* * * * * 8 votes
Heath's Hatch
2139 replies to this topic
#676 IMORAL
IMORAL
    Bored
  • 2,568 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 01 June 2016 - 01:35 PM
What I don't understand is you spend all this time fabricating these amazing panels then some Cunning Stunt comes along and fills them full of holes :wtf:
;) lol
#677 _LS1 Hatch_
_LS1 Hatch_
Posted 01 June 2016 - 01:48 PM
.. then some Daisy Chain comes along and fills them full of holes :wtf:
;) lol
There for a reason.. :D
Edited by LS1 Hatch, 01 June 2016 - 01:48 PM.
#678 Heath
  • 18,393 posts
Posted 01 June 2016 - 02:22 PM
Sactly.
#679 Heath
  • 18,393 posts
Posted 02 June 2016 - 11:06 PM
The legendary staff at R&J Batteries have lent me their 'dummy' battery of what they think is what I need for this car, it's a Full River HC28 which is a cost-effective, reasonably compact battery and a little lighter than a lead acid. It isn't actually a dry-cell but you can orient them however you want which I think is quite cool.
I'm going to put mine basically here, but tucked a bit behind that beam and a little bit lower.
Had some more sheet metal sitting there for jobs like this, marked out a rough battery tray
Zipped this shape out, will make more sense once it's folded up and in position... hopefully having another crack on that folder soon
Had a few holes in the chassis rails from a towbar install in previous ownership. This is just the underside which is far neater than inside the car. The holes that I didn't remove were holes I just drilled the other day to fit the 'drop tank' panel on with in the future. They'll have nutserts installed once the floor is painted.
And on the other side:
Cleaned up the inside of the filler cut-out extension I made.
Then time to plug weld my flat kick-up on the beaver panel up to the new flat floor. I pre-drilled this before installing the new floor to make this part much easier.
And that's where I'm up to.
Edited by Heath, 02 June 2016 - 11:08 PM.
#680 Heath
  • 18,393 posts
Posted 05 June 2016 - 11:05 PM
My mate started working at a racecar fabrication shop recently and I was allowed to do a little foreigner on his bender:
There's a bit more work to do but this is the tray that the battery will sit in:
Bit cleaner than doing it with a vice etc.
Quick zap with the TIG:
Basic flat bit of steel and the spare wheel shape that need to be put together:
Also managed to put some shape into this panel at the above shop on the roller:
Lots of in-and-out, trimming little bits off and bending things to where they need to be:
Battery tray will sit down into it like so:
Wanted to keep all of the factory swage lines and stuff in it, lots of organic shapes in the cut.
Whilst I'm fixing up the tow bar holes, I also noticed a little rust hole in the back of the chassis rail that needed to be filled. Pretty pleased to only be having to do these kinds of rust repairs on the hatch :P
Top side of the tow bar holes (heaps of distortion from obviously not having rigid enough/large enough washers which is totally typical).
Other side:
#681 Ice
  • 15,201 posts
Posted 05 June 2016 - 11:12 PM
Jesus Heath all your metal fab work is doing my head in
seriously though awesome work mate i tip my hat off to you
cheers Gene.
#682 76lxhatch
  • 7,205 posts
Posted 06 June 2016 - 11:08 AM
They're actually supposed to have crush tubes
Nice work
#683 rodomo
  • 18,038 posts
Posted 06 June 2016 - 08:45 PM
cheers Gene.
God will/should strike you down you blaspheme, with regards to Heaths work????.................harder than cutting tiles and gluing them.
#684 Heath
  • 18,393 posts
Posted 06 June 2016 - 11:48 PM
Back to the office again tonight:
Finished welding in the other little patch panels in the RHS rail:
Welded some more of the floor in:
After lots of stuffing around, got the spare wheel well to meet up really perfectly with the rolled floor. Tacked it into place with very good results.
That's probably the hardest part of the floor done, now. Pretty proud for piecing that together as neatly as I have. Whether the aesthetics of the design are nice or not is another question, but it kinda had to be there and I will try and clean it up nicely.
Edited by Heath, 06 June 2016 - 11:51 PM.
#685 SHEEL
SHEEL
  • 345 posts
  • Name:Daniel
Posted 08 June 2016 - 03:29 PM
Looks awesome Heath, I can't wait to see it finished. Hopefully it will have that factory look you are going for where it looks like it was meant to be that way!
