Potta's LC GTR
699 replies to this topic
#376 Potta
Posted 30 January 2015 - 10:44 PM
Picked up a few bits from Dattoman that should keep me busy for a while, although still waiting to get my steering rack back, should be ready Monday I hope.
Attached File  Bits.JPG   110.34K   6 downloads
And here is my painted up drive shaft now with yoke plug and 2 new uni's. Fire engine red is really really red. Who woulda thunk it?
Attached File  Shaft.JPG   111.9K   5 downloads
Edited by Potta, 30 January 2015 - 10:45 PM.
#377 _LHSL308_
_LHSL308_
Posted 30 January 2015 - 11:44 PM
Matches your diff mate nice  :spoton:
#378 _duggan208_
_duggan208_
Posted 31 January 2015 - 12:41 AM
At least you know what you have to do. When its all done it will be a good car to drive around in.
Regards
#379 Potta
Posted 31 January 2015 - 01:48 AM
True on both counts guys.
WTF have I got myself into though?
Right front suspension is out and in little piles all over the shed.
Now I have to work out how to get the ball joints out, any tips appreciated.
The top one looks like it still has original rivets, happy days.
I can drill that out.
And will the bottom one come out in the vice or do I have to get it pressed out?
Good call to replace it though I reckon.
It will be MUCH nicer to drive once all this is done.
Definitely worth the effort.
#380 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 31 January 2015 - 02:00 AM
Sounds like your having a ball, you'll look back when it's done and think "I'm a frOcking legend"
#381 Potta
Posted 31 January 2015 - 02:03 AM
I just wanna drive me car Mav.....
I think I will appreciate it a lot more once I've finished all this.
#382 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 31 January 2015 - 02:15 AM
No doubt there's a Cruze on the horizon
#383 Ice
  • 15,202 posts
Posted 31 January 2015 - 07:20 AM
The bottom ones will have to be pressed out and back in Craig
#384 Potta
Posted 31 January 2015 - 09:38 AM
Ok, cheers mate.
#385 hawk
hawk
  • 2,190 posts
  • Name:steve
  • Car:UC Torana
Posted 31 January 2015 - 02:09 PM
When i did my front end i disasembled it and dropped all the bits in to a local mechanics and had them press in the new bushes and ball joints.
It costs stuff all and makes things so much easier
#386 Potta
Posted 04 February 2015 - 01:50 AM
Making slow progress still.
Wilkinson's suspensions have been fantastic, I got my rack back yesterday and dropped off my LCA's and new ball joints.
Went back today and picked them up, ball joints fitted and all.
Attached File  image.jpg   240.36K   2 downloads
Attached File  image.jpg   163.77K   2 downloads
I remembered I had these too so they are going in when I put it back together
Attached File  image.jpg   152.23K   4 downloads
I'm currently trying to remove my upper ball joints. They appear to have the original rivets in so I am trying to drill them out while still in the car.
Not easy especially when my drill bit goes blunt after one rivet, and there's not a whole lot of room in there.
Attached File  image.jpg   89.68K   3 downloads
#387 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 04 February 2015 - 06:09 AM
Knock the top of the rivet with angle grinder, then use a pin punch to knock the rest out.
#388 N/A-PWR
  • 9,639 posts
Posted 04 February 2015 - 08:00 AM
Great progress Craig,
You are an experienced mechanic now.  :clap:  :spoton:
Great advice Warren too
#389 dattoman
  • 16,487 posts
Posted 04 February 2015 - 08:46 AM
yep yep grind them off
#390 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 04 February 2015 - 09:42 AM
Looking good Craig.   Just keep making progress. :-)
Make sure you get the rotors on the correct side. (ones a left and the other right)
Marty
#391 Potta
Posted 04 February 2015 - 10:45 PM
Ok, less drilly drilly, more grindy grindy, got it.
Sounds like a plan.
Marty
Oooh,..I had forgotten about that, thanks for the reminder mate.
#392 _ljxu1torana_
_ljxu1torana_
Posted 04 February 2015 - 10:51 PM
are you going to paint the front end
#393 Potta
Posted 05 February 2015 - 01:16 AM
Probably not.
If I was going to would you vote for Linamint or Fire Engine Red?
#394 _ljxu1torana_
_ljxu1torana_
Posted 05 February 2015 - 08:08 AM
looks is everything for a rwc
#395 _threeblindmice_
_threeblindmice_
Posted 08 February 2015 - 01:14 PM
While your under the car , maybe check the K frame for a crack in the bracing , it's common , another problem I've had on our two last blue slips , is the rear brakes don't pass the brake test (NSW)so I would give them a bit of attention , if your rego test is the same as ours .
#396 Potta
Posted 08 February 2015 - 08:19 PM
Yeah good idea re the k-frame and I have got some rear cylinders so I can do the rear brakes cause they look like they are shot!
Still battling with ball joints at the moment, one side is almost done, but taking a lot longer than expected!
#397 _duggan208_
_duggan208_
Posted 09 February 2015 - 12:25 AM
Be all worth it when you have plates on it and it wont leave the front end on the road when you hit the first corner. May as well do as much as you can afford to the front end while its in pieces.
Regards
#398 Potta
Posted 09 February 2015 - 01:45 AM
One side done
Attached File  image.jpg   133.28K   6 downloads
New ball joints, spring, shock, disk, and caliper was rebuilt last year with new pads.
No play in there now.
Mostly stuff I've bought over the years for my other cars that have never made it in lol.
#399 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 09 February 2015 - 09:04 AM
Are those ball joint nuts and bolts the wrong way round?
#400 Ice
  • 15,202 posts
Posted 09 February 2015 - 11:40 AM
Are those ball joint nuts and bolts the wrong way round?Sent from my iPhone using Tapatalk
Yes Do it again Craig
