* * * * * 8 votes
Heath's Hatch
2139 replies to this topic
#876 rodomo
  • 18,038 posts
Posted 09 November 2017 - 10:53 PM
What's the girls name Heath?
#877 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 10 November 2017 - 11:00 AM
LOL...a girl puts an end to everything.....
Edited by Redslur, 10 November 2017 - 11:01 AM.
#878 UC308Hatch
UC308Hatch
  • 119 posts
  • Name:Ron McNab
  • Car:UC Torana Hatch
Posted 10 November 2017 - 11:06 AM
Sure as hell hoping it's another one of Heath's attempts at humor!!
Really want to see this finished in the form it was dreamt up as.
#879 Heath
  • 18,393 posts
Posted 12 November 2017 - 06:44 PM
It's one of my crappy attempts at humour. Been doing a lot, not many stages of completion reached though - so not all that much to report.
#880 UC308Hatch
UC308Hatch
  • 119 posts
  • Name:Ron McNab
Posted 12 November 2017 - 08:19 PM
Glad to hear it!!
Rome wasn't built in a day & either was a good car. Lol mine took 8 years & still have more to do.....
#881 rodomo
  • 18,038 posts
Posted 12 November 2017 - 08:45 PM
Yep, when you get bored with one bit, move on to another, then go back.
#882 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 13 November 2017 - 01:04 PM
Thank goodness for that- was wondering what the hell was going on.
Please don't give up your day job to do stand up Heath.
#883 Heath
  • 18,393 posts
Posted 14 November 2017 - 11:45 PM
Sorry Stuart, just trying to make this thread an emotional rollercoaster to engage my readers more thoroughly.
After grinding the extractor holes out, the fasteners had next to no purchase on the flange because the holes were too big everywhere else, so they needed more work:
Welded extra in there, ground it flat, and then ground the holes out to the size & position they should have been.
Finally happy with the way they bolt up.
Got my diff back from the shop with a degree of negative camber bent into it, mocked it and the swaybar up to finish the exhaust.
End of the pipes just tuck into the area between the swaybar brackets at full droop, at ride height the diff will be higher and out of the way.
That's a wrap!
I was advised to strengthen the front swaybar mounts a little:
Diff getting ready for a lick of paint:
A bit of accomplishment just being able to tick a few components off the list and painting them. I'm using KBS gloss black which I've been experimenting with spraying (only brushed it in the past).
All of the parts have been deburred and all the casting/pressing/trimming marks ground out so they all look like the one on the left:
Edited by Heath, 14 November 2017 - 11:47 PM.
#884 Heath
  • 18,393 posts
Posted 15 November 2017 - 12:06 AM
Alright so this car seriously is getting a massive hole in the roof, like by far the biggest you've ever seen - as close to a Targa as I can get.
So I bought a roof cut from a Porsche 944:
Eg:
I've been able to disect it carefully so the corner pieces and bracketry can be adapted to my car.
My skin will need some edges very tactfully rolled into it - I won't do this myself as I want to make sure no filler is required.
One of the jobs is making a mount for the sunroof panel in the rear of the car:
Welded into the back of the car:
Like a glove! Almost looks like it was designed to fit. And by that I mean I spent about a year finding a sunroof solution that would work well in a Torana hatchback.
FINALLY mounting the sunroof in the storage location meant I could position the LPG tank at the right height, so bought some flat bar and made some straps:
Added a little gusset to the upper straps that don't wrap around the square edge:
Now I've just gotta get my CAD design ally floor section cut up and bent to cover the tank in...
Also got some new K-Mac Rear Mount(rear) Swaybar adjuster brackets so I could sell my 'kit' in the earlier photos:
Had a custom profile 20mm bar bent up locally to suit my tub modifications, and it was a bit loose (laterally) so I made up some little rings and lightly welded them on.
When that is done being re-tempered, I can get some bits and pieces powdercoated.