#686 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 08 June 2016 - 09:10 PM
Awesome fabrication work Heath.
Wish i had your metalwork skills.id save a fortune lol
Edited by madtoranajzedded, 08 June 2016 - 09:11 PM.
#687 Heath
  • 18,393 posts
Posted 08 June 2016 - 11:57 PM
Thanks guys. Well yeah it's a pretty slow process so I'm not surprised it costs a lot even when someone knows what they're doing.
Welded up the join at the front:
Got the battery box to actually fit in the hole:
In the above photo, you will see that I trimmed off all the shit hanging down from the 'false floor' and I'm gonna put a bit of RHS across between the tubs instead.
Oh yeah and got carried away drilling holes again.
#688 _Bomber Watson_
Posted 09 June 2016 - 08:29 AM
How many holesaws do you chew through haha?
#689 Heath
  • 18,393 posts
Posted 13 June 2016 - 11:33 PM
My diff brace had a few open sections that needed some more cross-sectional strength
Made up some little gussets:
Picked up a metre of 25x25x2mm SHS and mitre cut the ends to suit the shape of the inner tubs:
Drilled holes along that line for plug-welding, and clamped the SHS underneath.
Welded it to the inner tubs of the rear wheels and now the rear floor is rock-solid.
Obviously won't hurt in supporting the shock towers as it is welded directly onto the metal behind them.
Folded the tops of the battery tray over at the right level and profile cut it nicely to fit the floor.
Zap zap
Making sure that the positioning of what I've been working on is actually going to work... seems okay haha
#690 IMORAL
IMORAL
    Bored
  • 2,568 posts
  • Name:Paul
Posted 14 June 2016 - 09:13 AM
Be a shame to cover all that up with dyna mat and carpet...
#691 _Bomber Watson_
Posted 14 June 2016 - 09:36 AM
Rideheight looks like it will be appropriate.
#692 _Lightyear_
_Lightyear_
Posted 14 June 2016 - 09:39 AM
Msg me when you are there so I can drop off the flares.
#693 Heath
  • 18,393 posts
Posted 27 June 2016 - 09:10 PM
Changed my design on the back brace and had to weld up some holes:
Tacked some 1040 bar in to become crush tubes for the bolts:
Boxed it all in:
Lots of welding:
3.5kg:
Shaped some 1040 in a bigger diameter to fit snugly around the axle tubes:
Drilled and tapped the holes:
Also finished the repairs on the inside of the chassis rails:
Edited by Heath, 27 June 2016 - 09:13 PM.
#694 _LS1 Taxi_
_LS1 Taxi_
Posted 27 June 2016 - 09:18 PM
Lol, that thing is the frOcking Death Star of 3rd members!
#695 Heath
  • 18,393 posts
Posted 27 June 2016 - 09:44 PM
haha yeah
Sourced a Ferrari F40 tyre (335/35/R17) as that seemed a good tyre to 'make fit' if possible.
The obvious place it hits is the bottom of the tub as it tapers to the outside of the car, aft of the axle. Cut a little shape out and started stretching it on one side.
Edited by Heath, 27 June 2016 - 09:44 PM.
#696 _ljxu1torana_
_ljxu1torana_
Posted 28 June 2016 - 12:22 AM
just a question heath excellent work,10 bolt diffs centre comes out from the back of housings and you have braced the back of the housing,what will you do if you break a diff centre.
#697 torana_nick
torana_nick
  • 759 posts
  • Name:Nick
  • Car:LH Torana Project
Posted 28 June 2016 - 07:55 AM
The fabrication work is awesome. Loving your work Heath.
#698 Heath
  • 18,393 posts
Posted 28 June 2016 - 08:00 AM
Cheers guys.
Jason, this isn't a 10-bolt but yeah the carrier certainly gets loaded into the rear as you say, this is why the brace is a bolt-on assembly. Not sure I've understood your question correctly?
#699 orangeLJ
Posted 28 June 2016 - 10:42 AM
I think he missed the section where you bolt it on.
I get it though, I was initially wondering how you were going to make the extensions out to the axle tubes work without welding it all on.
Good work as always Heath, glueing stuff together well.
#700 SHEEL
SHEEL
  • 345 posts
  • Name:Daniel
Posted 28 June 2016 - 01:48 PM
Every once in a while there is an awesome build out there that you just keep hanging for updates... this is one of those builds!
