Heath's Hatch
#526
Posted 23 July 2015 - 07:55 AM
#527
Posted 23 July 2015 - 08:22 AM
Share the love heath, seeing you don't need them right now, send them to me, save shelf space, make another set when you need them later.
#528
_LS1 Hatch_
Posted 23 July 2015 - 08:35 AM
Yet another time I need to break out my secret decoder ring to make sense of you guys' numbers...lol1250mm length of of 75x50x2mm
#530
_LS1 Hatch_
Posted 23 July 2015 - 09:20 AM
1 Awesome = America.
Now let me go back to figure out how many cubits in a mm or what ever to sort out the frame connectors..
#531
Posted 23 July 2015 - 12:24 PM
#532
_LS1 Hatch_
Posted 24 July 2015 - 12:37 AM
#533
Posted 24 July 2015 - 08:17 AM
Not sure, but 20cm sound bigger than 8inches.
#534
Posted 24 July 2015 - 09:17 AM
So do Aussie spiders have 2.4 meters instead of 8 feet?
That's a small one.
#535
Posted 26 July 2015 - 09:49 PM
This tailshaft loop will be integrated into a brace that connects the two chassis rail extensions. This brace started off as 50x50x2mm SHS
Like everything on the car, trying to cut out dead material wherever possible.
Copied the shape of the gearbox crossmember to have some extra room for the exhaust.
Pretty refreshing to do a bit of TIG at the bench rather than leaning awkwardly into the car.
Definitely taking shape but nowhere near finished.
Edited by Heath, 26 July 2015 - 09:51 PM.
#536
Posted 26 July 2015 - 11:13 PM
Drag car tomorrow
i look forward to your future post mate
#537
Posted 26 July 2015 - 11:42 PM
I know you would've checked this out already H but do you reckon that hoop drops down far enough? I'd hate to see the rear suspension hanging on the drive shaft.
This pic isn't of a Torana but is something similar to the way I'd like to do it incorporating some structure for the upper trailing arm mount...
post-8224-0-58467500-1343789784.jpg 53.21K
9 downloads
#538
Posted 27 July 2015 - 06:58 AM
#539
Posted 27 July 2015 - 07:42 AM
I read that ANDRA required 3mm steel around 360°. I think it will be quite strong once finished, and you won't be able to measure the thickness of the strap once it's in the car.
The photo you shared is awesome.
Edited by Heath, 27 July 2015 - 07:43 AM.
#540
Posted 27 July 2015 - 08:26 AM
#541
Posted 27 July 2015 - 01:34 PM
The loop sits up close to the front uni so there isn't a whole lot of travel required ~
Haha, yeah I actually woke up in the middle of the night and face-palmed myself having realised my mistake, when you said it connects the two chassis rail extensions I wrongly assumed it was going across further back, like between the lower trailing arm mounts... sorry, I should'a known you were on top of it!
I was wondering why you went to the trouble of contouring it the same shape as the trans x-member, now I know!
Edited by Bigfella237, 27 July 2015 - 01:36 PM.
#542
_LS1 Taxi_
Posted 27 July 2015 - 06:08 PM
Not sure where the 6mm came from? 6mm is extremely heavy. 3mm will be fine - as specced by ANDRA.
#543
Posted 27 July 2015 - 09:18 PM
Is there no such thing as a plain Jane standard build thread these days?!! The build quality and custom mods are getting better all the time and the bar constantly getting raised, haha.
Keep the pics coming.
I want to rebuild my car. It's actually due for it
#544
Posted 27 July 2015 - 09:26 PM
I'm with ya! I was young once!full bump to full droop, and has enough room for me to get the tailshaft out when it's at full droop. I wanted it to be tight
#545
Posted 27 July 2015 - 09:40 PM
hahaha cheers Brett, means a lot. I know what you mean though. Everyone else has 10 pages worth of tricky rust repairs. Mine was pretty good rust-wise so I had to be a bit more creative with my time!Love your work Heatho old mate
Edited by Heath, 27 July 2015 - 09:42 PM.
#546
Posted 27 July 2015 - 10:24 PM
Really nice work. Neat as.
It is interesting that ANDRA specify a minimum of 50 mm x 3 mm yet CAMS specify a minimum of 30 x 5 mm for the 2015 Australian V8 Touring Car Series.
The NHRA specify a minimum of 2" x 0.25" which would explain why most of the universal loops are 2" x 0.25" (50.8 mm x 6.35 mm).
The McDonald Bros loop is 75 mm x 5 mm.
#547
_ott308_
Posted 28 July 2015 - 08:08 AM
Some nice work in here Heath!
#548
Posted 28 July 2015 - 08:34 AM
If it's too tight tho you don't get enough penetration.
#549
_SYCH08_
Posted 28 July 2015 - 04:47 PM
we have to have a 50x6mm over here in NZ for the road and drags
#550
Posted 23 August 2015 - 09:36 PM
Had to cut these little bits of the front seat strainer plates off, they will be welded into the cross-brace instead which will certainly be an increase in strength - not that they should need a whole lot.
Spent forever profile cutting some plates to attach the loop to the floor so that it's a continuous box section once welded.
I consider the weight increase significant at 4.5kg but I think I've made it about as efficiently as possible (could have been better if I could source thinner than 2mm square tube), and I am led to believe the structural difference will easily justify it.
So... what's next!?
Nothing, I've been having a break from the car for the last few weeks. Porsche, Chaser & Datsun are all getting overdue attention, and the Torana won't be touched again until the Cedric is blazing both rear tyres with the wastegate wide open and the screamer pipe destroying eardrums.
Edited by Heath, 23 August 2015 - 09:44 PM.
