* * * * * 8 votes
Heath's Hatch
2139 replies to this topic
#851 _LS1 Taxi_
_LS1 Taxi_
Posted 09 September 2017 - 06:34 PM
Thanks. 10.5 Litres volume.
Just mocked up the steering, and the lower Uni joint is hitting one of the primaries. Not happy.
Clearance it with a hammer sir #itmakesnodifference
#852 Heath
  • 18,393 posts
Posted 10 September 2017 - 04:34 PM
Yeah I'm not really game to go pie cutting into a primary and hoping that I don't drop weld into the flow path. The heat & flog the frOck out of out technique was preferable:
I was on the fence about the product before, but honestly, what a piece of shit. Wonder if the Pro Flow ones are any different? They look IDENTICAL in the photos.
Edited by Heath, 10 September 2017 - 04:37 PM.
#853 axistr
axistr
  • 1,212 posts
Posted 10 September 2017 - 05:01 PM
Wow all that good work on the collectors to get good flowing exhaust through the extractors then you flog it with a club to narrow it.
#854 Heath
  • 18,393 posts
Posted 10 September 2017 - 05:02 PM
The Engine Masters video on the topic suggests it makes no difference and I'm fairly convinced.
Cut the 1/2" stainless bar with some mitres and put together some engine mounts:
Can't finish my exhaust without my diff housing, currently with a diff shop that is going to put some negative camber into it but they're taking their sweet arse time.
Next area... thought I'd inspect the inside of the roof. All looks pretty good!
Hmmm what's happening here?
Looks like a nice clean slate.
This is how I view the audience of this thread now:
#855 axistr
axistr
  • 1,212 posts
Posted 10 September 2017 - 05:07 PM
why not heat shrink the housing yourself when the car is on the alignment machine. Much more accurate and easy to do. You can also set your toe and thrust angle at the same time.
#856 Heath
  • 18,393 posts
Posted 10 September 2017 - 05:25 PM
I had a crack at it myself with the oxy, and even tried pre-loading it before heating up the tube, but got it to move stuff all.
Apparently it needs to go in a press... I don't know what the best practice is. This is all new to me!
Edited by Heath, 10 September 2017 - 05:28 PM.
#857 _LS1 Taxi_
_LS1 Taxi_
Posted 10 September 2017 - 05:38 PM
lol, I've been waiting to see a makita sink into that roof for months! Get after it!! :lol:
#858 Heath
  • 18,393 posts
Posted 10 September 2017 - 05:41 PM
Bidding on this on eBay at the moment:
tylerskidmore-37070-albums-interior-334-
#859 axistr
axistr
  • 1,212 posts
Posted 10 September 2017 - 05:47 PM
Your not doing it right then. I had to do heat shrinks on car & truck diff housings and trailer tube axles on a weekly basis. We never preloaded the axles. By heat shrinking only we often moved the camber 45 minutes and the toe in/out by 4 mm. We  used to get a lot of 4x4s from panel shops that already had their diff housing straightened from diff specialists, which were always miles out. When they were out by more than 1 1/2 degree we would cold bend them first but in most cases this also moved the toe, so we had to heat shrink them to fix this as well, at the same time we worked the thrust angle. I all depends where and how wide you make the heat shrinks. In cases where the camber had to be moved a lot we would do 5 or 6 shrinks 1 inch apart.
#860 76lxhatch
  • 7,205 posts
Posted 11 September 2017 - 06:56 AM
Headers are not as bad as they looked, I thought you'd be re-routing the primary pipe to tuck it in tighter. Never hesitate to cut up brand new parts to make them better :-)
Not sure I like that particular style of sunroof, very bulky looking and a excessive trim around it. But I like the idea.
#861 myss427
myss427
  • 1,636 posts
Posted 11 September 2017 - 02:45 PM
Put the Pro-Flows on a mates XY had to mod heaps (banged steering box and frame) to get them to fit, he ended up going Pacemakers as the Pro-Flows hung too low.
#862 Heath
  • 18,393 posts
Posted 11 September 2017 - 03:02 PM
I think I'd need to hear feedback on the Torana ones specifically, and I couldn't find a whole lot of discussion about them.
Agree about the sunroof, it needs to be complemented with a second one behind it to look any good.
#863 UC308Hatch
UC308Hatch
  • 119 posts
  • Name:Ron McNab
  • Car:UC Torana Hatch
Posted 11 September 2017 - 04:37 PM
Got to say Heath, been loving the direction this build has been taking, but surely you got to be taking pi##? Any weight reduction gained is going to be replaced 3 or 4 fold with that sun roof.....
Edited by UC308Hatch, 11 September 2017 - 04:38 PM.
#864 _LS1 Taxi_
_LS1 Taxi_
Posted 11 September 2017 - 04:45 PM
I'd be converting it to a T-top myself....
#865 SmacT
SmacT
  • 977 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 11 September 2017 - 06:47 PM
Two aerial holes - spoont! I'd own this thing in a second.
#866 Ice
  • 15,201 posts
Posted 11 September 2017 - 07:34 PM
Hang on your gunna cut a hole in the roof are you out of your god damm frOckin mind Heath
Another lunatic ✌️
#867 _LS1 Taxi_
_LS1 Taxi_
Posted 11 September 2017 - 07:37 PM
This thread is warming up very nicely
#868 Heath
  • 18,393 posts
Posted 11 September 2017 - 07:51 PM
It's been a cold winter... Figured it was about time to stoke this sucker up.
#869 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 11 September 2017 - 07:55 PM
A NO for a sunroof from me :o
#870 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 11 September 2017 - 09:21 PM
Like your work Heath, that exhaust thing is interesting and I would like to hear it one day.
If you making everything lighter can you just remove the roof and fit an alloy roll bar or a pop up one from an old SLK Mercedes? Or a retractable hard top, surely there is a wrecked Peugeot in a wrecking yard with all the bits.
Keep it up, looking forward to the next install
#871 rodomo
  • 18,038 posts
Posted 12 September 2017 - 02:04 AM
I'm sure Heath is just taking the piss about the sun roof.
Isn't he? :dontknow:
#872 Bigfella237
Posted 12 September 2017 - 02:19 AM
Surely Heath would TIG-up his own out of Aluminum Oxynitride (aka transparent aluminium)?
#873 Heath
  • 18,393 posts
Posted 08 November 2017 - 09:34 PM
Well I cut a big hole in the roof for the sunroof and have basically lost interest since...
Might put this thing up for sale unfinished, or at least take a break for a while.
#874 Bigfella237
Posted 09 November 2017 - 12:23 PM
Damn, I hope you keep it Heath, this is one of my favourite build threads!
#875 myss427
myss427
  • 1,636 posts
Posted 09 November 2017 - 01:00 PM
Why the loss of love for the car, was going well?