Edited by Heath, 15 November 2017 - 12:22 AM.
#885 Heath
  • 18,393 posts
Posted 15 November 2017 - 12:50 AM
While the gearbox was still in, I realised that the standard shifter boot just wasn't going to work very well around the tower of the TKO. After much deliberation, I settled on a Porsche 911 Rubber Boot:
Found a catalytic converter with a nice tapered round shape, and welded it back together after stripping out the insides:
Cut the hole out to be much bigger:
Welded up the gap at the back of the hole:
Welded a sturdy strip at the back with a new profile much closer to the carpet height:
This piece will just be rivetted into place, so that it can be removed to change shifter assemblies etc.
Designed up a suitable footrest - a feature I always thought a Torana would benefit from.
Cut the floor sections out for these adjustments:
Flash back to an old photo when I had the extractors cut into pieces... I had a clearance problem with the floor here:
Probably some sore necks after this post!
#886 76lxhatch
  • 7,205 posts
Posted 15 November 2017 - 05:49 AM
Nice updates!
Have had thoughts on the footrest myself, mine has a hole worn in the carpet where my left foot sits (where your foot is in the photo where its not actually on the rest). Good idea incorporating the firewall clearance with it.
Are you going to be introducing some additional structure when you cut that big hole in the roof?
#887 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 15 November 2017 - 08:50 AM
Bloody hell Heath this is a far cry from the lad in the driveway of his mums house with a grinder in his hand
Love the work
#888 SHEEL
SHEEL
  • 345 posts
  • Name:Daniel
Posted 15 November 2017 - 11:19 AM
I am really liking the porsche sunroof idea! so well executed with the sunroof storage under the floor!! absolutely brilliant!
#889 UC308Hatch
UC308Hatch
  • 119 posts
  • Name:Ron McNab
Posted 15 November 2017 - 11:22 AM
You had me going! Awesome work as usual
#890 axistr
axistr
  • 1,212 posts
Posted 15 November 2017 - 12:45 PM
looks like you have been a busy little boy Heath.
#891 rodomo
  • 18,038 posts
Posted 15 November 2017 - 09:15 PM
Pic of hole in roof or it didn't happen.
#892 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 15 November 2017 - 09:37 PM
Fantastic work as usual Heath,
Can you explain a bit of the negative camber in the diff please?
Is it only possible because you have floating hubs?
In my head I can only picture a solid axle diff with the ends bent up which makes me wonder how the bearings are fitted? And supporting the axles
#893 Bigfella237
Posted 16 November 2017 - 03:54 AM
That's the beauty of full floating axles, the drive axle is completely independent of the wheel bearings...
#894 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 16 November 2017 - 05:18 AM
Thanks Andrew,
Will do some reading about floating axles.
Bit too serious for my build but most old the ideas in Heaths hatch are beyond my build
#895 bullitA9X
bullitA9X
  • 4,168 posts
Posted 16 November 2017 - 11:18 AM
Love your work heath you have some amazing skills but dont cut the roof or i will come over and frOcking slap you silly 😀😀
#896 Heath
  • 18,393 posts
Posted 17 November 2017 - 04:38 AM
Better get that slappin' hand ready mate!
#897 Peter UC
Peter UC
  • 770 posts
Posted 17 November 2017 - 11:34 AM
On the plus side, if anyone has a hatch with a sunroof they would like to fill, Heath will have the perfect patch panel.
#898 bullitA9X
bullitA9X
  • 4,168 posts
Posted 17 November 2017 - 12:59 PM
What's your address 😁
#899 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 17 November 2017 - 10:40 PM
What's your address
Hey once you've finished your slapping session can you bring back the sunroof repair panel for me mate?
Sent from my Moto G (5) using Tapatalk
#900 bullitA9X
bullitA9X
  • 4,168 posts
Posted 21 November 2017 - 02:44 PM
Haha frOck yeah mate
Sent from my SM-G935F using Tapatalk
