring rates can be used as a guide to what spring rate you should be looking for.
Lovells Standard Torana Springs
Standard 6 cyl spring range 590 lb/in
Standard V8 spring range 760 lb/in
V8 Track cars run 850 – 1000 lb/in
I bought the Mustang 600 lb/in springs to suit a LS2 with my preferred ride height, on paper they work out about right. I won't know for sure until the car is finished.
I know of a hatch with a BBC that is using the 700 lb/in springs, they were happy with the ride height.
Edited by ls2lxhatch, 10 December 2015 - 03:39 PM.
Posted 10 December 2015 - 05:06 PM
One thing I've always wondered with those QA1 front springs is, being different diameters top & bottom, does that have a "progressive rate" effect?
Also, I just went to the McDonald Bros website and they don't seem to list QA1 coilovers any more? The only brand I can find is Viking...
_UFO304_
Posted 10 December 2015 - 05:37 PM
They don't do QA1 anymore, they do Viking.
Viking do a 9" length, 350lb spring that is apparently perfect for the Torana.
You can use the Viking spring with the QA1 stuff.
The QA1 spring was 10" length 350 LB.
Ray also offered to swap a 9" Viking for my 10" QA1 spring.
That's my plan at the moment.
I can get the springs reset for $70 if I need to.
_LS1 Taxi_
Posted 10 December 2015 - 05:45 PM
Posted 10 December 2015 - 06:11 PM
That's the sixty four thousand dollar question Daz.
I would assume their custom lower control arms would be designed to take the load...
McDonald Bros LH-LX Tubular Lower Wishbone.jpg 37.09K
13 downloads
...but personally I hate the idea of the vehicle's weight being supported by two small lower shock mount bolts each side.
Edited by Bigfella237, 10 December 2015 - 06:14 PM.
_LS1 Taxi_
Posted 10 December 2015 - 06:14 PM
I'd want to drill out the threads on the lower arm and use oversized nuts and bolts.
Posted 10 December 2015 - 06:19 PM
At the very least I'd like to see the shock located on top of the control arm so the bolts are only locating it and the weight is borne by the metal arm, this wouldn't really make any difference to fitting as you can't remove a coilover shock without relieving the spring tension anyway like you can with a regular OEM-style shock.
#21
Posted 10 December 2015 - 06:23 PM
THis has been my arguement with these bolt in kits for some time now, And why I think they should DEFINITELY need engineering.
The shock mount in the LCA WAS NOT designed to bear the weight of the vehicle.
Posted 10 December 2015 - 06:43 PM
While we're on the subject, anyone know if our LCAs are interchangeable with the early Camaro stuff from the US (I know the ball joints are the same)?
I've seen some really beefy-looking tubular Camaro arms available...
#23
THey do look nice, more clearance for brakes to by the looks.
#24
_LS1 Taxi_
Posted 10 December 2015 - 06:58 PM
The US arms look stronger but still a poo design
#25
Posted 10 December 2015 - 07:03 PM
I'll have a search around to see if I can find a technical drawing of the Camaro arms to compare to ours, they look very similar although the bump stop and swaybar mounts are different?
