* * * * * 8 votes
Heath's Hatch
2139 replies to this topic
#51 _Skapinad_
_Skapinad_
Posted 25 July 2013 - 06:43 PM
Congrats Heath..... Doesnt matter what you do, it will always be ugly .... Try taking photos from the side!
#52 Heath
  • 18,393 posts
Posted 28 July 2013 - 01:11 PM
I will deal with the ugliness in time lol.
Want to put an LX rack in this car to speed up the steering a bit, but not a fan of the rubber mounts. This is not the finest machining work I've ever done, but I figure the design will probably need to be revised anyway. Spun these up earlier this weekend, two are just plain ally washers with a flat linished on them (to sit on the front), the other two are chamfered down to seat positively on the back of the rack (you won't really see them). I notice the UC rack actually has one of its bushes 'slotted' as are the ones that eyepeeler has for his car. I haven't slotted mine, and I've drilled them to a fraction under 1/2" so i will drill/file them accordingly which should ensure I can get a decent fit. We'll see...
#53 _LS2 Hatch_
_LS2 Hatch_
Posted 28 July 2013 - 01:15 PM
What's the advantage of a solid bush for the steering rack? I've noticed others have done it also
#54 eyepeeler
eyepeeler
  • 1,959 posts
Posted 28 July 2013 - 01:36 PM
Will be really interested to see if you end up filing it out a bit. I was having the same conversation with Welby (A9X) before I had mine made up, why do they need to be slotted?
Nice one mate.
#55 _evil UC hatch_
_evil UC hatch_
Posted 28 July 2013 - 01:56 PM
That is a very cool looking hatch you picked up there Heath, as I said on Facebook a week or so ago I have recently picked one up for myself, and I'm loving yours in the black. mine actually needs a respray and a fair bit of rust repair, as well as already being the same blue as my VC, so you have me hooked on a black paint job.
I look forward to see what you do with this, you're talents seemed to have grown quite a bit since the green machine :spoton:
#56 _Lazarus_
_Lazarus_
Posted 28 July 2013 - 02:07 PM
"Want to put an LX rack in this car to speed up the steering a bit..."
What's the ratio difference please... ?
#57 _Lazarus_
_Lazarus_
Posted 28 July 2013 - 02:12 PM
Sorry, forgot to say - beautiful car Heath.
And yeah... I agree, black really suits the UC. But mine will not be black only...
Stay tuned.
#58 Heath
  • 18,393 posts
Posted 28 July 2013 - 02:34 PM
Sorry, LH rack*
P/N: 9932244 is 18:1 rather than 20.4:1. But the steering arms on the UC are longer also which probably makes nearly as much difference again?
#59 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 28 July 2013 - 09:44 PM
Alloy bushes won't wear out like the rubber ones. Also, the rack tends to move around a bit with rubber bushes.
#60 Heath
  • 18,393 posts
Posted 28 July 2013 - 10:25 PM
I was going for the more positive location aspect, not the wearing out aspect, but I suppose that is also true.
#61 _LS1 Taxi_
_LS1 Taxi_
Posted 28 July 2013 - 10:40 PM
I've got the urethane bushes in mine (only urethane I run except engine mounts) for less movement. Those alloy jobbies are impressive. Can't see value in slots either...
#62 Potta
Posted 29 July 2013 - 10:44 PM
Heath will let us know when he finds out  :P
#63 Heath
  • 18,393 posts
Posted 07 August 2013 - 01:14 PM
The centre distance on the LH rack seems to be spot-on. Still haven't figured out what the slot is for.
#64 rodomo
  • 18,039 posts
Posted 07 August 2013 - 11:06 PM
Picture of slot please?
#65 eyepeeler
eyepeeler
  • 1,959 posts
Posted 07 August 2013 - 11:24 PM
Attached File  image.jpg   89.79K   31 downloads
Attached File  image.jpg   130.86K   31 downloads
#66 Heath
  • 18,393 posts
Posted 07 August 2013 - 11:26 PM
As above.
Just filed each of these bushes for a minute or two until they were a snug fit on the standard captive bolts.
Chopped the end off the steering rack input to accomodate the twin-uni mod:
Gave the rack a bit of a tidy up
Chucked it in.
#67 Potta
Posted 07 August 2013 - 11:33 PM
Nice rack Heath!
#68 eyepeeler
eyepeeler
  • 1,959 posts
Posted 07 August 2013 - 11:35 PM
Nice mate, that looks really good.
#69 _stooy_
_stooy_
Posted 08 August 2013 - 04:32 PM
I forgot there would be progress pics up here.
Looks good mate, especially down lower!
Have your sorted all the carby dramas with the secondary's etc?
#70 Heath
  • 18,393 posts
Posted 08 August 2013 - 11:36 PM
Seems to be fuelly when you open the taps, haven't fiddled with it yet. Still got a dead short on the electric choke so that is disabled too. Haven't driven out of the industrial estate for weeks now lol, hopefully that changes tomorrow arvo.
#71 _stooy_
_stooy_
Posted 09 August 2013 - 10:43 AM
Cool, it should be easy enough to sort, those Webber bits are everywhere, I am not sure if you really need a choke at all, we disconnected the one on the Haines, we just give it two pumps when its really cold and it comes up no worries.
Be good to drive it!  The GT has only been gone a week and a half and I am missing it already.
#72 Heath
  • 18,393 posts
Posted 09 August 2013 - 08:46 PM
No luck today. Didn't really notice until I put it in the car but this steering rack is a bit 'tight'. Felt weird on the hoist then took it for a spin and it didn't want to self-centre etc. Figure it's probably not worth getting an alignment if I'm gonna have to re-do the steering part of it. That is not very satisfying. Might have to do some work to the column while I'm at it to make it worth the while.
#73 Heath
  • 18,393 posts
Posted 23 August 2013 - 10:58 PM
Bit of an update... car went back together after a fair while off the road. Ended up having to put a 1mm thick rubber washer behind each rubber bush (against the K-frame) to ease up some misalignment in the mounting surfaces on the K-frame, not sure if other solid bush guys have experienced the same thing? But it was making the rack tight and it was a bit tricky to diagnose.
Linished the column down for the sealed bearing mod.
Cut the column short
Deburred the shaft & end, marked the point of the hex to line up with the rollpin hole etc
Refitted rollpin in new hole
Turned up longer intermediate steering shaft, filed the flats on manually
All back together
Should be able to feel the work come together after my wheel alignment tomorrow!
#74 _Lazarus_
_Lazarus_
Posted 23 August 2013 - 11:13 PM
What's the go with that modification ? Is there a thread on that, and what are the benefits please ?
I can imagine why it is done but would like to have it thoroughly explained if possible - bearing part number etc.
#75 Heath
  • 18,393 posts
Posted 24 August 2013 - 08:48 AM
The sealed bearing swap is a very common mod documented in this thread:
http://www.gmh-toran...brg/?hl=g clamp
The bearing I used was a (updated part number 20/4/23) 6205-2RS-25.4. It is a 1" I.D. and 2" O.D. bearing with rubber seals on both sides. The standard unsealed bearings don't work very well - have a fair bit of resistance, fall apart and are damn ugly.
Replacing the rag couple with a second uni joint is also a pretty common modication for more direct steering.
Shortening the column and making a longer (4340) intermediate shaft was something I thought of years ago and I've been waiting for an opportunity to do, but I have seen someone else on the forum do the same job. You could argue the difference is negligible but I prefer sharing the shaft misalignment between the two joints - it is a mechnically superior system - also makes for better clearance, I probably coulda/shoulda made the column even shorter but it's done now.
