* * * * * 8 votes
Heath's Hatch
2139 replies to this topic
#626 Heath
  • 18,393 posts
Posted 26 April 2016 - 01:10 PM
Yes, that is what we are talking.
Falcons had a watts link pin on the cast alloy diff hat and and transmitting the transverse load through the diff hat. Were they dowelled? If not, I wouldn't see that force to be much different.
#627 76lxhatch
  • 7,207 posts
Posted 26 April 2016 - 03:15 PM
I have one of those somewhere, from memory it does have a couple of small dowels in it. More for locating though, if its done up tight then the whole face takes the force.
#628 Heath
  • 18,393 posts
Posted 26 April 2016 - 05:06 PM
This will also be fastened to the axle tubes obviously, in addition to that.
#629 76lxhatch
  • 7,207 posts
Posted 26 April 2016 - 06:41 PM
Yeah that's likely to help more than anything else as it will spread the load a lot further, are you just going to bolt the parts together?
#630 Heath
  • 18,393 posts
Posted 26 April 2016 - 07:34 PM
Which parts, sorry?
Going to weld some stand-offs onto the axle tubes and run bolts through the brace onto the tubes to tie it all together. The ball joint pin will fit into a taper on the top of the brace, the balljoint will screw into a threaded tube on the top link.
Edited by Heath, 26 April 2016 - 07:36 PM.
#631 76lxhatch
  • 7,207 posts
Posted 26 April 2016 - 07:55 PM
I was talking about the brace to the axle tubes, was envisioning something sorta like that. I never would have thought of running a brace like that on anything but a Banjo-style housing, you know its good engineering when its simple (with the value of hindsight!)
#632 gtrboyy
gtrboyy
  • 3,211 posts
Posted 26 April 2016 - 09:10 PM
Yeah drag guys swear by them limiting housing flex & tie it to the caps so less likely break gears...they've got heaps more power than I'll ever have & faster times so must be onto something.
What you think this will weigh when finished?
#633 cameron
cameron
  • 371 posts
  • Name:Cameron
  • Car:LX SS Hatchback
Posted 26 April 2016 - 11:39 PM
You are doing such clean work its a credit to you. I was wondering how all the steel chassis braces and welding effects the legalities of the vehicals license? It must be adding to the weight and structures integrity. The licensing dept herein wa get all funny about changing the chassis.
Cameron
#634 axistr
axistr
  • 1,212 posts
Posted 28 April 2016 - 11:00 AM
Heath I think you might have to change your motto on the bottom of the page to " more weight, more cubic displacement " or more boost.
How much do you recon it will weigh when finished ?
#635 Heath
  • 18,393 posts
Posted 04 May 2016 - 10:52 PM
Are you asking me to predict the weight of the car? Or the weight of the diff brace and rear link? The diff will be heavier than the standard setup, significantly. And the gas tank assembly in the back will weigh more than the standard car too.
Not everything can be decreased in weight - it's particularly difficult when I'm trying to make it happy dealing with higher forces than the standard car was able to deal with - but where possible I'm trying.
Edited by Heath, 04 May 2016 - 10:54 PM.
#636 _Lightyear_
_Lightyear_
Posted 04 May 2016 - 11:11 PM
Where are the pics??
If you really want to save weight, you need to ditch all the metal panels. If only someone would lend me a hatchback moulds so I can make some nice light vacuum infused carbon fibre parts.
I already had a thought to mould the roof and quarters when mine is painted.. Then I can make a full composite hatchback to race in sports sedan.
#637 _LS2 Hatch_
_LS2 Hatch_
Posted 05 May 2016 - 07:52 AM
Great job Heath! Keep it up.
frOck the weight, just push the right pedal harder! You'll be fine!
#638 axistr
axistr
  • 1,212 posts
Posted 05 May 2016 - 08:25 AM
Both my Torana's ended up weighing much more than I thought, the hatch come in at 1,430kg and the SLR 1,450kg unfortunately adding a few mod cons and a bit of strength quickly add up.
#639 myss427
myss427
  • 1,636 posts
Posted 05 May 2016 - 09:26 AM
Mine came in at 1350, alloy engine, diff center, radiator, glass bumpers, lightweight Recarros, small optima battery ect. And its full chassis with heater, dynomatt and all legal requirements.I just made sure no heavy unnecessary stuff was added or removed.
#640 _Lightyear_
_Lightyear_
Posted 05 May 2016 - 09:34 AM
I would have thought they would weigh around 1200kg's. I will build a lightweight one, maybe. No wonder I can beat toranas in my MX5. (Weighs pretty much 1000kg's)
#641 myss427
myss427
  • 1,636 posts
Posted 05 May 2016 - 12:57 PM
1200 ish for a bog stock V8 sedan, with tiny banjo and depress.
#642 _LS2 Hatch_
_LS2 Hatch_
Posted 05 May 2016 - 03:28 PM
Can't see an MX5 doing over my Hatch"............. Just say'n
#643 Ice
  • 15,202 posts
Posted 05 May 2016 - 03:33 PM
Me either
#644 76lxhatch
  • 7,207 posts
Posted 05 May 2016 - 03:39 PM
At the risk of playing devil's advocate I don't doubt that's true in a straight line but...
Heath is working on the whole package though I'm sure ;-)
#645 _LS2 Hatch_
_LS2 Hatch_
Posted 05 May 2016 - 03:46 PM
True on Heaths package, although I prefer not to discuss other peoples package in too much detail ;)
#646 _Bomber Watson_
Posted 05 May 2016 - 04:50 PM
I could definitely see a MX5 walking a Torana in anything somewhat twisty.
#647 _LS2 Hatch_
_LS2 Hatch_
Posted 05 May 2016 - 05:06 PM
There may well be one exception to that Bomber. Don't think it's finished yet, but Glen(think that's his name) building the hatch with the skyline(??) driveline. That should be great handling hybrid (I think I'm safe calling it that).
Plus, apart from my comment being a bit of a smart ass comment, I was thinking lights to lights. Not often you get a chance to go someone on twisties (depending on where you live of course).
#648 _Bomber Watson_
Posted 05 May 2016 - 05:15 PM
Agreed and agreed.
#649 axistr
axistr
  • 1,212 posts
Posted 05 May 2016 - 07:33 PM
I think the equation is for every 10kg lost you gain 1.2hp offset.
#650 _Bomber Watson_
Posted 05 May 2016 - 08:39 PM
According to the Moroso slide rule thas about right.
